DIR-825EOL
AC1200 Wave 2 MU-MIMO Wi-Fi EasyMesh Gigabit Router with 3G/LTE Support and USB Port
Kirjeldus
USB Port
The router is equipped with a USB port for connecting a USB modem, which can be used to establish connection to the Internet. In addition, to the USB port of the router you can connect a USB storage device, which will be used as a network drive, or a printer1.
In order to use the multifunction USB port effectively, the router supports simultaneous operation of several USB devices2. For example, you can access multimedia content of the connected HDD storage and at the same time share a USB printer1.
Wireless Interface
Using the DIR-825 device, you are able to quickly create a high-speed wireless network at home or in your office, which lets computers and mobile devices access the Internet virtually anywhere (within the operational range of your wireless network). Simultaneous activity of 2.4GHz band and 5GHz band allows performing a wide range of tasks. The router can operate as a base station for connecting wireless devices of the standards 802.11a, 802.11b, 802.11g, 802.11n, and 802.11ac (at the wireless connection rate up to 1167Mbps3).
Secure Wireless Connection
The router supports multiple functions for the wireless interface: several security standards (WEP, WPA/WPA2/WPA3), MAC address filtering, WPS, WMM.
In addition, the device is equipped with a button for switching the Wi-Fi network off/on. If needed, for example, when you leave home, you can easily switch the router’s WLAN by pressing the button, and devices connected to the LAN ports of the router will stay online.
The EasyMesh function4 is D-Link implementation of mesh networks designed to quickly connect several5 devices into one transport network, for example, when it's required to provide high-quality Wi-Fi coverage without dead zones in living units of complicated planning or it's needed to create a large temporary Wi-Fi network for an outdoor event.
Multi-user MIMO technology allows to distribute the router's resources to let multiple wireless clients use the Wi-Fi network efficiently, keeping high rates for HD media streaming, lag-free gaming, and fast transfer of large files.
Transmit Beamforming technology allows to flexibly change the antennas' radiation pattern and to redistribute the signal directly to wireless devices connected to the router.
Support of guest Wi-Fi network allows you to create a separate wireless network with individual security settings and maximum rate limitation. Devices connected to the guest network will be able to access the Internet, but will be isolated from the devices and resources of the router's LAN.
Security
The wireless router DIR-825 includes a built-in firewall. The advanced security functions minimize threats of hacker attacks, prevent unwanted intrusions to your network, and block access to unwanted websites for users of your LAN1.
The SSH protocol support provides more secure remote configuration and management of the router due to encryption of all transmitted traffic, including passwords.
In addition, the router supports IPsec and allows to create secure VPN tunnels. Support of the IKEv2 protocol allows to provide simplified message exchange and use asymmetric authentication engine upon configuration of an IPsec tunnel.
The router also supports the SkyDNS web content filtering service1, which provides more settings and opportunities for safer Internet experience for home users of all ages and for professional activities of corporate users.
Now the schedules are also implemented; they can be applied to the rules and settings of the firewall and used to reboot the router at the specified time or every specified time period and to enable/disable the wireless network and the Wi-Fi filter.
The new ad blocking function effectively blocks advertisements which appear during web surfing.
Easy configuration and update
You can configure the settings of the wireless router DIR-825 via the user-friendly web-based interface (the interface is available in several6 languages).
The configuration wizard allows you to quickly switch DIR-825 to one of the following modes: router (for connection to a wired or wireless ISP), access point, repeater, or client, and then configure all needed setting for operation in the selected mode in several simple steps.
Also DIR-825 supports configuration and management via mobile application for Android smartphones.
You can simply update the firmware: the router itself finds approved firmware on D-Link update server and notifies when ready to install it.
1Only for DIR-825/R4.
2When using a USB hub with external power supply.
3Up to 300Mbps for 2.4GHz and up to 867Mbps for 5GHz.
4For DIR-825/I1 EasyMesh is supported from firmware version 1.0.3; for DIR-825/R4 EasyMesh is supported from firmware version 4.0.3.
5Up to 6 devices. Cooperation is supported for the following models: DIR-X1530/A1, DIR-X1510/R1, DIR-842V2/A1, DIR-842/R7, DIR-842/R5, DIR-842/S2, DIR-842/S1, DIR-842/R4, DIR-830M/A1, DIR-825/R7, DIR-825/R5, DIR-825/I1, DIR-825/R4, DIR-822/E1, DIR-822/R4, DIR-815/R4. Provided that the FW version supporting the EasyMesh function is used.
6In Russian and English for DIR-825/R4.
Põhiomadused
DIR-825/R4
DIR-825/I1
Hardware
Processor
RTL8197FH (1GHz)
RAM
128MB, DDR2, built in processor
Flash
128MB, SPI
128MB, SPI NAND
Interfaces
10/100/1000BASE-T WAN port
4 10/100/1000BASE-T LAN ports
USB 2.0 port
LEDs
Power
Internet
4 LAN LEDs
WLAN 2.4G
WLAN 5G
WPS
USB
Power
Internet
WLAN 2.4G
WLAN 5G
USB
Buttons
POWER button to power on/power off
WIFI button to enable/disable wireless network
WPS button to connect mesh network devices and set up wireless connection
RESET button to restore factory default settings
ON/OFF button to power on/power off
Antenna
Four external non-detachable antennas (5dBi gain)
MIMO
2 x 2, MU-MIMO
Power connector
Power input connector (DC)
Mounting
Desktop
Wall
Software
WAN connection types
Mobile Internet (via supported USB modem)
PPPoE
IPv6 PPPoE
PPPoE Dual Stack
Static IPv4 / Dynamic IPv4
Static IPv6 / Dynamic IPv6
PPPoE + Static IP / Dynamic IP (PPPoE Dual Access)
PPTP/L2TP + Static IP
PPTP/L2TP + Dynamic IP
Network functions
DHCP server/relay
Advanced configuration of built-in DHCP server
Stateful/Stateless mode for IPv6 address assignment, IPv6 prefix delegation
Automatic obtainment of LAN IP address (for access point/repeater/client modes)
DNS relay
Dynamic DNS
Static IPv4/IPv6 routing
IGMP/MLD Proxy
RIP
Support of UPnP IGD
Support of VLAN
WAN ping respond
Support of SIP ALG
Support of RTSP
WAN failover
Autonegotiation of speed, duplex mode, and flow control / Manual speed and duplex mode setup for each Ethernet port
Firewall functions
Network Address Translation (NAT)
Stateful Packet Inspection (SPI)
IPv4/IPv6 filter
MAC filter
Ad blocking function
URL filter
DMZ
Virtual servers
Built-in SkyDNS web content filtering service
VPN
IPsec/PPTP/L2TP/PPPoE pass-through
PPTP/L2TP tunnels
L2TP over IPsec
IPsec tunnels
Transport/Tunnel mode
IKEv1/IKEv2 support
DES encryption
NAT Traversal
Support of DPD (Keep-alive for VPN tunnels)
USB interface functions
USB modem
Auto connection to available type of supported network (4G/3G/2G)
Auto configuration of connection upon plugging in USB modem
Enabling/disabling PIN code check, changing PIN code1
Sending/receiving/reading/removing SMS messages1
Support of USSD requests1
USB storage
File browser
Print server
Access to storage via accounts
Built-in Samba server
Built-in FTP server
Built-in DLNA server
Built-in Transmission torrent client; uploading/downloading files from/to USB storage
Management and monitoring
Local and remote access to settings through SSH/TELNET/WEB (HTTP/HTTPS)
Bilingual web-based interface for configuration and management (Russian/English) + +
Multilingual web-based interface for configuration and management
Support of D-Link Assistant application for Android smartphones
Notification on connection problems and auto redirect to settings
Firmware update via web-based interface
Automatic notification on new firmware version
Saving/restoring configuration to/from file
Support of logging to remote host/connected USB storage
Automatic synchronization of system time with NTP server and manual time/date setup
Ping utility
Traceroute utility
TR-069 client
Schedules for rules and settings of firewall, automatic reboot, and enabling/disabling wireless network and Wi-Fi filter
Automatic upload of configuration file from ISP's server (Auto Provision) +
Wireless Module Parameters
Standards
IEEE 802.11ac Wave 2
IEEE 802.11a/b/g/n
IEEE 802.11k/v
IEEE 802.11w
IEEE 802.11a/b/g/n
IEEE 802.11k/v
IEEE 802.11w
Frequency range
The frequency range depends upon the radio frequency regulations applied in your country
2400 ~ 2483.5MHz
5150 ~ 5350MHz
5650 ~ 5850MHz
Wireless connection security
WEP
WPA/WPA2 (Personal/Enterprise)
WPA3 (Personal)
МАС filter
WPS (PBC)
WPS (PIN)
Advanced functions
EasyMesh function
Support of client mode
WMM (Wi-Fi QoS)
Information on connected Wi-Fi clients
Advanced settings
Guest Wi-Fi / support of MBSSID
Rate limitation for wireless network/separate MAC addresses
Periodic scan of channels, automatic switch to least loaded channel
Support of 5GHz TX Beamforming
Autonegotiation of channel bandwidth in accordance with environment conditions (20/40 Coexistence)
Support of STBC
Wireless connection rate
IEEE 802.11a: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
IEEE 802.11b: 1, 2, 5.5, and 11Mbps
IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
IEEE 802.11n (2.4/5GHz): from 6.5 to 300Mbps (MCS0–MCS15)
IEEE 802.11ac (5GHz): from 6.5 to 867Mbps
Transmitter output power
Less than 20dBm (100mW)
Receiver sensitivity
802.11a
-92dBm at 6Mbps
-91dBm at 9Mbps
-90dBm at 12Mbps
-88dBm at 18Mbps
-85dBm at 24Mbps
-81dBm at 36Mbps
-77dBm at 48Mbps
-75dBm at 54Mbps
-92dBm at 6Mbps
-91dBm at 9Mbps
-90dBm at 12Mbps
-88dBm at 18Mbps
-85dBm at 24Mbps
-81dBm at 36Mbps
-77dBm at 48Mbps
-75dBm at 54Mbps
802.11b
-87 дБм при 11 Мбит/с
-90dBm at 1Mbps
-92dBm at 2Mbps
-93dBm at 5.5Mbps
-96dBm at 11Mbps
802.11g
-92dBm at 6Mbps
-91dBm at 9Mbps
-90dBm at 12Mbps
-88dBm at 18Mbps
-85dBm at 24Mbps
-81dBm at 36Mbps
-77dBm at 48Mbps
-76dBm at 54Mbps
-94dBm at 6Mbps
-92dBm at 9Mbps
-90dBm at 12Mbps
-89dBm at 18Mbps
-87dBm at 24Mbps
-84dBm at 36Mbps
-80dBm at 48Mbps
-77dBm at 54Mbps
802.11n
2.4GHz, HT20
-92dBm at MCS0/8
-90dBm at MCS1/9
-87dBm at MCS2/10
-84dBm at MCS3/11
-81dBm at MCS4/12
-77dBm at MCS5/13
-75dBm at MCS6/14
-74dBm at MCS7/15
2.4GHz, HT40
-88dBm at MCS0/8
-86dBm at MCS1/9
-84dBm at MCS2/10
-81dBm at MCS3/11
-77dBm at MCS4/12
-73dBm at MCS5/13
-71dBm at MCS6/14
-70dBm at MCS7/15
5GHz, HT20
-91dBm at MCS0/8
-90dBm at MCS1/9
-88dBm at MCS2/10
-84dBm at MCS3/11
-81dBm at MCS4/12
-76dBm at MCS5/13
-75dBm at MCS6/14
-73dBm at MCS7/15
5GHz, HT40
-90dBm at MCS0/8
-87dBm at MCS1/9
-84dBm at MCS2/10
-81dBm at MCS3/11
-78dBm at MCS4/12
-73dBm at MCS5/13
-72dBm at MCS6/14
-70dBm at MCS7/15
2.4GHz, HT20
-95dBm at MCS0
-91dBm at MCS1
-88dBm at MCS2
-86dBm at MCS3
-82dBm at MCS4
-79dBm at MCS5
-77dBm at MCS6
-75dBm at MCS7
2.4GHz, HT40
-92dBm at MCS0
-89dBm at MCS1
-86dBm at MCS2
-83dBm at MCS3
-80dBm at MCS4
-77dBm at MCS5
-74dBm at MCS6
-72dBm at MCS7
5GHz, HT20
-95dBm at MCS0
-93dBm at MCS1
-90dBm at MCS2
-87dBm at MCS3
-83dBm at MCS4
-79dBm at MCS5
-77dBm at MCS6
-75dBm at MCS7
5GHz, HT40
-92dBm at MCS0
-89dBm at MCS1
-86dBm at MCS2
-83dBm at MCS3
-80dBm at MCS4
-76dBm at MCS5
-74dBm at MCS6
-72dBm at MCS7
802.11ac
VHT20
-91dBm at MCS0
-89dBm at MCS1
-87dBm at MCS2
-84dBm at MCS3
-81dBm at MCS4
-76dBm at MCS5
-75dBm at MCS6
-74dBm at MCS7
-69dBm at MCS8
VHT40
-90dBm at MCS0
-87dBm at MCS1
-84dBm at MCS2
-81dBm at MCS3
-78dBm at MCS4
-73dBm at MCS5
-72dBm at MCS6
-71dBm at MCS7
-66dBm at MCS8
-64dBm at MCS9
VHT80
-87dBm at MCS0
-83dBm at MCS1
-81dBm at MCS2
-78dBm at MCS3
-74dBm at MCS4
-70dBm at MCS5
-69dBm at MCS6
-67dBm at MCS7
-63dBm at MCS8
-62dBm at MCS9
VHT20
-95dBm at MCS0
-92dBm at MCS1
-90dBm at MCS2
-86dBm at MCS3
-83dBm at MCS4
-79dBm at MCS5
-77dBm at MCS6
-75dBm at MCS7
-71dBm at MCS8
VHT40
-92dBm at MCS0
-89dBm at MCS1
-87dBm at MCS2
-84dBm at MCS3
-80dBm at MCS4
-76dBm at MCS5
-74dBm at MCS6
-72dBm at MCS7
-68dBm at MCS8
-66dBm at MCS9
VHT80
-89dBm at MCS0
-86dBm at MCS1
-83dBm at MCS2
-80dBm at MCS3
-77dBm at MCS4
-73dBm at MCS5
-71dBm at MCS6
-69dBm at MCS7
-66dBm at MCS8
-64dBm at MCS9
Modulation schemes
802.11a
BPSK, QPSK, 16QAM, 64QAM с OFDM
802.11b
DQPSK, DBPSK, DSSS, CCK
802.11g
802.11n
802.11ac
BPSK, QPSK, 16QAM, 64QAM, до 256QAM с OFDM
Physical Parameters
Dimensions (L x W x H)
205 x 136 x 44 mm (8.07 x 5.35 x 1.73 in)
181 x 132 x 48 mm (7.13 x 5.22 x 1.88 in)
Weight
295 g (0.65 lb)
305 g (0.67 lb)
Operating Environment
Power
Output: 12V DC, 1.5A
Temperature
Operating: from 0 to 40 °C
Storage: from -20 to 65 °C
Humidity
Operating: from 10% to 90% (non-condensing)
Storage: from 5% to 95% (non-condensing)
Delivery Package
Router DIR-825
Power adapter DC 12V/1.5A
Ethernet cable
“Quick Installation Guide” (brochure)
Supported USB modems2
GSM
Alcatel X500
D-Link DWM-152C1
D-Link DWM-156A6
D-Link DWM-156A7
D-Link DWM-156A8
D-Link DWM-156C1
D-Link DWM-157B1
D-Link DWM-157B1 (Velcom)
D-Link DWM-158D1
D-Link DWR-710
Huawei E150
Huawei E1550
Huawei E156G
Huawei E160G
Huawei E169G
Huawei E171
Huawei E173 (Megafon)
Huawei E220
Huawei E3131 (MTS 420S)
Huawei E352 (Megafon)
Huawei E3531
Prolink PHS600
Prolink PHS901
ZTE MF112
ZTE MF192
ZTE MF626
ZTE MF627
ZTE MF652
ZTE MF667
ZTE MF668
ZTE MF752
LTE
Alcatel IK40V
D-Link DWM-222
Huawei E3131
Huawei E3272
Huawei E3351
Huawei E3372s
Huawei E3372h-153
Huawei E3372h-320
Huawei E367
Huawei E392
Megafon M100-1
Megafon M100-2
Megafon M100-3
Megafon M100-4
Megafon M150-1
Megafon M150-2
Megafon M150-3
MTS 824F
MTS 827F
Quanta 1K6E (Beeline 1K6E)
Yota LU-150
Yota WLTUBA-107
ZTE MF823
ZTE MF823D
ZTE MF827
ZTE MF833T
ZTE MF833V
Smartphones in USB tethering mode
Some models of Android smartphones
1For some models of USB modems.
2The manufacturer does not guarantee proper operation of the router with every modification of the firmware of USB modems.
Sertifikaadid
Sidustooted
DIR-825/R4
DIR-825/I1
Pildid
DIR-825/I1
Eestvaade
Paremvaade
Tagantvaade
Bottom view
Failid
Vaadake samuti
