DE-660T(CT/LT)EOL EOS
Ethernet PC Card
Tanımlama
High Permormance
This PC card raises throughput significantly compared to conventional PC cards. The high performance is builtdirectly into adapter's controller, dispensing users of the need for band-aid drivers.
Full-duplex Support
This function allows a notebook to connect to a switch and becomea power server, receiving and transmitting data at the same time ona dedicated Mbps bandwidth.
Snap-in Installation
The driver programs automatically search for and assign an available IRQ and I/O address. With the hot-swap support, users can plug in the PC card and connect it to the network anytime without any need to configure
Genel Özellikler
Çözümler
Sipariş Bilgisi
Görseller
İndir
Destek Merkezi
