DVG-N5402SPEOL EOS
נתב אלחוטי בתקן 802.11n עם שתי כניסות FXS, כניסת WAN ו-4 כניסות LAN + פורט USB
היכן לקנות
תאור
Internet Phone Solution for Home & SOHO
The D-Link DVG-N5402SP Wireless N VoIP Router allows you to take advantage of your DSL/cable modem connection to make inexpensive Internet phone calls. It combines the industry’s latest Voice over IP network technology with advanced communication features, and is compatible with phone services industry-wide. This VoIP Router connects you to up to two ordinary phone sets for phone calls, allowing you to make two separate calls simultaneously.
Superior voice quality
The DVG-N5402SP incorporates Quality of Service (QoS) to ensure that voice received through the Internet is the same as or even surpasses that of ordinary phones. It supports many useful functions like call transfer, caller ID display, 3-way conferencing, a phone book, speed dialing and hotlines to make it convenient to dial out or answer phone calls.
Complete security
The DVG-N5402SP supports voice VLAN to isolate your voice communication so it cannot be tapped over the network. It provides a lifeline phone port to relay your incoming and outgoing phone calls to PSTN for in case a network outage occurs. This guarantees that your phone connection will always be available.
Integrated wireless 4-port router
The DVG-N5402SP provides an 802.11n standard wireless LAN and router function with a built-in NAT/DHCP server to permit multiple computers to share an Internet broadband connection. Connect your wireless devices with high-speed 802.11n wireless networking. Also, with four integrated Switch Ethernet ports, four Ethernet-enabled computers and network devices can connect to the Internet.
מאפיינים כללים
Device Interfaces
• 1 port WAN 10/100Base-TX
• 4-port LAN 10/100Base-TX
• 1 telephone port PSTN lifeline
• 2 FXS ports
• 1 USB-host 2.0 (optional)
Indicators
• Power
• Provision
• Register
• WAN
• WLAN
• LAN 1 ~ 4
• LINE
• USB (optional)
SIP main functions
• Individual account for each port or a general account for all ports
• Identification of caller ID (Caller ID)
• Direct call IP-to-IP without SIP Proxy
• Numbering Plan (Digit Map), and phone book
• DNS SRV, SIP SRV
• Dialing E.164 (with an exclusion rule ENUM)
• Group, Pick Up
• Hot Line, Warm Line
• Setting up an interactive telephone answering (IVR)
• Message Waiting Indication (subscription)
• Visual message waiting indication (subscription)
• Music on Hold
• Outbound Proxy
• SIP INFO
• Three-way conference (Mode Ad Hoc, media server required)
• The main function calls (optional):
• Built-in Local Mixer
• Register up to three SIP-servers
  - Blocking anonymous calls
  - Lock and call filtering by IP-address of the caller
  - Call Forwarding (busy, no answer, unconditional)
  - History Call (status calls)
  - Call Hold
  - Call Interception
  - Call transfer to a fixed number (Call park) and the removal of the call off hold (Call Retrieve) (Support Proxy)
  - Call Transfer (Supports Proxy)
  - Call Waiting
  - The name of the caller and the call (FSK)
  - The "Do Not Disturb"
  - Caller ID Blocking
Voice Features
• Variable (dynamic) jitter-buffer
• Echo
• Automatic detection and switching of voice / fax / data
• Auto Gain Control (AGC)
• Codecs: G.711μ/A-law, G.729A/B/AB, G.723 (6.3/5.3 kbit / s), G.726, ILBC (13.33/15.2 kbit / s)
• Broad Voice (16 Kbit / s), G.722
• Comfort Noise Generation (CNG)
• DTMF detection and generation
• Inband or Out of Band DTMF event
• Packet Loss Concealment
• Support for voice / fax / modem (up to 33.6 kbit / s) over IP
• T.30 FAX bypass thought G.711
• T.38 real time FAX up to 14.4 kbit / s
• Voice Activity Detection (VAD)
• Detection and generation of caller ID: DTMF, FSK-BellCore, FSK-ETSI
• IGMP V1/V2/V3, Support Snooping and Proxy
Wireless Interface
• Access Point 802.11 b / g / n, Wi-Fi, support for up to 64 client associations
• Automatic selection of the wireless channel
• Supports Multi SSID (4 SSID)
• The default SSID Wireless-dlink
• Support for STA Mutual isolation
• Support for SES
• Support WDS
• Support for hidden SSID
• Support for the Prohibited List and the list of MAC-addresses
• Support for WMM
• Control wireless access based on MAC-address (deny or allow)
• Supports wireless security using encryption WEP (64/128 bit), WPA TKIP and WPA2
• Support for WPA/WPA2 TLS client
• Complies with IEEE 802.11n Draft 2.0 (2x2)
• Complies with IEEE 802.11g
• Complies with IEEE 802.11b
• Ability to send 2 HD streams over Wi-Fi
• WPS (Wi-Fi Protected Setup)
Management
• Automatic Provisioning (excl. Options TR069/TR104)
• Web-based user management
• User interface TELNET
• Save and restore the configuration file through the web-interface
• Call history (received, missed, blocked calls)
• Flat Call Detail Record output (CDR)
• Time synchronization in accordance with NTP (the default NTP-server D-Link)
• Password protection (web-interface and TELNET)
• Ping Test
• Reset to Factory
• SNMP v2 (excl. Options TR069/TR104)
• Static routes and default routes
• System status
• TFTP / FTP / HTTP-client for software upgrade
• Universal Plug and Play (UPnP) Internet Gateway Device (IGDv1.0)
• SNMP v1/v2c agent, SNMP MIBs
• Upload and download configuration file PSI
• TR-69 with TR-98, TR-104
WAN connection
• DHCP-client
• Authentication via PPPoE PAP / CHAP
• PPTP-client
• L2TP-client
• Static IP-address
• Support for USB HSDPA 3.5G modem
• USB 2.0 (optional)
QoS
• DiffServ (DSCP) or ToS IP Precedence tagging (WAN)
• Speed limit on the LAN port
• Speed limit on Port WAN (in increments of 64 Kb / s ~ 32 Mbit / s)
• Queue priority WAN port, first RTP
• 802.1Q and 802.1P tagging (VID 1 for VoIP-traffic, 4 VID for LAN-traffic)
NAT Traversal
• STUN-Client
• DDNS-client
• Specify the port range for SIP and RTP
• Static route
Security
• Built-in firewall
• Filtering of IP-addresses
• Filtering based on ports
• Filtering based on MAC-address
• Virtual server
• DMZ
• Protection against DoS attacks
• MD5 authentication for SIP
• Two privilege levels: Administrator and User
• VPN Pass-through with Multiple Sessions (IPSec, PPTP, L2TP)
נתונים פיזיים
Housing Dimensions (without antenna)
• 224 x 171 x 50 mm
Power
• Input: 100-240 VAC, 50/60 Hz
• Output: 12V / 2A
Power consumption
• 14 W
Temperature
• Operating: -10 to 40 C
• Storage: -20 to 60 C
Humidity
• Operating: 10 ~ 90%
• Storage: 5 ~ 95%
Electromagnetic compatibility (EMI)
• FCC class B, CE mark class B
Certificates Telecom
• FCC / PART 68
• CE / TBR21
תקנים
הורדות
איורים
DVG-N5402SP/B1
מראה מימין
מראה מאחורה
מראה מקדימה
דף מידע
ראה גם
