DEM-312GT2
1000Base-SX+ Multi-Mode SFP transceiver (up to 2 km)
Description
The DEM-312GT2 Gigabit SFP fiber transceiver is external transceiver designed for insertion in SFP (Small Form-Factor Pluggable) slot of network device for transmission and reception of data signals on the fiber cables. This transceiver provides high-speed and reliable distance (up to 2 km) data transfer.
The DEM-312GT2 transceiver uses standard duplex LC connector for fiber cable connection. It conforms to industry standards and is interoperable with D-Link Gigabit switches. All D-Link transceivers are hot-pluggable. Hot-swap capability allows network administrators to plug or unplug it from the SFP slot without having to turn off the power of the connected device.
General features
| General features | |
| Standard | • IEEE 802.3z 1000Base-SX+ |
| Wavelength | • 1310 nm |
| Data Rate | • 1.25 Gbps |
| Connector | • Duplex LC |
| Maximum Fiber Cable Length | • 2 km |
| Transmit Power Range | • -8 to -15 dBm |
| Receive Power Range | • -3 to -20 dBm |
| Sensitivity | • -20 dBm |
| Supported Features | • Hot swap • MSA compliant • RoHS compliant |
| Physical Parameters | |
| Power Support | • 3.3 V |
| Supply Current | • 220 mA |
| Temperature | • Operating: 0° to 70°C • Storage: -40° to 85°C |
| Humidity | • Operating: 0% to 85% • Storage: 0% to 85% |
| Dimensions | • 55.4 mm x 13.7 mm x 8.5 mm |
Certificates
Order info
DEM-312GT2/A1A 1000Base-SX+ Multi-Mode SFP transceiver (up to 2 km)
