תאור
High Resolution Surveillance
The D-Link® DCS-3110 Fixed
Network Camera is a high performance megapixel camera designed for
professional surveillance and security applications. Equipped with a
1.3 Megapixel Progressive Scan CMOS sensor and a 6mm Lens, the DCS-3110
allows you to capture a wider field of view with a resolution of up to
1280 x 1024. The built-in ICR filter in the DCS-3110 provides automatic
Day/Night functionality, adjusting the image from color during the day
(and in low-light conditions) to monochrome at night (or in extremely
poor lighting conditions).
With features such as simultaneous MPEG-4/MJPEG streaming, multicast MPEG-4 streaming, PoE support, a built-in Compact Flash card slot, and connectivity to a variety of external devices, the DCS-3110 is an extremely versatile solution for high quality, high resolution viewing and reliable recording throughout the day.
Multiple Streaming
The DCS-3110 supports
simultaneous streaming of MPEG-4 and MJPEG video to provide both high
quality and bandwidth efficient compression formats. MJPEG delivers
greater file integrity, making it ideal for detailed monitoring
situations. MPEG-4 has smaller file sizes, making it more useful for
extended recording periods or for use in low bandwidth networks.
Additionally, the DCS-3110 supports multicast MPEG-4 streaming allowing
users to view content by subscribing to a multicast IP address on the
network.
Flexible Connectivity
The DCS-3110 includes
digital input and output ports (one each) allowing connectivity to
external devices such as IR sensors, switches, and alarm relays. It
also comes with a RS-485 interface, providing connectivity to an
optional Pan/Tilt enclosure, which effectively adds pan/tilt
functionality to the DCS-3110. Additionally, a 12V interface provides
power for an optional LED illuminator.
3GPP Mobile Surveillance
Support for 3GPP Mobile Surveillance1
allows you to view a live video feed from your compatible
Internet-ready mobile phone with a 3GPP player installed. This extends
your monitoring capability without requiring the use of a computer,
allowing you to check your camera’s video feed while on-the-go.
Additional Features
The DCS-3110 comes with a built-in microphone and audio ports allowing 2-way audio communication2
when an external speaker is connected and even includes an audio switch
to ensure privacy when needed. The DCS-3110 also comes with a built-in
Samba client for NAS so there is no need for a direct connection to a
PC or any other hardware or software to capture and transfer images.
Equipped with 802.3af Power over Ethernet (PoE) support3,
the DCS-3110 can receive both power and data over a single Ethernet
cable, allowing you to place this camera in locations without a power
outlet.
Convenient Management
The included D-Link
D-ViewCam™ 2.0 software enables you to manage up to 32 network cameras,
set e-mail alert notifications, set recording schedules, and trigger
motion detection to record directly to your hard drive. D-ViewCam 2.0
also allows you to upload a floor plan of your business and create a
realistic layout of where your cameras are located, further simplifying
the management process.
מאפיינים כללים
נתונים פיזיים
