Hızlı Arama
Ürün Özellikleri:
Broadband Videophone
EOL EOS
Tanımlama:
The D-Link DVC- 1000 i2eyeTM VideoPhone introduces the world of video conferencing over the Internet, to bring you and your family, friends and colleagues together. Since the DVC-1000 i2Eye VideoPhone is a stand-alone device, you do not need a computer to video conference over the Internet.
The previously complicated process of conducting a video conference is simplified with the DVC-1000. Connect a standard telephone and a television to the DVC-1000, plug in a standard Ethernet network cable connected to your broadband Internet connection and you are ready to conduct real-time videoconferencing.
Using advanced video compression technology, the DVC-1000 VideoPhone maximizes the image and audio quality within the available bandwidth. The DVC-1000 can send and receive video at up to a full 30 frames per second. It is an ideal solution for consumers and small businesses with high-speed Internet access.
Easy to use set-up wizards guide you step-by-step through the set-up of the DVC-1000 VideoPhone. You can be up and working in minutes. With the DVC-1000 it is easy to make changes to personalize your videoconferencing display.
The remote control that is included with the DVC-1000 allows you to easily answer an incoming videophone call or initiate a new one. The built-in caller ID provides privacy protection. You can know who is calling before you answer.
Be there real-time, anytime. You won't miss a moment with your friends, family and colleagues with the i2eye DVC-1000 VideoPhone.
* Patent Pending
Ürünler | Destek  | Haberler  | Hakkında |
