DIR-640L
נתב אלחוטי VPN התומך בטכנולוגיית Cloud, עד 300Mbps
היכן לקנות
תאור
Wireless VPN-Router DIR-640L, which combines the functions of a router, switch, 10/100, 802.11n wireless access point and firewall designed for network construction sector SOHO, which require maximum performance and security. Among small businesses increases the demand for network construction, and therefore companies are interested in the device, providing protection for the network. Acquisition Wireless VPN-router DIR-640L is a profitable investment, since the device supports a safe, comfortable setting mechanism, and provides maximum protection for the network of small office and home.
User-friendly interface
DIR-640L offers a user-friendly intuitive Web-based interface for configuration. Manage the settings available to the user as an administrator or a read / write. With the data access privileges, any authorized user can configure or access the management interface DIR-640L.
The service mydlink network management
Broadband VPN-router supports Cloud service mydlink Cloud, which allows the user to access the network, regardless of its location. With Internet-connected computer or mobile device with iOS or Android, you can use the view of clients connected to the router, change settings, or block access to the individual clients. Home users can check the most frequently visited Internet sites their children, and for the offices the ability to monitor network activity of workers.
Enterprise-class protection
DIR-640L perform secure data transmission over wireless networks using encryption WPA ™ or WPA2 ™. In addition, protecting the network from intruders and potential attacks by using a firewall, use a mechanism Network Address Translation (NAT) and Stateful Packet Inspection (SPI).
Advanced hardware features
DIR-640L can be connected to a cable or DSL-modem for high-speed public Internet access. Also, the device is equipped with a 4-port 10/100 Mbit / s, which supports full duplex mode, which allows you to connect up to 4 devices with interfaces Ethernet. To extend the wired network, simply add more switches. In addition, using DIR-640L, you can create a virtual private network (VPN) and provide secure remote access to a central network through the Internet for up to 25 users simultaneously.
VPN performance
For optimal VPN configuration, the router DIR-140L is equipped with a built-in VPN-client and the VPN-server, which keeps most of the required policies VPN. In this device, VPN support is implemented in hardware and manage up to 25 profiles VPN. DIR-640L supports the IPSec, PPTP, L2TP and GRE as a server, and allows you to handle the traffic pass-through. Advanced VPN configuration options include encryption, DES, key management IKE / ISAKMP, to desirable Main / Aggressive and authentication support VPN, using a database of 10 internal users.
מאפיינים כללים
Standards
• IEEE 802.11 b / g / n
• IEEE 802.3
• IEEE 802.3u
Ports
• 4-Port LAN 10/100 Mbit / s
• WAN port 10/100 Mbit / s
• USB 2.0 port
• COM-port RS-232
• Slot for Kensington lock
Indicators
• Power / Status
• WAN
• WLAN
• LAN 1/2/3/4
Device control
• Internet Explorer 6 or later, or other Java-enabled browser
Modes of Operation Firewall
• Level 3: NAT mode
• Port Forwarding
• Port Address Translation (PAT)
Secure VPN
• VPN-tunnels 25 (IPSec, PPTP, L2TP, GRE)
• IPSec LAN-to-LAN / Remote user
• IPSec/PPTP/L2TP Pass-through
• Client / server PPTP/L2TP
• IPSec NAT-Traversal
• XAUTH (Extended Authentication) for IPSec Authentication
• Encryption: DES
Secure Firewall
• Database of internal users (10 records)
Network Services
• Static IP-address
• DHCP-client for WAN-interface
• Internal DHCP-server
• Static Routes
• Convert DNS-name the remote gateway IP-address
• PPPoE for xDSL
• Russian PPPoE / PPTP (Dual Access)
• Quality of Service
• Dynamic DNS
Functions mydlink
• Remote control
• View the current bandwidth for outgoing / incoming traffic
• View client connections currently
• Displays your browsing history for each customer
• Lock / Unlock access to the client
• Detailed information on monitoring wireless network
• Access via the Web-browser or mobile app iOS or Android
תקנים
הורדות
איורים
DIR-640LAx
מראה מקדימה
מראה משמאל
מראה מאחורה
דף מידע
ראה גם
