DVG-N5402FFEOL EOS
WIRELESS N VoIP ACTIVE FIBER ROUTER
Tanımlama
INTERNET PHONE SOLUTION FOR HOME & SOHO
The D-Link DVG-N5402FF Wireless N VoIP Active Fiber Router allows you to take advantage of your modem or fiber connection to share your Internet connection with multiple computers, while making inexpensive Internet phone calls. It combines the industry’s latest Voice over IP network technology with advanced communication features, and is compatible with phone services industry-wide. This router lets you connect up to two ordinary phone sets, allowing you to make two separate calls over the Internet simultaneously, while leaving you with enough bandwidth to stream media and surf the Internet with ease.
SUPERIOR CALL QUALITY AND FUNCTIONALITY
The DVG-N5402FF incorporates Quality of Service (QoS), which prioritizes voice traffic to ensure that phone calls received over the Internet are the same quality or better than calls made over ordinary phone lines. The router also supports many useful functions like call transfer, caller ID display, 3-way conferencing, a phone book, speed dialing, and hotlines to make it more convenient to dial out or answer phone calls.
CREATE A HIGH-SPEED HOME NETWORK
This router has built-in DHCP and NAT functions that automatically assign IP addresses for devices on your network, allowing you to share your Internet connection with your entire home. It provides four Ethernet ports to connect your wired PCs and devices at speeds of up to 100 mbps, as well as an 802.11n wireless LAN for wireless speeds of up to 300 mbps. This means you can create a fast home network that provides ample bandwidth for seamlessly connecting multiple wired and wireless network devices.
SECURE COMMUNICATIONS
The DVG-N5402FF supports a voice VLAN feature that isolates your voice communication so it cannot be tapped over the network. Wireless transmissions are protected by WPA2/WPA/WEP wireless encryption. In addition, the router’s built-in WPS (Wi-Fi Protected Setup) technology enables you to securely add new devices to your WLAN by simply pressing a button.
Genel Özellikler
DEVICE INTERFACES
• 2 RJ-11 FXS ports (to analog phones)
• 10/100BASE-FX Fiber WAN port (SFP cage)
• 10/100BASE-TX Ethernet WAN port
• 4 10/100BASE-TX Ethernet LAN ports
• 802.11n WLAN (wireless connection to computers, etc.)
• USB 2.0 port
• WPS button
• WLAN ON/OFF switch
• Factory reset button
• Power ON/OFF switch
POWER
• Input: 100 to 240 V AC, 50/60 Hz
• Output: 12 V / 2 A
• Power consumption: 16 W
MTBF
• 50,000 hours
DIMENSIONS
• 222 x 145.7 x 33 mm w/o stand (8.74 x 5.74 x 1.3 inches)
• 226 x 145.7 x 80 mm w/ stand (8.9 x 5.74 x 3.15 inches)
WEIGHT
• 0.48 kg (1.06 lbs)
OPERATING TEMPERATURE
• -10 to 40 °C (14 to 104 °F)
STORAGE TEMPERATURE
• -20 to 60 °C (-4 to 140 °F)
OPERATING HUMIDITY
• 10 to 90% relative humidity
STORAGE HUMIDITY
• 5 to 95% relative humidity
CERTIFICATIONS
• FCC Part 15B
• CE Class B
• CE/LVD
Çözümler
Sipariş Bilgisi
DVG-N5402FF WIRELESS N VoIP ACTIVE FIBER ROUTER
