DSH-C310
Omna 180 Cam HD
Where to buy
Description
View live video, receive motion detection notifications, playback recorded videos, and more. Download the free Omna app for iPhone, iPad, and iPod Touch from the App Store.*
The Omna 180 Cam HD is D-Link’s first HomeKit-enabled camera and combines the company’s long history of producing award-winning network surveillance devices with the Apple HomeKit ecosystem. The DSH-C310’s elegant, stylish design fits effortlessly into the modern home, while still packing a full suite of high-end features including a 180-degree wide-angle lens, Full HD 1080p resolution, two-way audio, night vision, and a microSD card slot.
Simply place the camera against a wall and the 180-degree wide-angle lens can capture the entire room on its own. Full HD 1080p resolution allows users to see every little detail. Infra-red (IR) LEDs are hidden behind the black bands on either side of the lens, and are only visible when the camera is operating in dark environments. To meet today's on-the-go lifestyle, the Omna 180 Cam HD can be used directly from your iPhone®, iPad®, or iPod® touch, or use the free Omna app for more control and advanced settings—so you can rest assured knowing you'll receive instant notifications no matter where you are.**
General features
Hardware Profile
• 1/3” 3 Megapixel progressive CMOS sensor
• 5 meter IR illumination distance
• Minimum illumination:
  0.3 lux (IR off; color mode)
  0 lux (IR on; B/W mode)
• Built-in Infrared-Cut Removable (ICR) Filter module
• Aperture: F2.0
• Angle of view:
  (H) 180°
  (V) 66°
  (D) 180°
• Built-in microphone and speaker (5-meter range)
Camera Housing
• Aluminum housing
LED Indicators
• Power/Status LED
Image Features
• Automatic image size and quality adjustment based on network quality***
• Configurable motion detection windows
• Pre-event recording
Video Compression
• Simultaneous H.264/MJPEG format compression
• H.264 SRTP streaming
Video Resolutions
• 16:9 - 1920 x 1080,1280 x 720, 640 x 360 up to 30 fps
Audio Compression
• AAC
External Device Interface
• microSD card slot****
Network Protocols
• IPv6
• IPv4
• ARP
• TCP/IP
• UDP
• ICMP
• DHCP client
• NTP client (D-Link)
• DNS client
• Bonjour
• HTTPS configuration
Wireless Security
• WPA/WPA2-PSK
Event Management
• Motion detection
• Event notification
Mobile Support
• OMNA mobile app for iPhone, iPad, iPod Touch
Physical Parameters
Weight
• 232 grams
Dimensions
• Diameter: 58 mm
• Height: 132.2 mm
External Power Adapter
• Input: 100 to 240 V AC, 50/60 Hz
• Output: 5 V DC, 2 A
Temperature
• Operating: 0° to 40°C
• Storage: -20° to 70°C
Humidity
• Operating: 20 to 80% non-condensing
• Storage: 5% to 95% non-condensing
Certifications
• CE
• CE LVD
• ICES
• SRRC
• TRA
• VCCI
• FCC
• NCC
• KCC
• C-Tick
* To control this HomeKit-enabled accessory automatically and away from home, an Apple TV with tvOS 10.1 or later or an iPad with iOS 10.1 or later and an iPhone or iPad with iOS 10.1 or later is recommended.
** Notification transmission may be dependent on network stability and other extraneous factors.
*** The resolution and frame rate will be adjusted automatically based on network quality. The quality of HD streaming is dependent on network bandwidth.
**** A microSD card is not included. SDHC Class 10 is recommended.
Certificates
Order info
DSH-C310  Omna 180 Cam HD
Pictures
DSH-C310/Ax
Left side view
Back view
Back view
View from the right
Front view
Downloads
Support Resources
