Hızlı Arama
Ürün Özellikleri:
IP Phone with 1 10/100 PoE Port
Genel Özellikler:
Fiziksel Özellikler
Interfaces • WAN Port: 10/100 BASE-T RJ-45 with PoE support for Internet connection • LAN Port: 10/100 BASE-T RJ-45 for PC • Headset : RJ9 • Handset : RJ9 LEDs • Power Display • Large dot matrix LCD display • Display Resolution: 128x48 pixels Keyboard • 4 programmable soft keys • Navigation keys • Headset • Volume adjustment (-/+) • Redial • Speaker phone • Dial phone numbers (including * and #) CPU • Broadcom SDRAM • 16 MB Flash Memory • 4 MB Power Plug • AC power plug Phone features • Vxworks OS • Support SIP2.0 (RFC3261) • SIP support 2 SIP servers, and backup SIP proxy servers • Supports SIP UDP / TCP/ TLS • SIP support SIP domain, SIP authentication (none, basic, MD5), DNS name of server, Peer to Peer / IP Call Audio Features • HD voice: HD handset • Codec: G.711A/u, G.7231 high/low, G.729AB, G.722, G.726-32 • DTMF: In-band, RFC 2833 and SIP INFO • Full duplex hands- free speaker phone with acoustic echo cancellation • Voice Activity Detection (VAD) • Comfort Noise Generation (CNG) • Background noise suppression • Adaptive jitter buffers • Packet loss concealment • SRTP • mute Advanced Features • Call forwarding (busy/no answer/always) • Call transfer (unattended/attended/semi-attended) • Call holding • Call waiting • 3 way call conference • BLF list • Join call • Call pickup • Call park • Redial • Call back • Call completion • Hot desking • Auto redial • Predial • SIP messaging, MWI • Flexible dial plan • Barring function for outgoing calls • Do not disturb • Auto answer • Caller ID display • CLIR(rejects anonymous calls) • CLIP(to make an anonymous call) • Dial without registration • Call logs with missed calls/incoming calls/outgoing calls. Each support 300 records • Phonebook: 500 records • Speed Dial (abbreviated dialing) • Hotline/Warm-line • Call rejection • Black List/ White List • Intercom • Password dial, DTMF hidden • Action URL/ active URI • Voice codec setting for each SIP line • LDAP, XML phonebook • Web dial • Keypad lock, Emergency call Network/ Security Features • Bridge mode and route • PPPoE for xDSL • 802.3af PoE • VLAN(Voice VLAN/Data VLAN) • 802.1X • NAT (NAPT) • NAT transverse :Support STUN client • DHCP client on WAN/ DHCP server on LAN • Main DNS and secondary DNS server • DNS Relay • SNTP Client • Firewall and DMZ • Web management access restricted • VPN (L2TP) • ping, Trace route, telnet Maintenance & Management • WEB, telnet and LCD menu management • Management with different account right • Recover firmware and factory reset • Upgrade firmware via HTTP, HTTPS, FTP, TFTP • DHCP option66 and custom option for auto provisioning • Auto Provisioning to upgrade configuration file with AES encryption • TR-069 and Syslog Physical Parameters Dimensions • 250 x 205 x 60 mm Weight • 0.84kg Power Supply • DC 5 V/600 mA, power adapter • Ethernet cable (PoE) 802.3af Power consumption: • IDLE: 2.5W • Active: 2.8W Operation Temperature: • 0 to 40°C Relative Humidity: • 10% to 65% Certification • FCC • CCC • CE • RoHS Fiziksel Özellikler
Ürünler | Destek  | Haberler  | Hakkında |
