DES-1016CEOL EOS
16-Port 10/100 Mbps Unmanaged Switch
Description
	The DES-1016C Unmanaged Switch is economical, plug-and-play networking switch solution for SOHO and small and medium businesses wanting to benefit from the increased bandwidth of Fast Ethernet. It provides 16 10/100 Mbps ports that enable you to easily expand your network and provide a quick way to upgrade your network to fast connectivity.
	Fast Networking Made Easy
	With data transfer speeds of up to 200 Mbps at full duplex, this switch is ideal for quick file transfers, online gaming and smooth streaming media. It features easy-to-access Ethernet
	ports with LED indicators per port to easily distinguish link status. Auto MDI/MDIX crossover
	makes connection a cinch; just plug in your cables and you’re ready to go.
	Conserve Energy
	The DES-1016C implements 802.3az Energy Efficient Ethernet, which saves energy and reduces heat automatically without sacrificing performance or functionality. The switch can detect when a connected computer is shut down or when there is no Ethernet traffic, and will put the port in standby mode, saving a substantial amount of power. In addition, the switch optimizes power usage for each port for the length of cable connected to it, using only as much power as is required. Both of these features work together to help you save power automatically.
	Reliable Plug and Play Installation
	The DES-1016C is Plug-and-Play device that requires no configuration, so setup is simple and hassle-free, and you can easily connect multiple computers, share files, music, and video across your home or small office network, or even create a multiplayer gaming environment. 802.3x flow control on each port minimizes dropped packets when the port’s receiving buffer is full, giving you a more reliable connection for all of your connected devices.
	Smooth Streaming
	This switch supports QoS, which prioritizes network traffic so that time-sensitive data is delivered efficiently, even during bursts of high data traffic. This helps ensure an optimal experience for streaming media and VoIP calls.
General features
	Device Interfaces
	• 16 10/100 Mbps LAN ports
	Standards
	• IEEE 802.3 10BASE-T
	• IEEE 802.3u 100BASE-TX
	• IEEE 802.3x Flow Control
	• IEEE 802.1p QoS
	Switching Capacity
	• 3.2 Gbps switching fabric
	Advanced Features
	• Auto MDI/MDIX crossover for all ports
	• Secure store-and-forward switching scheme
	• Full/half-duplex for Ethernet/Fast Ethernet speeds
	• Supports 9 216 byte jumbo frames
	• Back pressure at half-duplex operation
	• Wire-speed reception and transmission
	• Store and-Forward switching method
	• Auto-negotiation for each port
	• QoS (4 queues, strict mode)
	Data Transfer Rates
	• Ethernet:
	  • 10 Mbps (half duplex)
	  • 20 Mbps (full duplex)
	• Fast Ethernet:
	  • 100 Mbps (half duplex)
	  • 200 Mbps (full duplex)
	Transmission Method
	• Store-and-forward
	MAC Address Table Size
	• 8 000
	Packet Filtering/Forwarding Rates
	• Ethernet: 14 880 pps per port
	• Fast Ethernet: 148 800 pps per port
	RAM Buffer
	• 256 KB per device
	Physical Parameters
	LED Indicators
	• Per port: Link/Activity/Speed
	• Per device: Power
	Media Interface Exchange
	• Auto MDI/MDIX adjustment for all ports
	Dimensions
	• 282.2 x 151 x 44.5 mm
	Weight
	• 1.06 kg
	Power
	• 100 to 240 V AC
	Power Consumption
	• Power On (Standby): 0.79 watts
	• Maximum: 5 watts
	Temperature
	• Operating: 0В° to 40В°C
	• Storage: -40В° to 70В°C
	Humidity
	• Operating: 10% to 90% (Non-condensing)
	• Storage: 5% to 95% (Non-condensing)
	MTBF
	• 1 215 319 hours
	Maximum Heat Dissipation
	• 22.75 BTU/h
	Certifications
	• CE Class B
	• CE (LVD 2006/95/EC)
Certificates
Order info
DES-1016C 16-Port 10/100 Mbps Unmanaged Switch
