תאור
Media Converter DMC-805X converts a signal from a standard 10G CX4 a signal 10G SFP +. DMC-805X is equipped with a slot for SFP + optical transceivers, selectable by the user, and extends the network connectivity for different distances depending on the capabilities of SFP + transceivers. DMC-805X is a high performance media converter 10G, which allows you to increase the distance for servers equipped with network cards 10G CX4 or old switches with port 10G CX4.
DMC-805X can be used as a standalone unit or mounted in standard rack chassis (DMC-1000), and the management function will be available. The control module (DMC-1002) allows users to monitor the status of DMC-805X and the food in the chassis in real time. It also sends an alarm and notifies users of emergency situations. The control module meets the following industry standards, including SNMP, and HTTP, which allows users to monitor and control the chassis party SNMP management station or via the web-browser.
מאפיינים כללים
Features media converter
• One-channel media conversion between 10 Gb / s SFP + and 10 Gbit / s CX4
• Support for various distances through 802.3ae/aq compliant SFP + transceivers
• Support for link pass through
• The switch to preset mode full-or half-duplex
• The switch to set the auto-negotiation or forced
• The switch for setting the speed
• The switch for setting the functions LLCF, LLR
• Mode switching Store-and-forward
• Support Backpressure and flow control IEEE 802.3x
• Wire-speed performance
• Status LEDs on the front panel
• Use as a single unit or installation in the chassis (DMC-1000)
• Easy management via web-based interface
• Graphical User Interface (GUI)
נתונים פיזיים
Indicators
• Power, Link / Act / Speed
Input Power
• 3.4 W AC
Maximum power consumption
• Power on. (standby)
• Power input: 1.63 V DC, 2.26 Tues AC
Dimensions
• 120 x 88 x 25 mm
Weight
• 0.29 kg
Operating temperature
• From 0 to 40 ° C
Storage temperature
• From -10 To 70 C
Operating humidity
• From 10% to 90% noncondensing
EMI
• CE Class A, LVD
