Hızlı Arama
Ürün Özellikleri:
Wireless N300 router with 3G/CDMA/LTE and USB port
Genel Özellikler:
Fiziksel Özellikler
Hardware
Interfaces · WAN Port 10/100BASE-TX
· 4 LAN ports 10/100BASE-TX
· USB 2.0 port
Indicators · POWER
· WPS
· INTERNET
· WLAN
· 4 LAN LEDs
· USB
Buttons · ON/OFF Button to turn on/off
· RESET button for reset to factory default settings
· WPS button to setup a secure wireless connection and
enable/disable wireless network
Antenna · Two internal Omni-directional antenna with gain of 2.5 dBi
Scheme MIMO · 2 x 2
Power connector · Connector for power supply connection (DC)
Software
Connection types WAN network · LTE network
· 3G
· PPPoE
· IPv6 PPPoE
· Dual Stack PPPoE
· Static IP or Dynamic IP
· Static IPv6 / Dynamic IPv6
· PPPoE + Static IP
· PPPoE + Dynamic IP for
· PPTP and L2TP + Static IP
· PPTP and L2TP + Dynamic IP for
Network features · Support standard security IEEE 802.1 x to connect to the Internet
· DHCP server/relay
· Track the status of dhcpv6 server (stateful/stateless), the delegation of IPv6 prefix for
· DNS relay
· Support records DNSv6 class AAAA
· Dynamic DNS
· Static IP-routing
· Static IPv6 routing
· Proxy IGMP
· REAP
· Support UPnP IGD
· Support VLANs
· Support the functions of the ping command from external network (WAN ping respond)
· SIP Protocol support
· Support RTSP
· Reservation
Firewall features · network address translation (NAT)
· Monitoring the status of network connections (SPI)and
· IP-filters
· IPv6 filters
· Mac-filter
· Url-filter
· DMZ-zone
· The protection ARP - and DDoS-attacks
· Virtual servers
· Integrated content filtering service Yandex.DNS
VPN·, IPSec and PPTP and L2TP/PPPoE Pass-through
Software
Features USB interface · USB modem
Auto connection to available type of supported network (4G/3G/2G)1
The on/ off PIN-code verification, change PIN-Code2
· USB drive
File browser
Print server
Account to access the drive
Built-in Samba server
Built-in FTP server
Built-in DLNA server
Built-in torrent client Transmission, the possibility of downloading files on the USB
the drive and
Management · Local and remote access to settings through TELNET/WEB (HTTP/HTTPS)
· Web-based configuration and management in multiple languages
· Notification on connection problems and auto redirect to
settings
· Firmware update via web interface
· Automatic notification on new firmware version
· Save and load configuration
· Support of remote logging
· Automatic synchronization of system time with NTP server and manual
setting the date and time
· Ping function
· Traceroute utility
· The TR-069 client
The settings of the wireless module
Standards · IEEE 802.11 b/g/n
Frequency range · 2400 ~ 2483,5 MHz
The WLAN security · WEP
· WPA/WPA2 (Personal/Enterprise)
· MAC-filter
· WPS (PBC/PIN)
Additional features · the "client"
· WMM (Wi-Fi QoS)
· Management of connected devices
· Advanced settings
Wireless speed · IEEE 802.11 b: 1, 2, 5.5 and 11 Mbps
· IEEE 802.11 g: 6, 9, 12, 18, 24, 36, 48 and 54 Mbps
· IEEE 802.11 n: from 6.5 to 300Mbps (from MCS0 to MCS15)
Transmitter output power
The maximum value of the power
the transmitter will change
accordance with the rules
regulations in Your
the country
· 802.11 b (typical at room temperature 25 °C)
17 dBm (+/-1.5 dB) at 1, 2, 5,5, 11 Mbps
· 802.11 g (typical at room temperature 25 °C)
14 dBm (+/-1.5 dB) at 6, 9, 12, 18, 24, 36, 48, 54 Mbps
· 802.11 n (typical at room temperature 25 °C)
HT20
14 dBm (+/-1.5 dB) at MCS0/1/2/3/4/5/6/7/8/9/10/11/12/13/14/15
HT40
14 dBm (+/-1 dB) at MCS0/1/2/3/4/5/6/7/8/9/10/11/12/13/14/15
Physical parameters
Dimensions · 160 x 120 x 59 mm
Weight · 200 g
Conditions
Power · Output: 12 VDC, 1 A
Temperature · operating: 0 to 40 °C
· Storage: -20 to 65 °C
Humidity · operating: 10% to 90% (non-condensing)
· Storage: 5% to 95% (non-condensing)
Ürünler | Destek  | Haberler  | Hakkında |
