DIR-890LEOL EOS
AC3200 Wi-Fi Ultra Router
Tanımlama
	Super-Charged with Smarter Wireless AC Features
	Create a blazing fast home network that connects all of your computers and mobile devices to your broadband Internet connection. The newly introduced SmartConnect1 technology ensures that older wireless devices do not degrade the overall performance of the DIR-890L and allows wireless AC devices to have a total throughput of 3200 Mbps. The Advanced AC SmartBeam technology that is also in the DIR-890L brings you the future of high-bandwidth wireless connectivity, vastly increasing the speed and coverage of your network.
	Use mydlink to Monitor Your Network
	The AC3200 Ultra Wi-Fi Router is mydlink Cloud enabled, so you can effortlessly access and view your network no matter where you are. See who is connected to your router, change settings, or block someone from using your network connection, all from an Internet connected PC, tablet, or smartphone. Parents can monitor what sites their children are visiting, to stay informed and in control on the go.
	File Sharing at Your Fingertips
	The mydlink SharePort app allows you to connect a USB storage device to the DIR-890L and instantly share documents, movies, pictures, and music with mobile devices. Put your music library on a USB drive and share it with everyone else in your home, or show photos on the living room TV while a family member watches a movie on their mobile device.
	Easy to Set Up and Use
	Get the DIR-890L up and running in no time right from your couch using the QRS (Quick Router Setup) Mobile app on your smartphone or tablet. Simply plug in the router, open the app, and follow a few easy steps to get your home network connected without having to touch a computer. You can also set up a secure network with the touch of a button using Wi-Fi Protected Setup.
Genel Özellikler
	General
	Device Interfaces
	• 802.11 a/b/g/n/ac wireless LAN
	• Four 10/100/1000 Gigabit LAN ports
	• One 10/100/1000 Gigabit WAN port
	• Two USB ports (one USB 3.0, one USB 2.0)
	Standards
	• IEEE 802.11ac
	• IEEE 802.11n
	• IEEE 802.11g
	• IEEE 802.11b
	• IEEE 802.11a
	• IEEE 802.3
	• IEEE 802.3u
	Minimum System Requirements
	• Windows 8/7/Vista, Mac OS X 10.6 or higher
	• Microsoft Internet Explorer 9 or higher, Firefox 12 or higher, or other Java-enabled browser
	• Ethernet network interface
	• Cable or DSL modem
	• Subscription with an Internet service provider
	Data Rate
	• 802.11a
	  • 6,9,12,18,24,36,48,54Mbps
	• 802.11b
	  • 11, 5.5, 2, and 1Mbps
	• 802.11g
	• 802.11n (5GHz)
	  • From MCS – 0 to MCS –23
	• 802.11n (2.4GHz)
	• IEEE 802.11ac (5GHz)
	  • 6.5~1333 Mbps
	Receiver Sensitivity
	• 802.11a (Typical sensitivity at which frame (1000-byte PDUs) error rate < 10% at room temperature 25 degree C)
	  –82dBm at 6Mbps
	  –81dBm at 9Mbps
	  –79dBm at 12Mbps
	  –77dBm at 18Mbps
	  –74dBm at 24Mbps
	  –70dBm at 36Mbps
	  –66dBm at 48Mbps
	  –65dBm at 54Mbps
	• 802.11b (Typical sensitivity at each RF chain. Frame (1000-byte PDUs) Error Rate = 8%)
	  –80dBm at 1Mbps
	  –80dBm at 2Mbps
	  –80dBm at 5.5Mbps
	  –76dBm for 11Mbps
	• 802.11g (Typical sensitivity at each RF chain. Frame (1000-byte PDUs) Error Rate <10%)
	  -82dBm at 6Mbps
	  -81dBm at 9Mbps
	  -79dBm at 12Mbps
	  -77dBm at 18Mbps
	  -74dBm at 24Mbps
	  -70dBm at 36Mbps
	  -66dBm at 48Mbps
	  -65dBm at 54Mbps
	• 802.11n (5GHZ) (Typical sensitivity at which frame (1000-byte PDUs) error rate = 10% and at room temperature 25degree C)
	  HT20
	  –82dBm at MCS0/8
	  –79dBm at MCS1/9
	  –77dBm at MCS2/10
	  –74dBm at MCS3/11
	  –70dBm at MCS4/12
	  –66dBm at MCS5/13
	  –65dBm at MCS6/14
	  –64dBm at MCS7/15
	  HT40
	  –79dBm at MCS0/8
	  –76dBm at MCS1/9
	  –74dBm at MCS2/10
	  –71dBm at MCS3/11
	  –67dBm at MCS4/12
	  –63dBm at MCS5/13
	  –62dBm at MCS6/14
	  –61dBm at MCS7/15
	  HT20
	  -82 dBm at MCS 0/8
	  -79 dBm at MCS 1/9
	  -77 dBm at MCS 2/10
	  -74 dBm at MCS 3/11
	  -70 dBm at MCS 4/12
	  -66 dBm at MCS 5/13
	  -65 dBm at MCS 6/14
	  -64 dBm at MCS 7/15
	  HT-40
	  -79 dBm at MCS 0/8
	  -76dBm at MCS 1/9
	  -74 dBm at MCS 2/10
	  -71 dBm at MCS 3/11
	  -67 dBm at MCS 4/12
	  -63 dBm at MCS 5/13
	  -62 dBm at MCS 6/14
	  -61dBm at MCS 7/15
	• 802.11ac (5GHz) (Typical sensitivity at which frame (1000-byte PDUs) error rate = 10% and at room temperature 25degree C)
	  VHT-20
	  –82dBm at MCS0
	  –79dBm at MCS1
	  –77dBm at MCS2
	  –74dBm at MCS3
	  –70dBm at MCS4
	  –66dBm at MCS5
	  –65dBm at MCS6
	  –64dBm at MCS7
	  –59dBm at MCS8
	  VHT-40
	  –79dBm at MCS0
	  –76dBm at MCS1
	  –74dBm at MCS2
	  –71dBm at MCS3
	  –67dBm at MCS4
	  –63dBm at MCS5
	  –62dBm at MCS6
	  –61dBm at MCS7
	  –56dBm at MCS8
	  –54dBm at MCS9
	  VHT-80
	  –76dBm at MCS0
	  –73dBm at MCS1
	  –71dBm at MCS2
	  –68dBm at MCS3
	  –64dBm at MCS4
	  –60dBm at MCS5
	  –59dBm at MCS6
	  –58dBm at MCS7
	  –53dBm at MCS8
	  –51dBm at MCS9
	Transmitter Output Power
	• 802.11a (Typical average RF Output Power at each Data Rate at room temperature (+/- 2dB Tolerance)
	  Band 1&2
	  • 15dBm for 54Mbps
	  • 16dBm for 48Mbps
	  • 17dBm for 36Mbps
	  • 18dBm for 24Mbps
	  • 18dBm for 18Mbps
	  • 18dBm for 12Mbps
	  • 18dBm for 9Mbps
	  • 18dBm for 6Mbps
	  Band 3&4
	  • 20dBm for 54Mbps
	  • 21dBm for 48Mbps
	  • 22dBm for 36Mbps
	  • 23dBm for 24Mbps
	  • 23dBm for 18Mbps
	  • 23dBm for 12Mbps
	  • 23dBm for 9Mbps
	  • 23dBm for 6Mbps
	• 802.11b (Typical RF Output Power at each RF chain, Data Rate and at room temperature 25degree C (tolerance ± 2dB))
	  • 23dBm
	• 802.11g (Typical RF Output Power at each RF chain, Data Rate and at room temperature 25degree C (tolerance ± 2dB))
	  • 20dBm for 54Mbps
	  • 21dBm for 48Mbps
	  • 22dBm for 36Mbps
	  • 23dBm for 24Mbps
	  • 23dBm for 18Mbps
	  • 23dBm for 12Mbps
	  • 23dBm for 9Mbps
	  • 23dBm for 6Mbps
	• 802.11n (5GHz) (Typical RF Output Power at each RF chain, Data Rate and at room temperature 25degree C (tolerance +/-2dB))
	  Band 1 & 2
	  HT20
	  • 15dBm for MCS7
	  • 16dBm for MCS6
	  • 17dBm for MCS5
	  • 17dBm for MCS4
	  • 17dBm for MCS3
	  • 17dBm for MCS2
	  • 17dBm for MCS1
	  • 17dBm for MCS0
	  HT40
	  • 15dBm for MCS7
	  • 16dBm for MCS6
	  • 17dBm for MCS5
	  • 17dBm for MCS4
	  • 17dBm for MCS3
	  • 17dBm for MCS2
	  • 17dBm for MCS1
	  • 17dBm for MCS0
	  Band 3 & 4
	  HT20
	  • 19dBm for MCS7
	  • 20dBm for MCS6
	  • 21dBm for MCS5
	  • 22dBm for MCS4
	  • 22dBm for MCS3
	  • 22dBm for MCS2
	  • 22dBm for MCS1
	  • 22dBm for MCS0
	  HT40
	  • 19dBm for MCS7
	  • 20dBm for MCS6
	  • 21dBm for MCS5
	  • 22dBm for MCS4
	  • 22dBm for MCS3
	  • 22dBm for MCS2
	  • 22dBm for MCS1
	  • 22dBm for MCS0
	• 802.11n (2.4GHz)(Typical RF Output Power at each RF chain, Data Rate and at room temperature 25degree C (tolerance +/-2dB))
	  HT-20
	  • 18dBm for MCS9
	  • 18dBm for MCS8
	  • 19dBm for MCS7
	  • 20dBm for MCS6
	  • 21dBm for MCS5
	  • 22dBm for MCS4
	  • 22dBm for MCS3
	  • 22dBm for MCS2
	  • 22dBm for MCS1
	  • 22dBm for MCS0
	  HT-40
	  • 18dBm for MCS9
	  • 18dBm for MCS8
	  • 19dBm for MCS7
	  • 20dBm for MCS6
	  • 21dBm for MCS5
	  • 22dBm for MCS4
	  • 22dBm for MCS3
	  • 22dBm for MCS2
	  • 22dBm for MCS1
	  • 22dBm for MCS0
	Functionality
	Advanced Features
	• SmartConnect1
	• Guest zone
	• mydlink SharePort™ web access
	• Multi-language web setup wizard
	• DLNA media server support
	• Advanced AC SmartBeam
	• Dual active firewall
	• VPN Passthrough (PPTP/L2TP/IPsec)
	• Advanced QoS
	• QuickVPN - L2TP over IPsec
	mydlink Features
	• Remote Management
	• View current upload/download bandwidth
	• View currently connected clients
	• View web browsing history per client
	• Block/unblock client network access
	• Manage wireless network details
	• Accessible through a web browser or iOS or Android mobile app
	Mobile App Support
	• mydlink Lite
	• mydlink SharePort
	• QRS Mobile v1.5
	Wireless Security
	• WPA & WPA2 (Wi-Fi Protected Access)
	• Wi-Fi Protected Setup (WPS) PIN/PBC
	Physical
	Dimensions (L x W x D)
	• 387 x 247.3 x 119.5mm (15.23 x 9.73 x 4.7 inches)
	Weight
	• 1.00 kg (2.20 lbs)
	Power
	• Input: 100 to 240 V AC, 50/60 Hz
	• Output: 12 V DC, 5 A
	Temperature
	• Operating: 0 to 40 °C (32 to 104 °F)
	• Storage: -20 to 65 °C (-4 to 149 °F)
	Humidity
	• Operating: 0% to 90% non-condensing
	• Storage: 5% to 95% non-condensing
	Certifications
	• Wi-Fi Certified
	• Wi-Fi Multimedia (WMM)
	• IPv6 Ready
	• Compatible with Windows 8
	* Smart Connect currently operates on the 5 GHz radio bands. Operation the 5 GHz and 2.4 GHz will be included in firmware version 1.02 and higher.
Çözümler
Sipariş Bilgisi
DIR-890L AC3200 Wi-Fi Ultra Router
