DSL-2650U/RA/U1AEOL EOS
Wireless modem/router ADSL2+ 802.11n Desteği (150 Mbit/s) ve USB-port
Nereden Alınır
Tanımlama
USB-port
The router is equipped with USB-port for connecting a USB-modem with which you can quickly connect to the Internet. In addition, you can connect to the USB-port on the router USB-drive, which will be used as a network drive, or a printer.
ADSL-port and 4-port switch, Ethernet WAN support
ADSL-router has a port for connecting to ADSL-line. Built-in 4-port switch allows you to connect computers equipped with Ethernet-adapters, game consoles and other devices to your network. In addition, any Ethernet-port devices can be used to connect to a dedicated Ethernet-line.
Security
Wireless Router DSL-2650U has a built-in firewall. Enhanced security functions minimize threats of hackers and prevent intrusions to your network and access to unwanted websites for users on your local network.
Wireless Interface
You can quickly create a wireless network at home or in the office, which will allow your employees or members of your family to connect to a wireless network almost anywhere (within range of a wireless network.) The Router can serve as an access point to connect to the wireless network devices of the standards 802.11b, 802.11g and 802.11n. The device supports several security standards (WEP, WPA/WPA2), filtering devices to be connected to MAC-address, and allows the use of technology WPS. In addition, the device is equipped with a button to disable / enable the Wi-Fi-network. In case of need, such as leaving home, you can turn off the router's wireless network at the touch of a button, while the devices connected to the LAN-ports on the router will remain in the network.
Easy setup and update
To configure a wireless router DSL-2650U uses a simple and user-friendly web-interface (available in several languages). Now you can easily upgrade the firmware - the router itself is a proven version of the software update server D-Link, and notifies the user ready to install it.
Genel Özellikler
Fiziksel Özellikler
Hardware
Interfaces
• ADSL: 1 port with an RJ-11
• LAN: 4-port 10/100BASE-TX Ethernet with RJ-45 auto-sensing polarity MDI / MDIX
• WLAN: built-in wireless interface standard 802.11b, g and n
• USB: USB 2.0 type A
Frequency band
2412 ~ 2484 MHz
Data transfer rate
• 802.11b: 11, 5.5, 2, 1 Mbit / c
• 802.11g: 54, 48, 36, 24, 18, 12, 9, 6 Mbit / s
• 802.11n
  ◦ HT20: 150, 130, 117, 104, 78, 52, 39, 26, 13 Mbit / s
  ◦ HT40: 150, 130, 117, 104, 78, 52, 39, 26, 13 Mbit / c
Transmitter output power
The maximum value of the transmitter power will vary in accordance with the rules of the radio-frequency regulation in your country
• 802.11b: 16,5 ~ 18,5 dBm
• 802.11g: 13,5 ~ 16,5 dBm
• 802.11n: 13,5 ~ 16,5 dBm
Modulation Schemes
• 802.11b: CCK (11, 5.5 Mbit / c), DQPSK (2 Mbit / c), DBPSK (1 Mbit / c), DSSS
• 802.11g: PSK / CCK, DBPSK, DQPSK, OFDM, BPSK, QPSK 16QAM, 64QAM
• 802.11n: PSK / CCK, DBPSK, DQPSK, OFDM, etc.
ADSL Standards
• ADSL: Multi-mode, ANSI T1.413 Issue 2, ITU-T G.992.1 (G.dmt) Annex A, ITU-T G.992.2 (G.lite) Annex A, ITU T G.994.1 (G. hs)
• ADSL2: ITU-T G.992.3 (G.dmt.bis) Annex A / L / M, ITU-T G.992.4 (G.lite.bis) Annex A
• ADSL2 +: ITU-T G.992.5 Annex A / L / M
Software
Types of WAN-connection
• 3G
• ADSL
  ◦ PPPoE
  ◦ PPPoA
  ◦ IPoA
  ◦ Static IP
  ◦ Dynamic IP
  ◦ Bridge
• Ethernet
  ◦ PPPoE
  ◦ Static IP
  ◦ Dynamic IP
  ◦ Bridge
Wireless network
• Standard IEEE 802.11n, device compatibility standard IEEE 802.11b / g
• WEP-encryption
• WPA/WPA2 encryption technology mechanisms TKIP, AES and TKIP + AES
• Access to a wireless network based on the MAC-address
• The PBC method of WPS
• Management of the connected devices
• Advanced Settings
Protocols ATM / PPP
• Ethernet encapsulation bridging and routing
• Multiplexing based VC / LLC
• ATM Forum UNI3.1/4.0 PVC (up to 8 PVC)
• ATM Adaptation Layer Type 5 (AAL5)
• Principles and functions OAM ITU-T I.610, including F4/F5 loopback
• ATM QoS
• PPP over ATM (RFC 2,364)
• PPP over Ethernet (PPPoE)
• Support for Keep-alive for PPP-protocol
Network Protocols and Features
• DHCP-server/klient/relay
• DNS relay
• Dynamic DNS
• Static IP-routing
• Remote access
• Network statistics for each interface
• IGMP proxy
• IGMP snooping
• RIP
• UPnP
• VLAN support
• Supports ping co side external network (WAN ping respond)
• Support for SIP
• Support for RTSP
Firewall and Access Control
• IP-filters
• MAC-filter
• URL-Filter
• DMZ-zone
• The protection and ARP-DDoS-attacks
• Virtual servers
QoS
• Grouping interfaces
• Priority VLAN (802.1p)
USB-modem *
• Automatically connect to an available type of supported network (3G/2G)
• Enable / disable PIN-code verification, change PIN-code
USB-drive
• File Browser
• Print Server
• Access via SMB from accounts
• Built-in FTP-server
• Built-in DLNA-server
Torrent-client
• Built client Transmission
• Ability to download files on the USB-drive and with it
Configuration and Management
• Web-based interface for configuration and management of multiple languages
• Access via TELNET
• Upgrade the firmware of the router through the web-interface
• Automatic notification when a new software version
• Save and load configuration
• Support for remote logging
• Automatic synchronization of system time with a NTP-server and manually configure the date and time
• The Ping
Supported USB-modems **
• GSM-modems
  ◦ Alcatel X500
  ◦ D-Link DWM-152C1
  ◦ D-Link DWM-156C1
  ◦ Huawei E150
  ◦ Huawei E1550
  ◦ Huawei E156G
  ◦ Huawei E160G
  ◦ Huawei E169G
  ◦ Huawei E171
  ◦ Huawei E173 (Megafon)
  ◦ Huawei E220
  ◦ Huawei E352 (Megafon)
  ◦ Huawei E392 (3G-mode)
  ◦ ZTE MF112
  ◦ ZTE MF192
  ◦ ZTE MF626
  ◦ ZTE MF627
  ◦ ZTE MF652
  ◦ ZTE MF668
  ◦ ZTE MF752
• CDMA-modems
  ◦ Airplus MCD-650
  ◦ Airplus MCD-800
  ◦ AnyDATA ADU-300A
  ◦ AnyDATA ADU-500A
  ◦ AnyDATA ADU-510A
  ◦ Huawei EC306
  ◦ ZTE AC5710
  ◦ ZTE AC5730
Fiziksel Özellikler
Indicators
• POWER
• DSL
• INTERNET
• WLAN
• LAN 1-4
• WPS
• USB
Power
External Power Adapter DC 12V/1A
Buttons
• The Power Switch ON / OFF
• The RESET button to return to the factory defaults
• The button to turn on the wireless network and use the WPS function
Operating temperature
From 0 to 40 ° C
Storage temperature
-20 To 70 ° C
Humidity
From 5% to 95% non-condensing
* Options available only for GSM USB-modems.
** The manufacturer does not guarantee proper operation of the router with every modification of the USB-modems.
Çözümler
Sipariş Bilgisi
Görseller
DSL-2650U/RA/U1A
View from the right
Back view
Front view
Front view
İndir
Destek Merkezi
