תאור
Dual Band Wireless Router D-Link DIR-516 provides high-speed Internet connection. DIR-516 allows you to create a secure connection, and provides public access to the Internet at home or at the hotel. New wireless standard 802.11ac (draft) provides the highest data transfer rate to compatible devices. In addition, the router retains all connection settings, which greatly simplifies the connection of devices to the wireless router DIR-516 in the future.
High level of performance with standard 802.11ac (draft)
Router DIR-516 supports the latest standard 802.11ac, which provides high speed data transfer with compatible wireless devices. Dual band 2.4 GHz and 5 GHz to avoid network congestion and interference. Wireless speed at 2.4 GHz is about 150 Mbit / s, 5 GHz - up to 433 Mbit / s. You can also configure the guest area («guest zone»), whose clients will have access only to the Internet.
Portability
Compact, lightweight router DIR-516 allows you to set up an Internet connection at any time and in any place. Due to the small size of the router can be put in your pocket or laptop bag. DIR-516 is an ideal solution for high-speed connectivity wherever you are in the library, coffee shop or at home.
Easy to install, easy to use
Router DIR-516 greatly simplifies shared access to the Internet. Just open the Web-browser to access the utility, and follow instructions. Create a secure network with one touch WPS button without entering settings and passwords.
מאפיינים כללים
Device Interfaces
• 2.4 GHz band: 802.11 b / g / n Wireless LAN, up to 150 Mbit/s1
• The frequency of 5 GHz: 802.11 a / n / ac Wireless LAN, up to 433 Mbit1
• WPS button
• Reset Button
• Port WAN / LAN 10/100 Ethernet
Indicators
• Power / condition
Standards
• IEEE 802.11ac (draft)
• IEEE 802.11n
• IEEE 802.11g
• IEEE 802.11b
• IEEE 802.11a
• IEEE 802.3
• IEEE 802.3x
• IEEE 802.3u
• USB 2.0
Modes of Internet connection
• Router
• Access point
Frequency band
• IEEE 802.11a: 5150 MHz ~ 5250 MHz, 5725 MHz ~ 5850 MHz
• IEEE 802.11b: 2400 ~ 2497 MHz ISM band
• IEEE 802.11g: 2400 ~ 2483.5 MHz ISM band
• IEEE 802.11n (5 GHz): 5150 MHz ~ 5250 MHz, 5725 MHz ~ 5850 MHz
• IEEE 802.11n (2,4 GHz): 2400 ~ 2483.5 MHz ISM band
• IEEE 802.11ac (draft) (5 GHz): 5150 MHz ~ 5250 MHz, 5725 MHz ~ 5850 MHz
Antennas
• Internal antennas
Security
• Wi-Fi Protected Access (WPA/WPA2)
• 64/128-bit WEP-encryption
• WPS 2.0 (PBC)
Device control
• Management via Web-interface
נתונים פיזיים
Measurements
63 x 44 x 23 mm
Weight
• 29.72 g
Power
• Powered via USB-port
Temperature
• Operating: 0 to 40 ° C
• Storage: -10 to 45 ° C
Humidity
• Operating: 10 to 75% non-condensing
• Operating: 5 to 75% non-condensing
Certificates
• FCC
• CE
• CSA
