DIR-640L
Broadband wireless router VPN-Cloud, and 300 Mbit / s
Nereden Alınır
Tanımlama
Wireless VPN-Router DIR-640L, which combines the functions of a router, switch, 10/100, 802.11n wireless access point and firewall designed for networking sector SOHO, requiring maximum performance and security. In the small business environment increases the demand for construction of networks, and thus enterprises are interested in the device, providing protection for the network. Purchase of Wireless VPN-Router DIR-640L is a profitable investment, as the device supports security features, easy configuration mechanisms and provides maximum protection for the network of small offices and homes.
User-friendly interface
DIR-640L offers a user-friendly intuitive Web-based interface for configuration. Manage settings available to the user as an administrator or with the rights of Read / Write. Thanks to the data access privileges, any authorized user can configure or access the management interface DIR-640L.
The service mydlink network management
Broadband VPN-router supports Cloud service mydlink Cloud, which allows the user to access the network, regardless of its location. With a computer connected to the Internet or a mobile device equipped with iOS or Android, you can use the view of clients connected to the router, change settings, or block access to the individual clients. Home users can check the most frequently visited Internet sites their children, and for the offices the ability to monitor network activity of workers.
Enterprise-class protection
DIR-640L performs the secure transmission of data over wireless networks using encryption WPA ™ or WPA2 ™. In addition, the protection of the network from intruders and potential attacks by using a firewall that uses the mechanisms of Network Address Translation (NAT) and Stateful Packet Inspection (SPI).
Advanced hardware features
DIR-640L can be connected to a cable or DSL-modem for high-speed public Internet access. Also, the device is equipped with a 4-port 10/100 Mbit / s, which supports full duplex mode, allowing you to connect up to 4 devices with interfaces Ethernet. To extend a wired network, you need to simply add additional switches. In addition, using DIR-640L, you can create a virtual private network (VPN) and provide secure remote access to a central network through the Internet for 25 simultaneous users.
VPN Performance
For optimal VPN configuration, the router DIR-640L is equipped with a built-in VPN-client and the VPN-server, allowing you to maintain most of the required policies VPN. In this device, VPN support is implemented in hardware and manage up to 25 profiles, VPN. DIR-640L supports protocols IPSec, PPTP, L2TP and GRE in server mode, and allows you to handle the traffic pass-through. Advanced VPN configuration options include encryption with DES, the key management IKE / ISAKMP, negotiation mode Main / Aggressive and authentication support VPN, using a database of 10 internal users.
Genel Özellikler
Fiziksel Özellikler
Standards
• IEEE 802.11 b / g / n
• IEEE 802.3
• IEEE 802.3u
Ports
• 4-port LAN 10/100 Mbit / s
• WAN port 10/100 Mbit / s
• USB 2.0 port
• COM-port RS-232
• Slot for Kensington lock
Indicators
• Power / Status
• WAN
• WLAN
• LAN 1/2/3/4
The output power of the transmitter
• IEEE 802.11b
  17dBm at 1,2,5.5,11 Mbit / s
• IEEE 802.11g
  14dBm at 54, 48 Mbit / s
  15dBm at 36, 24 Mbit / s
  16dBm at 18, 12 Mbit / s
  17dBm at 9, 6 Mbit / s
• IEEE 802.11n
  2.4 GHz Band/HT-20:
  + 16dBm at MCS0, 1
  + 15dBm at MCS2, 3
  + 14dBm at MCS4, 5
  + 13dBm at MCS6, 7
  2.4 GHz Band/HT-40:
  + 16dBm at MCS0, 1
  + 15dBm at MCS2, 3
  + 14dBm at MCS4, 5
  + 13dBm at MCS6, 7
Device control
Internet Explorer 6 or later, or other Java-enabled browser
Modes of Operation Firewall
• The Level 3: NAT mode
• Port Forwarding
• Port Address Translation (PAT)
VPN Security
• VPN-tunnels: 25 (IPSec, PPTP, L2TP, GRE)
• IPSec LAN-to-LAN / Remote user
• IPSec/PPTP/L2TP Pass-through
• Client / server PPTP/L2TP
• IPSec NAT-Traversal
• XAUTH (Extended Authentication) for IPSec Authentication
• Encryption: DES
Secure Firewall
• Database of internal users (10 entries)
Network Services
• Static IP-address
• DHCP-client for WAN-interface
• Internal DHCP-server
• Static Routes
• Convert DNS-name the remote gateway IP-address
• PPPoE for xDSL
• Russian PPPoE / PPTP (Dual Access)
• Quality of Service
• Dynamic DNS
Functions mydlink
• Remote control
• View the current bandwidth for outgoing / incoming traffic
• Show clients connected to the current moment
• Displays your browsing history for each customer
• Lock / Unlock access to the client
• Detailed information on monitoring wireless network
• Access through a Web-browser or mobile app iOS or Android
Fiziksel Özellikler
Measurements
111,8 x 188 x 28 mm
Weight
422 g
Nutrition
12 Vdc, 1 A
Temperature
Operating: 0 to 55 C
Humidity
Operating: 95% maximum (non-condensing)
Certifications
• FCC Class B
• CE
• UL
• Wi-Fi
Çözümler
Sipariş Bilgisi
Görseller
DIR-640LA1
Left side view
Front view
Back view
DIR-640L без Wi-Fi-модуля
Front view
İndir
Destek Merkezi
