Description
The outdoor enclosures provide a cost-effective solution for protecting your D-Link network camera from the rigors of outdoor use. The fixed-type enclosures include heavy-duty, angle-adjustable mounting brackets that can be used to secure the camera on a vertical or horizontal surface. These enclosures maximize the full potential of your D-Link network cameras to secure and protect your home and business.
The DCS-45 is IP66 certified for weatherproof and dustproof operation. The housing is complete with an adjustable semi-cable managed bracket.
General features
Dimensions
• 390 x 127 x 124mm
Weight
• 3.0kg
Material
• Aluminum housing
Color
• White
Certificates
Order info
DCS-45/B1 Outdoor Enclosure
