DIR-825/A/D1AEOL EOS
Wireless Dual-Band N600 Router with Gigabit Ethernet ports
Nereden Alınır
Tanımlama
Wireless Interface
Using a wireless router DIR-825, you can quickly create a high-speed wireless network at home or in the office, providing Internet access to computers and mobile devices almost anywhere (within range of a wireless network). Simultaneous operation in the 2.4 GHz and 5 GHz wireless network allows for a wide range of tasks. The Router can serve as a base station for a wireless network device of the standards 802.11a, 802.11b, 802.11g and 802.11n (at speeds up to 600 Mb / s *).
In the router supports multiple functions for the wireless interface. The device supports several security standards (WEP, WPA/WPA2), filtration devices to be connected by MAC-address, and allows the use of the WPS, WMM.
Built-in antennas Airgain
The router is equipped with a built-in omni-directional antennas AirGain. Despite its compact size, these antennas are not only not inferior in performance to traditional pin, but in many ways superior to them. With a high gain (4 dBi for the 2.4 GHz, 6 dBi for 5 GHz) and the circular radiation pattern in the horizontal and vertical planes, antenna AirGain work equally well in either direction, provide enhanced wireless coverage and reduce the likelihood of "dead" zones.
USB-port
The router is equipped with a USB-port for connection of USB-modem with which you can quickly connect to the Internet. In addition, you can connect to USB-port router, USB-drive, which will be used as a network drive, or a printer.
Safety
Wireless Router DIR-825 is equipped with a built-in firewall. Advanced security features minimize threats of hackers and prevent intrusions to your network.
Configuration and Management
To manage and configure your wireless router DIR-825 uses a simple and user-friendly web-based interface (available in several languages).
* Up to 300 Mbit / s in the 2.4 GHz and up to 300 Mbit / s in the 5 GHz band
Genel Özellikler
Fiziksel Özellikler
Hardware
Interfaces
• WAN: 1 10/100/1000BASE-TX Ethernet port for cable or DSL-modem or a dedicated Ethernet-line
• LAN: 4 ports 10/100/1000BASE-TX Ethernet
• WLAN:
  IEEE 802.11n (600 Mbit / s *)
  IEEE 802.11a/b/g
The USB interface
USB 2.0 type A to connect the USB-modem, printer or storage device
Frequency band
• 802.11a: 5725 ~ 5850 MHz ISM band
• 802.11b: 2400 ~ 2483.5 MHz ISM band
• 802.11g: 2400 ~ 2483.5 MHz ISM band
• 802.11n:
  ◦ 2400 ~ 2483.5 MHz ISM band
  ◦ 5725 ~ 5850 MHz ISM band
Wireless speed
• 802.11a: 54, 48, 36, 24, 18, 12, 9 and 6 Mbit / s
• 802.11b: 11, 5.5, 2 and 1 Mbit / c
• 802.11g: 54, 48, 36, 24, 18, 12, 9 and 6 Mbit / s
• 802.11n:
  2.4 GHz: MCS0 ~ MCS15 (up to 300 Mbit / s)
  5 GHz: MCS0 ~ MCS15 (up to 300 Mbit / s)
Modulation Schemes
• 802.11a: BPSK, QPSK, 16QAM, 64QAM with OFDM
• 802.11g: BPSK, QPSK, 16QAM, 64QAM with OFDM
• 802.11n: BPSK, QPSK, 16QAM, 64QAM with OFDM
Receiver Sensitivity
• 802.11a (typical at PER = 10% for a packet size of 1000 bytes at room temperature 25 ° C)
  -65 DBm at 54 Mbps / c
• 802.11b (typical at PER = 8% for the packet size of 1000 bytes at room temperature 25 ° C)
  -82 DBm at 1 Mbit / s
  -78 DBm at 5.5 Mbit / s
  -76 DBm at 11 Mbit / s
• 802.11g (typical at PER = 10% for a packet size of 1000 bytes at room temperature 25 ° C)
  -82 DBm at 6 Mbit / c
  -81 DBm at 9 Mbit / c
  -79 DBm at 12 Mbps / c
  -77 DBm at 18 Mbps / c
  -74 DBm at 24 Mbps / c
  -70 DBm at 36 Mbps / c
  -66 DBm at 48 Mbps / c
• 802.11n (typical at PER = 10% for a packet size of 1000 bytes)
  HT20
  -82 DBm at MCS0 / 8
  -79 DBm @ MCS1 / 9
  -77 DBm at MCS2/10
  -74 DBm at MCS3/11
  -70 DBm at MCS4/12
  -66 DBm at MCS5/13
  -65 DBm at MCS6/14
  -64 DBm at MCS7/15
  HT40
  -79 DBm at MCS0 / 8
  -76 DBm @ MCS1 / 9
  -74 DBm at MCS2/10
  -71 DBm at MCS3/11
  -67 DBm at MCS4/12
  -63 DBm at MCS5/13
  -62 DBm at MCS6/14
  -61 DBm at MCS7/15
The output power of the transmitter
• 802.11a (typically at ambient temperature of 25 ° C)
  12.5 dBm (+ / -1.5 dB)
• 802.11b (typical at room temperature 25 ° C)
  17 dBm (+ / -1.5 dB)
• 802.11g (typical at room temperature 25 ° C)
  14.5 dBm (+ / -1.5 dB)
• 802.11n (typical at room temperature 25 ° C)
  HT20
  14 dBm (+ / -1.5 dB) at MCS6 / 7 (2.4 GHz)
  11.5 dBm (+ / -1.5 dB) at MCS6 / 7 (5 GHz)
  HT40
Software
Network Features
• The types of WAN-connection:
 ◦ LTE
 ◦ 3G
 ◦ PPPoE
 ◦ Static IP
 ◦ Dynamic IP
 ◦ PPTP/L2TP
 ◦ PPTP/L2TP + Static IP
 ◦ PPTP/L2TP + Dynamic IP
• DHCP-server and DHCP-Client
• DNS relay
• Skip VPN-tunnel (PPTP/L2TP)
• Dynamic DNS
• Static IP-routing
• Remote Access
• Network statistics for each interface
• IGMP Proxy
• RIP
• UPnP
• VLAN support
• Flow control (flow control)
• TR-069 Client
• Supports ping from the external network (WAN ping respond)
USB-modem
• Automatically connect to an available type of supported network (4G/3G/2G)
• Turn on / off check PIN-code, PIN-code change **
USB-drive
• Access via SMB
• Built-in FTP-server
• Print Server
• Accounts for access to storage
Wireless connection
• Supports security standards:
 ◦ WEP
 ◦ WPA/WPA2 Personal
 ◦ WPA/WPA2 Enterprise
• MAC-filter
• Control of the connected devices
• Methods and PIN WPS PBC function
• The WMM (Wi-Fi QoS)
• Advanced Settings
• Supports the "client"
Torrent-client
The ability to download files to a USB-drive and with it
Firewall Security
• IP-filters
• MAC-filter
• URL-Filter
• DMZ-zone
• The Prevention of ARP-and DDoS-attacks
• Virtual Servers
• Web-based interface for configuration and management of multiple languages
• Access via TELNET
• Upgrade the firmware of the router through the web-interface
• Save and load configuration
• Support for remote logging
• Automatic synchronization of system time with a NTP-server and manually set the date and time
• The ping
• The traceroute utility
Supported USB-modems ***
• GSM-modems
 ◦ D-Link DWM-152
 ◦ D-Link DWM-156
 ◦ Huawei E1550
 ◦ Huawei E160G
 ◦ Huawei E169G
 ◦ Huawei E171
 ◦ Huawei E220
 ◦ ZTE MF112
 ◦ ZTE MF192
 ◦ ZTE MF626
 ◦ ZTE MF627
 ◦ ZTE MF652
 ◦ ZTE MF668
 ◦ ZTE MF752
• CDMA-modem
 ◦ Airplus MCD-650
 ◦ Airplus MCD-800
 ◦ AnyDATA ADU-300A
 ◦ AnyDATA ADU-500A
 ◦ AnyDATA ADU-510A
 ◦ ZTE AC5710
 ◦ ZTE AC5730
• LTE-modems
 ◦ Huawei E392
 ◦ Yota LU150
• WiMAX-modem
 ◦ Samsung SWC-U200 (software version: u200_rev1-2.7.40-CI14)
Fiziksel Özellikler
Indicators
• Power
• WPS
• INTERNET
• 2.4GHz
• 5GHz
• 4 LEDs LAN
• USB
Nutrition
• Power supply: External Power Supply DC 12V / 1.2A
• Power on / off
• The RESET button to restore factory default settings
• WPS Button
Operating temperature
From 0 to 40 C
Storage temperature
-20 To 65 ° C
Operating humidity
From 10% to 90% non-condensing
Storage humidity
From 5% to 95% non-condensing
** Only for GSM USB-modems.
*** The manufacturer does not guarantee the operation of the router with every modification of the USB-modems.
Çözümler
Sipariş Bilgisi
Görseller
DIR-825/A/D1A/D1
Back view
View from the right
Front view
İndir
Destek Merkezi
