DVG-N5402GFEOL EOS
Router with 2 x FXS, 1 port WAN 10/100/1000Base-TX, 1 WAN port 1000 Mbit / s (SFP), 4-port LAN 10/100/1000Base-TX and 1 USB-port (optional)
Nereden Alınır
Tanımlama
The DVG-N5402GF VoIP wireless router links traditional telephony networks to IP networks with conventional telephony devices such as analog phones or fax machines. It can reduce long distance phone charges and deliver toll-quality voice communication over the IP network. This VoIP wireless router featuring a combo WAN interface. The combo WAN interface enable DVG-N5402GF can used for fiber and copper network. This VoIP wireless router provides two loop start Foreign Exchange Subscriber (FXS) ports and four LAN ports. And the other for connection to create a home or small office LAN networks. The built-in DHCP server/client and Network Address Translation (NAT) function automatically assign IP address for LAN users, allowing multiple users to share a single Internet connection. The DVG-N5402GF supports prioritized voice traffic for optimum Quality of Service (QoS)
Genel Özellikler
Fiziksel Özellikler
Device Interfaces
• 1 WAN port 1000 Mbit / s (SFP)
• 1 copper port 10/100/1000Base-TX
• 4-port LAN 10/100/1000 Mb / s
• 2 FXS ports
• 1 host USB 2.0 (optional)
Indicators
• Power
• Prov. / Alm
• Register
• WAN
• WLAN
• LAN 1 ~ 4
• USB (optional)
• Phone 1 ~ 2
• WPS
Voice Features
• Codecs: G.711 a / μ-law, G.723.1, G.726, G.729A / B, GSM 6.10 Full Rate, iLBC
• DTMF detection and generation
• Detection and silence suppression
• Comfort Noise Generation (CNG)
• Voice Activity Detection (VAD)
• Echo Cancellation (G.165/G.168)
• Variable (dynamic) jitter-buffer
• Call progress tone generation (FXS)
• Automatic or programmable gain control
• Built-in local frequency converter
• ITU-T V.152 Voice-band Data over IP Networks
SIP main functions
• Calls to view Peer-to-Peer
• Retention / Disarming Hold
• Call Waiting
• Selection of a call
• Parking Call / removal of a call hold (requires SIP-Server)
• Call forwarding (busy, no answer, unconditional)
• Call transfer (accompanied or unaccompanied)
• The "do not disturb"
• Speed ​​Dial
• Redial
• Three-way conference
• MWI (RFC-3842)
• Hot Line and Warm Line
Phone functions
• In-band (In-Band) DTMF, out-of-band (Out-of-Band) DTMF Relay (RFC2833 or SIP INFO)
• Support for DTMF / pulse dialing
• Detection and generation of caller ID (Caller ID): DTMF
• FSK-Bellcore Type 1 and 2
• FSK-ETSI Type 1 and 2
• FSK-NTT
• FSK: The name of the caller's number, date and time, vMWI
• FXS metering pulse:
• Detection of polarity reversal
• DTMF 12 kHz
• Tone nabor16 kHz
• Generation (FXS) POTS tone
• T.30 FAX Bypass to G.711, T.38 Real Time FAX Relay
Account Management
• Check port-based
• Register-based devices (general account)
• Mixed mode register (Hunt number for inbound calls, based on port number for outgoing calls)
• Invite with Challenge
• Registration by IP-address SIP-server or a domain name
• Support the format of RFC3986 SIP URI
Call Management
• Outbound Proxy Support
• Mechanism for SIP Registration Failover
• Group Hunting
• Privacy Mechanism / Private Extensions to SIP
• Timers Session (Update / Re-invite)
• Support for DNS SRV
• Types of calls: voice / modem / fax
• Routing of calls to the phone number prefix
• Supports user programmable dial plan
• CDR-client
• Manual Peer Table (for calls P2P)
• E.164 Numbering, support for ENUM
Wireless Interface
• Standards IEEE 802.11b/g/n
• Frequency range 2.4 GHz • 2.484 GHz
• Connection speed up to 300 Mbit / s
• Mode AP Client
• Automatic change of speed (Auto rate adaptive)
• Multi-SSID
• Office of Broadcast SSID
• 64/128 bit WEP-encryption
• WPA-PSK / WPA2-PSK
• Universal Repeater Mode
• IAPP (802.11f)
• Wi-Fi Multi-Media (WMM) mode access point
• WPS (Wi-Fi Protected Setup) for ease of installation
Network Features
• Support for IPv4, in the future • IPv6 (optional)
• WAN: Static IP, PPPoE, DHCP, PPTP
• Supports Network Protocols: IP, TCP, UDP, TFTP, FTP, RTP, RTCP, RTCP XR, ARP, RARP, ICMP, NTP, SNTP, RIP I & II, SNMP v1/v2c/v3, HTTP, HTTPS, DNS, DNS SRV, Telnet, DHCP Server, DHCP Client, STUN Client, UPnP, IGMP snooping, IGMP proxy
• Support for QoS:
WAN: DiffServ, IP Precedence, priority queues, speed control, 802.1Q (VLAN Tagging), 802.1p (Priority Tag)
The speed limit on the LAN port
• DDNS support
Network Security
• VPN PPTP client
• DIGEST authentication
• MD5 encryption
• Protection against DoS attacks
Management
• Web-based user management
• The function of «Auto-provisioning» via HTTP / HTTPS
• Telnet
• IVR
• Software update via FTP / TFTP / HTTP
• Configure backup and recovery
• Reset button to return to default settings
• TR-069/104 (optional)
• Host USB 2.0 (optional) (Support 3/3.5G and Share Port (optional))
• SIP ALG / RTSP ALG
Housing Dimensions (with stand)
• 222 x 145.7 x 33 mm or 226 x 145.7 x 80 mm
Weight
• 0.48 kg
Power
• Input: 100-240 VAC, 50/60 Hz
• Output: 12V / 2A
Power consumption
• 14 W
MTBF
• 50000 h
Temperature
• Operating: -10 to 40 C
• Storage: -20 to 60 C
Humidity
• Operating: 10 ~ 90%
• Storage: 5 ~ 95%
Electromagnetic compatibility (EMI)
• FCC part15B, CE class B
Security
• CE / LVD
Çözümler
Sipariş Bilgisi
Görseller
DVG-N5402GF
Front view
View from the right
Back view
İndir
Destek Merkezi
