ANT24-1801EOL EOS
תאור
D-Link, an industry leader in networking, introduces the ANT24-1801 18 dBi Directional Yagi Antenna designed to provide extended coverage for an existing 802.11b/g wireless network. The directional yagi design of the ANT24-1801 offers dramatically increased wireless signal coverage in a specific direction allowing for improved data throughput at further distances.
The D-Link 18 dBi Directional Yagi Antenna connects to a variety of wireless PCI adapters, wireless routers and acess points on the market today. Whether the wireless router or access point has a SMA or TNC connector, the ANT24-1801 comes with a RP-SMA to RP-TNC conversion adapter to accommodate either connector type.
The D-Link ANT24-1801 includes a mounting kit that allows for precise positioning and concentrated signal strength allowing for improved data throughput at further distances. The D-Link ANT24-1801 also includes a lightning surge protector, and a 0.5m (1.5 feet) cable. The ANT24-1801 is weatherproof and made of corrosion-resistant material to withstand harsh outdoor conditions and wind speeds up to 120 miles/hr (200km/hr).
Avoid the cost and complexity of adding additional wireless acess points or wireless repeaters when you can easily use the D-Link yagi antenna indoors or outdoors. Enjoy the benefits of wireless connectivity at greater distances and speeds throughout your indoor or outdoor wireless coverage area.
מאפיינים כללים
Directional antenna
Frequency band
• 2.3-2.5GHz
Gain
• 18 dBi
VSWR
• 1,5 max
Polarization
• Linear, vertical
HPBW
• Horizontal 15o
• Vertical 15o
Input power
• 50W (cw)
Resistance
• 50 ohm
Jack
• N-type ("Mom")
Cable adapter
• N-«Dad" in RP-SMA, length 0.5 m
• Cable loss per meter 0.83db
The theoretical transmission distance at a speed of 1 Mbit/s/11 Mbit / s (when operated with internal access points) *
• Up to 5km/2km
The theoretical transmission distance at a speed of 1 Mbit/s/11 Mbit / s (when working with external access points) *
• Up to 8km/3km
1. Distance calculation is based on the transmit power 15dbm (intra-TD), 19dbm (outside SC) with standard cable loss*
2. The transmission distance may depend on both antennas with the same characteristics with standard cable loss
3. The effective radius of action is based on EIRP (Effected Isotropic Radiation Power = power of the transmitter unit + antenna gain - cable loss)
4. On the range of factors may adversely affect the environment.
