DCS-5211LEOL EOS
HD PoE PAN & TILT NETWORK CAMERA
Description
The D-Link DCS-5211L HD PoE Pan & Tilt Network Camera is a pan and tilt network camera that is ideal for small and medium business applications and remote monitoring over the Internet. It gives you detailed 24-hour remote surveillance of a large area by using a high-resolution HD image sensor for high-quality video and a built-in IR illuminator for low-light and dark surveillance. The DCS-5211L incorporates Power over Ethernet (PoE), allowing it to be installed in a variety of locations without the need for supplemental power cabling.
A COMPLETE SURVEILLANCE SYSTEM
The DCS-5211L includes a built-in CPU, allowing it to be used as a complete, standalone surveillance system. Recordings can be made continuously, whenever movement is detected, or according to a set schedule. E-mail notifications can be sent when specific events occur; keeping you informed of what is going on. The built-in microSD slot allows the camera to run independently, or can be used to continuously record video even if the network connection is lost. The DCS-5211L can also be used as part of a multi-camera surveillance system through the included D-ViewCam software, which supports the management of up to 32 cameras.
SHARP IMAGE MONITORING FROM DIFFERENT ANGLES
With sharp, responsive pan/tilt movement and 4x digital zoom, the D-Link HD PoE Pan & Tilt Network Camera gives you full control, so you can quickly scan a wide area from a variety of angles, and use the digital zoom to zoom in for more detail. The DCS-5211L can also be set to automatically move to specific preset positions, allowing the camera to patrol and secure a wide area.
MYDLINK™ FOR EASY SETUP AND REMOTE VIEWING ON YOUR PHONE
D-Link’s convenient mydlink™ zero-configuration setup gets you up and running in no time – just connect the DCS-5211L, then register the device on the mydlink™ website. The DCS-5211L will then automatically configure itself and connect to the mydlink™ service, which gives you convenient access to your video feeds through the mydlink™ website. You can even view your camera feeds on your smart phone or tablet with the mydlink iOS and Android apps so you can stay in touch while on the go.
General features
CAMERA SPECIFICATIONS
• 1/4” Megapixel Progressive CMOS sensor
• 5 meter IR illumination distance
• Minimum illumination 0 Lux with IR LED on
• Built-in Infrared-Cut Removable (ICR) filter module
• Built-in Passive Infra-Red (PIR)
• Fixed length 4.57 mm
• Aperture f1.9
• Angle of view:
(H) 45.7°
(v) 29.5°
(D) 52.9°
• Built-in Microphone/Speaker
VIDEO FEATURES
• Configurable image size, quality, frame rate, and bit rate
• Time stamp and text overlays
• Configurable motion detection windows
• Configurable shutter speed, brightness, saturation, contrast, mirror, flip
• Three configurable privacy mask zones
VIDEO COMPRESSION
• JPEG for still images
• H.264/MPEG4/MJPEG format simultaneous compression
• H.264/MPEG4 multicast streaming
VIDEO RESOLUTION
• 16:9 (support frame rate up to 30 fps)
• 1280 x 720
• 640 x 352
• 320 x 176
• 160 x 80
PAN/TILT/ZOOM
• Pan Range: -170° to 170°
• Tilt Range: -25° to 90°
• Digital Zoom: 4x2
• Manual pan speed: 1-10
• Manual tilt speed: 1-10
• Pre-set setting: 10 points
AUDIO COMPRESSION
ADPCM, PCM
NETWORK PROTOCOL SUPPORT
IPv4, ARP, TCP, UDP, ICMP, DHCP Client, NTP Client (D-Link), DNS Client, DDNS Client (D-Link), SMTP Client, FTP Client, HTTP Server, PPPoE, RTP, RTSP, RTCP, 3GPP
REMOTE MANAGEMENT
• Configuration accessible via web browser
• Take snapshots/video clips and save to local hard drive via web browser
SECURITY
• Administrator and user group protected
• Password authentication
• HTTP and RTSP digest encryption
SURVEILLANCE
• Record video continuously
• Record video according to a weekly schedule
• Record video when motion is detected
• Upload snapshots/video clips via e-mail
• Upload snapshots/video clips via FTP
SYSTEM REQUIREMENTS
• Operating System: Microsoft Windows 7/vista/XP SP3
• Browser: Internet Explorer 6 or higher, Firefox 3.5, Safari 4.0
SUPORTED MOBILE DEVICES
• Mobile devices with a 3GPP player, such as Packet video Player 3.0, QuickTime 6.5, or Real Player 10.5
• MyDlink™ app requires a mobile device running iOS or Android
Certificates
Order info
DCS-5211L HD PoE PAN & TILT NETWORK CAMERA
