DVG-N5402SPEOL EOS
Router with 2 x FXS, 1 port WAN 10/100Base-TX, 1-port PSTN (LifeLine), 4 LAN 10/100Base-TX ports and 1 USB-port (optional)
Nereden Alınır
Tanımlama
Wireless VoIP-Router DVG-N5402SP used to connect analog phones or fax machines to IP-based networks. The router reduces the cost of long distance calls, and provides high-quality voice communication in IP-based networks. DVG-N5402SP equipped with a 2-port FXS (Foreign Exchange Subscriber) and 4-port LAN. The router is designed for networking for home and small office. Integrated DHCP-server/klient and NAT (Network Address Translation) provides automatic assignment of IP-addresses for the users LAN, allowing multiple users to share access to the Internet. DVG-N5402SP supports the prioritization of voice traffic for optimum Quality of Service (QoS).
Genel Özellikler
Fiziksel Özellikler
Device Interfaces
• 1 port WAN 10/100Base-TX
• 4-port LAN 10/100Base-TX
• 1 telephone port PSTN lifeline
• 2 FXS ports
• 1 USB-host 2.0 (optional)
Indicators
• Power
• Provision
• Register
• WAN
• WLAN
• LAN 1 ~ 4
• LINE
• USB (optional)
SIP main functions
• Individual account for each port or a general account for all ports
• Identification of caller ID (Caller ID)
• Direct call IP-to-IP without SIP Proxy
• Numbering Plan (Digit Map), and phone book
• DNS SRV, SIP SRV
• Dialing E.164 (with an exclusion rule ENUM)
• Group, Pick Up
• Hot Line, Warm Line
• Setting up an interactive telephone answering (IVR)
• Message Waiting Indication (subscription)
• Visual message waiting indication (subscription)
• Music on Hold
• Outbound Proxy
• SIP INFO
• Three-way conference (Mode Ad Hoc, media server required)
• The main function calls (optional):
• Built-in Local Mixer
• Register up to three SIP-servers
  - Blocking anonymous calls
  - Lock and call filtering by IP-address of the caller
  - Call Forwarding (busy, no answer, unconditional)
  - History Call (status calls)
  - Call Hold
  - Call Interception
  - Call transfer to a fixed number (Call park) and the removal of the call off hold (Call Retrieve) (Support Proxy)
  - Call Transfer (Supports Proxy)
  - Call Waiting
  - The name of the caller and the call (FSK)
  - The "Do Not Disturb"
  - Caller ID Blocking
Voice Features
• Variable (dynamic) jitter-buffer
• Echo
• Automatic detection and switching of voice / fax / data
• Auto Gain Control (AGC)
• Codecs: G.711μ/A-law, G.729A/B/AB, G.723 (6.3/5.3 kbit / s), G.726, ILBC (13.33/15.2 kbit / s)
• Broad Voice (16 Kbit / s), G.722
• Comfort Noise Generation (CNG)
• DTMF detection and generation
• Inband or Out of Band DTMF event
• Packet Loss Concealment
• Support for voice / fax / modem (up to 33.6 kbit / s) over IP
• T.30 FAX bypass thought G.711
• T.38 real time FAX up to 14.4 kbit / s
• Voice Activity Detection (VAD)
• Detection and generation of caller ID: DTMF, FSK-BellCore, FSK-ETSI
• IGMP V1/V2/V3, Support Snooping and Proxy
Wireless Interface
• Access Point 802.11 b / g / n, Wi-Fi, support for up to 64 client associations
• Automatic selection of the wireless channel
• Supports Multi SSID (4 SSID)
• The default SSID Wireless-dlink
• Support for STA Mutual isolation
• Support for SES
• Support WDS
• Support for hidden SSID
• Support for the Prohibited List and the list of MAC-addresses
• Support for WMM
• Control wireless access based on MAC-address (deny or allow)
• Supports wireless security using encryption WEP (64/128 bit), WPA TKIP and WPA2
• Support for WPA/WPA2 TLS client
• Complies with IEEE 802.11n Draft 2.0 (2x2)
• Complies with IEEE 802.11g
• Complies with IEEE 802.11b
• Ability to send 2 HD streams over Wi-Fi
• WPS (Wi-Fi Protected Setup)
Management
• Automatic Provisioning (excl. Options TR069/TR104)
• Web-based user management
• User interface TELNET
• Save and restore the configuration file through the web-interface
• Call history (received, missed, blocked calls)
• Flat Call Detail Record output (CDR)
• Time synchronization in accordance with NTP (the default NTP-server D-Link)
• Password protection (web-interface and TELNET)
• Ping Test
• Reset to Factory
• SNMP v2 (excl. Options TR069/TR104)
• Static routes and default routes
• System status
• TFTP / FTP / HTTP-client for software upgrade
• Universal Plug and Play (UPnP) Internet Gateway Device (IGDv1.0)
• SNMP v1/v2c agent, SNMP MIBs
• Upload and download configuration file PSI
• TR-69 with TR-98, TR-104
WAN connection
• DHCP-client
• Authentication via PPPoE PAP / CHAP
• PPTP-client
• L2TP-client
• Static IP-address
• Support for USB HSDPA 3.5G modem
• USB 2.0 (optional)
QoS
• DiffServ (DSCP) or ToS IP Precedence tagging (WAN)
• Speed limit on the LAN port
• Speed limit on Port WAN (in increments of 64 Kb / s ~ 32 Mbit / s)
• Queue priority WAN port, first RTP
• 802.1Q and 802.1P tagging (VID 1 for VoIP-traffic, 4 VID for LAN-traffic)
NAT Traversal
• STUN-Client
• DDNS-client
• Specify the port range for SIP and RTP
• Static route
Security
• Built-in firewall
• Filtering of IP-addresses
• Filtering based on ports
• Filtering based on MAC-address
• Virtual server
• DMZ
• Protection against DoS attacks
• MD5 authentication for SIP
• Two privilege levels: Administrator and User
• VPN Pass-through with Multiple Sessions (IPSec, PPTP, L2TP)
Housing Dimensions (without antenna)
• 224 x 171 x 50 mm
Power
• Input: 100-240 VAC, 50/60 Hz
• Output: 12V / 2A
Power consumption
• 14 W
Temperature
• Operating: -10 to 40 C
• Storage: -20 to 60 C
Humidity
• Operating: 10 ~ 90%
• Storage: 5 ~ 95%
Electromagnetic compatibility (EMI)
• FCC class B, CE mark class B
Certificates Telecom
• FCC / PART 68
• CE / TBR21
Çözümler
Sipariş Bilgisi
Görseller
DVG-N5402SP
Front view
View from the right
Back view
İndir
Destek Merkezi
