DPH-400GEEOL EOS
IP phone with 1 WAN port 10/100/1000Base-T, 1 LAN port 10/100/1000Base-T and PoE
Tanımlama
	IP-phone DPH-400GE is designed for use in small, home offices and for
	installation at the enterprises of small and average business. With its modern and stylish design,
	high performance and versatility, this phone is perfect
	solution for business. DPH-400GE can be used in network environments that use
	connecting to the Internet via cable modem, digital subscriber line (DSL) or LAN
	network (LAN). The phone can be registered with SIP server (s), the controller connection (softswitch'e),
	telephone station (s), IP PBX or IMS system, as well as connect to the terminals using the SIP Protocol.
	You can also connect a computer user to this phone and not to the local network
	directly. The device is made in plastic housing, supplied with the phone
	the handset cord to the handset and the wall-mounting kit. On the front of the phone is
	LCD display, which displays various information. To configure your phone
	the user can use the keyboard/LCD display or Web browser.
Genel Özellikler
Physical parameters and operating conditions
Size  240 x 185 x 45 mm
Weight  1000 g
Food  Input: 5VDC, 1.0 A
Power consumption  Typical: 2.5 W (in standby mode)
 Max.: 2.8 W (conversation mode)
MTBF (hours)  583 598
Temperature  operating: 0 to 40 °C  Storage: -20 to 60 °C
Humidity  operating: 10% to 65% without
condensate
 Storage: 15% to 85% without
condensate
Certificates  CE Class B
