Hızlı Arama
Ürün Özellikleri:
Ethernet PC Card
EOL
Tanımlama:
High Permormance
This PC card raises throughput significantly compared to conventional PC cards. The high performance is builtdirectly into adapter's controller, dispensing users of the need for band-aid drivers.
Full-duplex Support
This function allows a notebook to connect to a switch and becomea power server, receiving and transmitting data at the same time ona dedicated Mbps bandwidth.
Snap-in Installation
The driver programs automatically search for and assign an available IRQ and I/O address. With the hot-swap support, users can plug in the PC card and connect it to the network anytime without any need to configure
Ürünler | Destek  | Haberler  | Hakkında |
