DSM-350
MyChannel Media Player
Kirjeldus
TAKE CONTROL OVER YOUR DIGITAL MEDIA
Download, organize, and play your digital videos, music, and photos with the MyChannel Media Player. By adding a 2.5” SATA hard drive, you can conveniently store your entire multimedia library on the MyChannel Media Player. Connect it to your TV for easy access to your multimedia fles through the included remote control and a friendly on-screen interface. The MyChannel Media Player is also mydlink enabled, allowing you to manage it from anywhere over the Internet through the mydlink.com website.
CUSTOM CHANNELS YOU CREATE
MyChannel mode allows you to create your own custom TV channels, making it easy to watch what you want, when you want. Create a channel for your favorite TV series and fip through all the episodes in a season, or create separate channels for your movies and kids’ shows. MyChannel mode includes an Electronic Program Guide (EPG) feature that lets you see what programs are on each of your custom channels, and lets you access a particular show instantly.
HIGH-DEFINITION VIDEO PLAYBACK
The MyChannel Media Player includes a HDMI connection to give you high-defnition video at up to 720p resolution, so you can watch your movies with incredible image and sharpness. A digital optical audio output allows you to listen to your music with outstanding clarity. An AV cable is also included for connection to TVs with composite video connection.
DOWNLOAD FILES DIRECTLY TO THE MYCHANNEL MEDIA PLAYER
By including a built-in downloading agent, the MyChannel Media Player can download fles directly to the installed hard drive, allowing you to shut down your home PC while the MyChannel Media Player continues downloading your fles for you. After downloading your fles, they can be automatically assigned to a channel for easy playback.
Põhiomadused
NETWORK
+ Wired LAN: 10/100BASE-Tx Ethernet
+ DHCP, PPPoE, or Static IP Address
OUTPUTS
+ HDMI (High-Defnition Multimedia Interface)
+ S/PDIf digital optical audio port
+ Composite video out and Audio l/r outputs
SUPPORTED VIDEO FORMATS (1)
+ ASf
+ AVI
+ DAT
+ FlV
+ M4V
+ MkV
+ MoV
+ MP4
+ MPG
+ RM
+ RMVB
+ TS
+ VoB
+ WMV
+ SRT Subtitle Support
SUPPORTED AUDIO FORMATS (1)
+ MP3
+ WAV
+ OGG
+ FLAC
+ WMA
+ AAC
+ PlS/M3u/wPl Playlist Support
SUPPORTED IMAGE FORMATS (1)
+ JPG
+ BMP
+ PNG
+ GIF
HARD DRIVE SUPPORT (2)
+ 2.5” hard drive bay
+ SATA interface
MEDIA STREAMING PROTOCOL
HTTP
Sertifikaadid
Sidustooted
DSM-350  MyChannel Media Player
Pildid
Failid
Vaadake samuti
