DSL-2640U/B1A/T3AEOL EOS
Wireless N150 ADSL2+ Modem Router
Apraksts
	ADSL port and 4-port switch
	The router is equipped with an ADSL port to connect to an ADSL line. The built-in 4-port switch enables you to connect Ethernet-enabled computers, game consoles, and other devices to your network. In addition, any Ethernet port of the device can be used to connect to a private Ethernet line.
	Security
	The DSL-2640U wireless router includes a built-in firewall. The advanced security functions minimize threats of hacker attacks, prevent unwanted intrusions to your network, and block access to unwanted websites for users of your LAN.
	Wireless interface
	You are able to quickly create a wireless network at home or in your office, which lets your relatives or employees connect to your wireless network virtually anywhere (within the operational range of your wireless network). The router can operate as an access point for connecting wireless devices of the standards 802.11b, 802.11g, and 802.11n. The router supports multiple functions for the wireless interface: several security standards (WEP, WPA/WPA2), MAC address filtering, and the WPS function.
	Configuration and management
	You can configure and manage the settings of the DSL-2640U router via the user-friendly web-based interface (the interface is available in several languages).
Īpašības
	Hardware
	Interfaces
	• ADSL: one RJ-11 port
	• LAN: four RJ-45 10/100BASE-TX Fast Ethernet ports with auto-MDI/MDIX
	• WLAN: built-in 802.11b, g, n wireless interface
	Frequency band
	• 2412 ~ 2484MHz
	Data rate
	• 802.11b: 11, 5.5, 2, 1 Mbit/s
	• 802.11g: 54, 48, 36, 24, 18, 12, 9, 6 Mbit/s
	• 802.11n
	  HT20: 150, 130, 117, 104, 78, 52, 39, 26, 13 Mbit/s
	  HT40: 150, 130, 117, 104, 78, 52, 39, 26, 13 Mbit/s
	Transmitter output power
	The maximum value of the transmitter power will vary in accordance with the rules of the radio frequency regulation in your country
	• 802.11b: 16.5 ~ 18.5 dBm
	• 802.11g: 13.5 ~ 16.5 dBm
	• 802.11n: 13.5 ~ 16.5 dBm
	Modulation Schemes
	• 802.11b: CCK (11, 5.5 Mbit/s), DQPSK (2 Mbit/s), DBPSK (1 Mbit/s), DSSS
	• 802.11g: PSK / CCK, DBPSK, DQPSK, OFDM, BPSK, QPSK, 16QAM, 64QAM
	• 802.11n: PSK / CCK, DBPSK, DQPSK, OFDM, etc.
	ADSL standards
	• ADSL: Multi-mode, ANSI T1.413 Issue 2, ITU-T G.992.1 (G.dmt) Annex A, ITU-T G.992.2 (G.lite) Annex A, ITU-T G.994.1 (G.hs)
	• ADSL2: ITU-T G.992.3 (G.dmt.bis) Annex A/L/M, ITU-T G.992.4 (G.lite.bis) Annex A
	• ADSL2+: ITU-T G.992.5 Annex A/L/M
	Software
	WAN connection types
	• ADSL
	  PPPoE
	  PPPoA
	  IPoA
	  Static IP
	  Dynamic IP
	  Bridge
	• Ethernet
	  PPPoE
	  Static IP
	  Dynamic IP
	  Bridge
	Wireless network
	• IEEE 802.11n standard, IEEE 802.11b/g compliant
	• Support of guest wireless network
	• WEP encryption
	• WPA/WPA2 security with TKIP, AES and TKIP+AES
	• MAC-based access to wireless network
	• PIN and PBC methods of WPS
	• Advanced settings
	ATM/PPP protocols
	• Bridged and routed Ethernet encapsulation
	• VC/LLC-based multiplexing
	• ATM Forum UNI3.1/4.0 PVC (up to 8 PVCs)
	• ATM Adaptation Layer Type 5 (AAL5)
	• ITU-T I.610 OAM F4/F5 loopback
	• ATM QoS
	• PPP over ATM (RFC 2364)
	• PPP over Ethernet (PPPoE)
	• Keep-alive for PPP connections
	Network protocols and features
	• Additional IP address for LAN interface
	• Static IP routing
	• NAT (Network Address Translation)
	• DHCP server/client/relay
	• DNS relay
	• Dynamic DNS (DDNS)
	• VLAN support
	• IGMP proxy
	• IGMP snooping
	Firewall and access management functions
	• MAC filtering based on time of day and day of week
	• URL filter
	• Packet filtering (IP/ICMP/TCP/UDP)
	• Virtual servers
	• Prevention of DoS attacks
	• Intrusion detection system
	• DMZ
	• Port Triggering
	QoS
	• Interface grouping
	• VLAN priority (802.1p)
	• Multilingual web-based interface for configuration and management
	• Access via TELNET
	• Firmware upgrade via Web-based interface
	• Supports remote logging
Sertifikāti
Informācija pasūtījumam
DSL-2640U/B1A/T3A Wireless N150 ADSL2+ Modem Router
