Hızlı Arama
Ürün Özellikleri:
IP phone with 1 WAN port 10/100/1000Base-T, 1 LAN port 10/100/1000Base-T and PoE
Tanımlama:
IP-phone DPH-400GE is designed for use in small, home offices and for
installation at the enterprises of small and average business. With its modern and stylish design,
high performance and versatility, this phone is perfect
solution for business. DPH-400GE can be used in network environments that use
connecting to the Internet via cable modem, digital subscriber line (DSL) or LAN
network (LAN). The phone can be registered with SIP server (s), the controller connection (softswitch'e),
telephone station (s), IP PBX or IMS system, as well as connect to the terminals using the SIP Protocol.
You can also connect a computer user to this phone and not to the local network
directly. The device is made in plastic housing, supplied with the phone
the handset cord to the handset and the wall-mounting kit. On the front of the phone is
LCD display, which displays various information. To configure your phone
the user can use the keyboard/LCD display or Web browser.
Ürünler | Destek  | Haberler  | Hakkında |
