DES-1005C
5-Port 10/100Base-TX Switch
תאור
The DES-1005C 5-Port SOHO Desktop Switch is economical, plug-and-play networking switch solution for SOHO and small to medium businesses. It provides five 10/100 Mbps ports, enabling you to easily expand your network and quickly upgrade your connectivity.
Plug-and-Play Installation
The DES-1005C is plug-and-play device that requires no configuration. You can easily connect multiple computers, share files, music, and video across your home or small office network. 802.3 flow control automatically and efficiently manages the data transmission process without packet loss, providing a more reliable connection for all of your connected devices.
Auto MDI/MDIX Crossover
All ports support automatic MDI/MDIX crossover, eliminating the need for crossover cables or uplink ports. Each port can be plugged directly into a server, hub, router, or switch using regular straight-through twisted-pair Ethernet cables, streamlining installation.
Conserve Energy
The DES-1005C implements a power saving function that can detect when a connected computer is shut down or when there is no Ethernet traffic. The 5-Port SOHO Desktop Switch will automatically put inactive ports in standby mode, saving a substantial amount of power, and power them back on later when needed.
מאפיינים כללים
Interfaces
• 5 x 10/100Base-TX ports
Diagnostic LEDs
• Power
• Link/Act (per port)
Enclosure
• Plastic
Installation
• Desktop
Standards
• IEEE 802.3 10Base-T
• IEEE 802.3u 100Base-TX
• IEEE 802.3x Flow Control
• Speed and duplex mode auto-negotiation for each port
• Auto-MDI/MDIX adjustment on all ports
• Back pressure at half-duplex operation
Data Transfer Rates
• Ethernet:
  • 10 Mbps (half duplex)
  • 20 Mbps (full duplex)
• Fast Ethernet:
  • 100 Mbps (half duplex)
  • 200 Mbps (full duplex)
Additional Features
• Power saving by link status detection
Switching Capacity
• 1 Gbps
Transmission Method
• Store-and-forward
MAC Address Table
• 2K entries
Max. Packet Forwarding Rate
• Fast Ethernet: 148,800 pps per port
Packet Buffer
• 96 KB
Physical Parameters
Dimensions
• 85 x 52 x 22 mm
Weight
• 55.6 g
Power Input
• 5 V DC / 0.55 A external power adapter
Maximum Power Consumption
• 0.97 W
Standby Power Consumption
• 0.15 W
Heat Dissipation
• 0.97 W (3.31 BTU/hr)
MTBF
• 1,205,642 hours
Ventilation System
• Fanless
Temperature
• Operating: 0° to 40°C
• Storage: -40° to 70°C
Humidity
• Operating: 10 to 90% non-condensing
• Storage: 5% to 95% non-condensing
Certificates
• CE Class B
• CE LVD
• FCC Class B
• ICES 003
• RCM Class B
• BSMI Class B
תקנים
הורדות
| DES-1005C/C2A | 5-Port 10/100Base-TX Switch |
