Kirjeldus
POWERFUL SURVEILLANCE
IP surveillance systems are quickly gaining over conventional CCTV security cameras due to superior performance and low costs. The DCS-5610 now features a Sony VGA Progressive Scan CCD technology which provides exceptional picture quality. Use D-Link's SoC (system-on-chip) products to provide high quality real-time video compression in MPEG-4 and Motion JPEG formats. DCS-5610 supports simultaneous dual-streaming for live monitoring and recording. With a built-in Samba client for NAS, DCS-5610 IP camera does not need a direct connection to a PC or any other hardware or software to capture and transfer images.
WIRED PoE ACCESS
For effective surveillance in and around a building, this camera comes with a built-in 802.3af compliant Power Over Ethernet (PoE) module, which eases the installation process and also gives you the freedom to place the camera where it's needed. In addition, a 10/100BASE-TX Ethernet port is also provided for convenient connection to an Ethernet network or to a broadband Internet via a gateway router. The camera can be accessed and viewed from any network place as a device on the network.
SHARP IMAGE MONITORING FROM DIFFERENT ANGLES
Equipped with a light sensitive lens, this camera is capable of capturing video in rooms with minimal lighting. It features a motorized pan/tilt capability, allowing images to be monitored from different angles, and an optical zoom for greater remote viewing options. The DCS-5610 provides high quality real-time videos in MPEG-4 and JPEG compression with VGA/QVGA/QQVGA resolution delivering 30 frames per second, including the transmission of audio data. DCS-5610 supports Netscape, Mozilla and Opera browser (QuickTime for MPEG4 stream).
VIEW LIVE VIDEO FROM A 3G MOBILE PHONE2
The live camera feed of the camera can be pulled from the 3G cellular network by using a compatible cell phone or PDA with a 3G video player. Anywhere within the 3GPP service area, users are offered a flexible and convenient way to remotely monitor a home or office in real time.
SMART & EASY TO USE
Records images 24 hours a day, 7 days a week to a computer’s hard drive only when motions are detected. This saves disk space and eliminates the time wasted to view unnecessary images. Also, images can be recorded manually or according to a pre-set schedule. Playback consumes little time with triggered event browsing and fast database searching. The software, D-View Cam allows you to view up to 32 cameras on a single computer screen at one central location. Users can set up automated e-mail alerts to be instantly informed of unusual activities. The camera supports the Universal Plug-n-Play feature, which allows computers running on Windows XP/ME/Vista to automatically recognize the camera and adds it to the network. Sign up with one of the free Dynamic DNS services available on the web, to assign a name and domain to the camera (e.g. mycamera.dlinkddns.com). This allows users to remotely access the camera without having to remember the IP address.
Põhiomadused
Võrguprotokollide toetus
TCP/IP, RTSP, RTP, RTCP, HTTP, SMTP, FTP, NTP, DNS, DHCP, UPnP, DDNS, PPPoE, ICMP, Samba-klient
Sisseehitatud võrguliidesed
Video-algoritmide toetus
Video resolutsioon
Video funktsionaal
Video kiirus
20K kuni 4M
Kaamera omadused
Pööramine/kallutus/suumimine
LAN
Füüsilised parameetrid
Indikaatorid
2 indikaatori värvi
Toide sisendil
Tarbitav võimsus
6 W
Mõõdud
104 x 103,5 x 118 mm
Kaal
319 g
Аudio + GSM-AMR/MPEG-4 AAC
Мikrofon
Turvalisus
Tarkvara jälgimis funktsioonid
Nõuded süsteemile
PDA, mobiiltelefonide ja tarkvara toetus
