ANT24-1200EOL EOS
תאור
The D-Link ANT24-1200 connects to any Air™, AirPlus™, AirPlusG+™, AirXtremeG™ or AirPremier™ Access Point or Wireless Gateway Router.
The antenna provides extended coverage for an existing 802.11b or 802.11g wireless local area network (WLAN), and uses a reverse SMA connector, and is easy to install to an access point or wireless gateway router with a reverse SMA connector.
It ships with a3 metre extension cable and mounting caps for easy installation.
Note: This product does not currently work with the enterprise DWL-1750 external wireless router and the DWL-1700AP external wireless access point
מאפיינים כללים
High Gain Directional Panel Antenna
ANT24-1200
Electrical Specification
Frequency range 2400 MHz - 2500 MHz
Gain 12 dBi
VSWR 1.5 : 1 Max.
Polarization Linear, vertical
HPBW / horizontal 80o
HPBW / vertical 23o
Front to back ratio 15 dB
Downtilt 0o
Power handling 50 W (cw)
Impedance 50 Ohms
Connector SMA female
Survival wind speed 180 km/hr
Temperature - 40 C to +80 C o o
Humidity 100% @ 25 C o
Lightning protection DC ground
Radome color White
Radome material ABS, UV resistant
Weight 0.19 kgw
Dimensions 330 x 93 x 20.7 mm
