Hızlı Arama
Ürün Özellikleri:
Wireless N300 router with 3G/CDMA/LTE and USB port
Tanımlama:
USB port The router includes a USB port for connecting a USB modem, with which You can quickly connect to the Internet. In addition, You can connect to the USB port on the router USB drive that will be used as a network drive, or printer. Wireless interface Using a wireless router DIR-620, You can quickly create a wireless network at home or in the office that will allow Your employees or members of Your family to connect to your wireless network virtually anywhere (within range of your wireless network). The router can operate as a base station for connecting wireless devices of the standards 802.11 b, 802.11 g, and 802.11 n (at speeds up to 300 Mbps). The router supports multiple functions for the wireless interface. The device supports several security standards (WEP, WPA/WPA2), filtering of connected devices by MAC address, and allows you to use technology WPS and WMM. In addition, the device is equipped with a button to disable/enable the Wi-Fi network. If necessary, for example, leaving home, You can turn off the router's wireless network just one press on the button, devices connected to LAN ports of the router will remain in the network.1 4-port switch Built-in 4-port switch allows you to connect computers equipped with Ethernet adapters, game consoles, and other devices to Your network. Safety Wireless router DIR-620 is equipped with a built-in firewall. Advanced security functions minimize threats of hacker attacks, prevent unwanted intrusions to Your network, and block access to unwanted websites for users of Your LAN. Easy configuration and update To configure the wireless router DIR-620 friendly web-interface (available in several languages). Now You can easily upgrade the firmware – the router itself finds approved firmware on the update server D-Link, and notifies the user that it is ready to install.
Ürünler | Destek  | Haberler  | Hakkında |
