DPH-400EDM/E/F3
Key Expansion Module for DPH-400S/SE, DPH-400S/E/F3, DPH-400SE/E/F3, DPH-150S/F3 and DPH-150SE/F3
Tanımlama
External extension DPH-400EDM is designed to connect to an IP-phone DPH-400S/SE, DPH-400S/E/F3, DPH-400SE/E/F3, DPH-150S/F3 and DPH-150SE/F3. Each module has 26 physical keys. Each button module can be programmed for a specific function, such as voice mail, call forwarding function "do not disturb", etc. Also for them to appoint a selection of lines, when you press the button is engaged in one of the SIP lines. Power supply of the DPH-400EDM can be carried out directly with the IP-phones (up to 2 modules), to which they are connected.
The use of expansion modules DPH-400EDM allows the use of IP-Phones for small businesses, call centers, where the control and management of a large number of calls
Genel Özellikler
Çözümler
Sipariş Bilgisi
Görseller
DPH-400EDM/E/F3/F3
Front view
View from the right
View from the right
View from the right
İndir
Destek Merkezi
