DCS-2310LEOL EOS
תאור
HD IP-Camera Cube DCS-2310L with PoE and mydlink cloud service is designed to provide day and night outdoor surveillance.
24/7 Camera Surveillance
DCS-2310L has a megapixel sensor and allows you to create clear and detailed still images and videos in HD-quality with a resolution of up to 720p. Function application ePTZ, you can zoom, rotate an image with the camera, which in turn provides an overview of a large area.
Built-in ICR-filter during the day does not pass infrared light, which contributes to a high quality image. At night, the ICR-filter is moved to the side to use a wider range of radiation surveillance in low light conditions, and with infrared illumination allows monitoring even in complete darkness.
Outdoor surveillance
DCS-2310L is designed to provide outdoor surveillance and executed in weatherproof housing with protection from moisture and dust IP-65. Support PoE technology allows the simultaneous transmission of data and power over a single cable, which simplifies installation and enables the camera in places where the power supply is not available.
Access from anywhere with cloud services mydlink
External HD IP-Camera Cube supports cloud service mydlink, which gives the user the ability to remotely access the settings and images from IP cameras, regardless of its location. The user can view video from IP-camera to Web-site mydlink from any computer or mobile device with an iOS or Android, you can download special mobile app mydlink.
Automatic adjustment Zero Configuration
When a router with support for cloud service mydlink configure the network camera does not pose any difficulty due to the automatic adjustment Zero Configuration. To do this, simply connect the power adapter to the camera and the camera to a router with an Ethernet-cable, and the device will automatically be added to your account. Mydlink service allows even the most inexperienced user to quickly and easily configure the camera that supports the cloud.
Comprehensive features
With an extended functional DCS-2310L is ideal for various tasks surveillance. Infrared motion sensor (PIR) is designed to detect motion, which allows the camera to automatically take pictures and send you alerts when motion is detected. Built-in microphone and speaker provide two-way audio transmission, which is especially useful for conducting surveillance at the entrance to the building.
Ready scalable solution
DCS-2310L is a standalone solution for conducting surveillance and supports video recording and save still images to MicroSD card without the need for a PC or network-attached storage NAS.
To enhance video surveillance package includes the software D-ViewCam, designed to manage 32 cameras with a wide array of features, such as viewing images from multiple cameras simultaneously and send them to e-mail notifications of suspicious events or emergency situations.
מאפיינים כללים
Camera Specifications
• 1/4-inch megapixel CMOS-sensor with progressive scan
• Infrared light: the range of - 5 m
• Minimum illumination: 0 lux with IR lighting
• Built-in ICR-filter
• Built-in infrared motion sensor (PIR) (5 m)
• Built-in microphone / speaker
• 10x digital zoom
• Focal length: 3.45 mm
• Aperture: F2.0
• Viewing angle:
- 57,8 ° (horizontal)
- 37,8 ° (vertical)
- 66 ° (diagonal)
Housing
• Weatherproof housing with degree of protection IP-65
Image details
• Setting the image quality and size, frame rate and bit rate
• Timestamps and overlay text
• Windows to configure motion detection
• Customizable private mask area
• Set the shutter speed, brightness, color saturation, contrast and sharpness
Video Compression
• Simultaneous compression formats H.264/MPEG-4/MJPEG
• Multicast streaming video formats H.264/MPEG-4
• JPEG for still images
Video Resolution
• 16:9 - 1280 x 800, 1280 x 720, 800 x 450, 640 x 360, 480 x 270, 320 x 176, 176 x 144 up to 30 frames / s ¹
• 4:3 - 1024 x 768, 800 x 600, 640 x 480, 480 x 360, 320 x 240, 176 x 144 up to 30 frames / s ¹
Audio support
• G.726
• G.711
Interfaces to external devices
• Port 10/100 BASE-TX Fast Ethernet
• Supports 802.3af PoE
• Card slot for MicroSD / SDHC
Network Protocols
• IPv6
• IPv4
• TCP / IP
• UDP
• ICMP
• DHCP-Client
• NTP-Client (D-Link)
• DNS-client
• DDNS-client (D-Link)
• SMTP-client
• FTP-client
• HTTP / HTTPS
• Samba-client
• PPPoE
• UPnP port forwarding
• RTP / RTSP / RTCP
• Filtering of IP-addresses
• QoS
• CoS
• Multicast
• IGMP
• Compliance with ONVIF
Safety
• Security Administrator and user group
• Password authentication
• Encryption HTTP and RTSP
System requirements for the web-interface
• Web-browser: Internet Explorer, Firefox or Chrome
Event management
• Motion detection
• Event notification and download stop-kadrov/videozapisey via email or FTP
• Support for multiple FTP and SMTP servers
• Multiple event notifications
• Several ways to backup
Remote management
• Creating and maintaining stop-kadrov/videozapisey to a local hard drive or NAS via Web-browser
• The ability to gain access to the settings interface using Web-browser
Support for mobile devices
• OS Windows 7/Vista/XP, PDA or mobile phone
• Mobile application mydlink for mobile devices based on iOS and Android
System Requirements D-ViewCam ™
• Operating System: Microsoft Windows 7/Vista/XP
• Web-browser: Internet Explorer 7 or above
• Protocol: Standard TCP / IP
The software features D-ViewCam ™
• Remote management / control of up to 32 cameras
• View images from multiple cameras on a single screen (up to 32 cameras)
• Supports all management functions in the Web-interface
• Recording triggered detection or manual
