Description
	24/7 Camera Surveillance
	The DCS-2210/2230 Full HD Cube Network Camera is a versatile surveillance solution that is perfect for monitoring low-light environments in your home or small office. It combines a high-resolution 2 Megapixel sensor with a built-in IR LED to help you keep watch over areas in complete darkness. The DCS-2210/2230 also includes a built-in IR cut filter, making it suitable for both day and night applications. Additionally, the DCS-2210/2230 is a complete system with a built-in CPU and web server that transmits high-quality video images for security and surveillance. The DCS-2210 includes support for Power over Ethernet(PoE), so the camera can be placed in areas where no power outlet is nearby. The DCS-2230 features 802.11n wireless, allowing the camera to be placed anywhere within range of your wireless network. The DCS-2210/2230 also offers simple installation, an intuitive web-based interface, and remote monitoring and motion detection features for a complete and cost-effective home security solution.
	Wireless N Connectivity (DCS-2230)
	The DCS-2230 includes 802.11n wireless for fast and easy integration into your existing network environment. Wireless N allows you to stream high-quality video to remote sites and mobile devices. A Site Survey feature also allows you to view and connect to nearby wireless networks with ease. The DCS-2210/2230 also includes a standard Ethernet port for connections to traditional wired networks.
	ePTZ For Surveying Regions Of Interest
	The ePTZ feature allows users to select a target region for close-up viewing simply by clicking on the video feed displayed within their browser. ePTZ makes use of the camera’s 2 mexapixel resolution to survey a large area effortlessly. Since ePTZ requires no moving parts, there is no need to worry about the camera having mechanical failures.
	Easy To Configure And Operate
	This network camera supports the Universal Plug-n-Play feature, which allows computers running on Windows XP/Vista/7 to automatically recognize the camera and add it to the network. Sign up with one of the free Dynamic DNS services available on the web to assign a name and domain to the camera (e.g. mycamera.dlinkddns.com), and remotely access the camera without having to remember your IP address. You may also view up to 32 cameras from a central location using the included D-ViewCam software. D-ViewCam has a robust set of features including automated e-mail alerts which can instantly inform administrators of suspicious or unusual activities.
General features
	Camera Hardware Profile
	• 1/2.7" 2 Megapixel progressive CMOS sensor
	• IR Illumination distance: 5 m
	• Minimum illumination: 0 lux with IR illumination
	• Built-in Infrared-Cut Removable (ICR) filter module
	• Built-in PIR (Passive Infrared) sensor
	• Built-in microphone and speaker
	• 10x digital zoom
	• Fixed length: 4.37 mm
	• Aperture: F2.0
	• Angle of view:
	  (H) 67.4°
	  (V) 40.8°
	  (D) 75°
	Image Features
	• Configurable image size, quality, frame rate, and bit rate
	• Time stamp and text overlays
	• Configurable motion detection windows
	• 3 configurable privacy mask zones
	• Configurable shutter speed, brightness, saturation, contrast, and sharpness
	Video Compression
	• Simultaneous H.264/MPEG-4/MJPEG format compression
	• JPEG for still images
	Video Resolution
	• 16:9 - 1920 x 1080 (up to 15 fps), 1280 x 720, 800 x 450, 640 x 360, 480 x 270, 320 x 176, 176 x 144 up to 30 fps
	• 4:3 - 1440 x 1080 (up to 15 fps), 1280 x 960, 1024 x 768, 800 x 600, 640 x 480, 320 x 240, 176 x 144 up to 30 fps
	Audio Support
	• G.726
	Device Interfaces
	• 10/100 BASE-TX Ethernet port
	• 802.11n wireless
	• 1 DI / 1 DO
	• MicroSD card slot
	Network Protocols
	• IPv4, TCP/IP, UDP, ICMP, DHCP Client, NTP Client (D-Link), DNS Client, DDNS Client (D-Link), SMTP Client, FTP Client, HTTP / HTTPS, Samba Client, PPPoE, UPnP Port Forwarding, RTP / RTSP/ RTCP, IP filtering, 3GPP, IGMP, ONVIF Compliant
	Security
	• Administrator and user group protection
	• Password authentication
	System Requirements for Web Interface
	• Operating System: Microsoft Windows 7/Vista/XP/2000
	• Browser: Internet Explorer, Firefox, Netscape, Opera
	Event Management
	• Motion detection
	• PIR motion detection
	• Event notification and upload snapshots/video clips via HTTP, SMTP, or FTP
	• Supports multiple HTTP, SMTP, and FTP servers
	• Multiple event notifications
	• Multiple recording methods for easy backup
	Remote Management
	• Configuration accessible via web browser
	• Take snapshots/video clips and save to local hard drive or NAS via web browser
	Mobile Support
	• Windows 7/Vista/XP system, Pocket PC, or mobile phone with 3GPP playback support
	D-ViewCam™ System Requirements
	• Web Browser: Internet Explorer 6 or higher
	• Protocol: Standard TCP/IP
	D-ViewCam™ Software Functions
	• Remote management/control of up to 32 cameras
	• Viewing of up to 32 cameras on one screen
	• Supports all management functions provided in web interface
	• Scheduled motion triggered, or manual recording options
Certificates
Order info
DCS-2230 Full HD Cube Network Camera
