DES-1226GEOL EOS
Description
24 10/100Mbps Ports for Workstations Connection
The switch provides 24 10/100Mbps ports supporting auto-sensing and auto-negotiation of network speeds and full/half duplex. These ports can connect to workstations and print servers, giving each a dedicated bandwidth. All ports support auto MDI/MDIX cross-over, allowing you to connect to any node without the need to change your usual straight-through twisted-pair cables.
2 Combo 1000BASE-T/SFP for Flexible Gigabit Connection
2 combo 1000BASE-T/SFP are provided for flexible copper or fiber Gigabit connection. You can select to install optional transceivers in the SFP slots for short, medium or long-distance fiber backbone attachment. Use of the SFP will disable their corresponding built-in 1000BASE-T connections.
Port Trunks for Aggregated Bandwidths
Ports can be combined together to create multi-link load-sharing aggregated bandwidths to a server or a network backbone. To expand the network, you can also make use of the port trunks to eliminate bottlenecks between the cascaded switches. The switch allows you to combine multiple ports per trunk, and to create multi-link port trunks.
VLANs for Enhanced Security & Performance
The switch support VLANs to let you improve security and bandwidth utilization by limiting the broadcast domains and confining intra-group traffic within their segments. To segment up the network, VLAN-supported workstations and servers that are connected to the switch can be grouped into different Virtual LANs (VLANs).
Quality of Service Support
The switch supports Layer 2 802.1p Priority Queue control to prioritize network packets. Classification of users' data priorities can be based on a data packet Priority Queue. This QoS function support allows you to run bandwidth-intensive and delay-sensitive applications and to attach video servers to the switch for video conference.
Port Mirroring
The switch supports port mirroring to assist network traffic monitoring. The network administrator can use this function as a diagnostic tool or debugging feature, especially when fending off an attack. It enables you to keep close track of switch performance and alter it if necessary. Port mirroring can be managed locally or remotely. The administrator places a protocol analyzer on the port receiving the mirrored data to monitor each segment separately. The analyzer captures and evaluates the data without affecting the client on the original port.
General features
Port Standards & Functions
- IEEE 802.3 10BASE-T Ethernet (twisted-pair copper)
- IEEE 802.3u 100BASE-TX Fast Ethernet (twisted-pair copper)
- IEEE 802.3ab 1000BASE-T Gigabit Ethernet (twisted-pair copper)
- IEEE 802.3z Gigabit Ethernet (fiber)
- ANSI/IEEE 802.3 NWay auto-negotiation
- IEEE 802.3x Flow Control
- Port mirroring
Number of Ports
- 24 10BASE-T/100BASE-TX ports
- 2 combo 1000BASE-T/SFP *
* Use of the SFP will disable their corresponding 10/100/1000BASE-T connections
SFP Support
- IEEE 802.3z 1000BASE-LX (DEM-310GT transceiver)
- IEEE 802.3z 1000BASE-SX (DEM-311GT/DEM-312GT2 transceiver)
- IEEE 802.3z 1000BASE-LHX (DEM-314GT transceiver)
- IEEE 802.3z 1000BASE-LX (DEM-315GT transceiver)
Protocol
CSMA/CD
Data Transfer Rates
- Ethernet:
10Mbps (half duplex)
20Mbps (full duplex)
- Fast Ethernet:
100Mbps (half duplex)
200Mbps (full duplex)
- Gigabit Ethernet:
2000Mbps (full duplex)
Topology
Star
Network Cables
- UTP Cat. 5, Cat. 5e (100 m max.)
- EIA/TIA-568 100-ohm STP (100 m max.)
Full/half Duplex
- Full/half duplex for 10/100Mbps speeds
- Full duplex for Gigabit speed
Media Interface Exchange
Auto MDI/MDIX adjustment for all twisted-pair ports
LED Indicators
- Per port: Link/Act, Speed
- Per device: Power/CPU
Quality of Service (QoS)
- 802.1p Priority Queues
- Maximum number of queues: 2
Port Trunks
- 2 10/100Mbps port trunk groups (up to 12 10/100Mbps ports per trunk)
- 1 Gigabit port trunk (2 Gigabit ports per trunk)
VLAN
- 802.1Q VLAN
- Maximum number of VLAN: 64 per device
User Access Security
- MAC-based access control (64 static entries)
Management & Configuration
- Web-based configuration
- Windows-based utility
- Configuration reset through software or hardware (reset button)
- SNMP v.1 with MIB-II (RFC 1213), private MIB support
Port Mirroring
Performance
Transmission Method
Store-and-forward
MAC Address Table
8K entries per device
MAC Address Learning
Automatic update
Packet Filtering/Forwarding Rates (half duplex)
Maximum 1,488,095 pps per port
RAM Buffer
256KB per device
Certificates
Order info
Smart 10/100Mbps Switch
DES-1226G 24 10/100BASE-TX ports, 2 combo 1000BASE-T/SFP
Optional SFP Transceiver
DEM-310GT SFP transceiver for 1000BASE-LX, single-mode fiber, max. distance 10km, 3.3V
DEM-311GT SFP transceiver for 1000BASE-SX, multi-mode fiber, max. distance 550m, 3.3V
DEM-312GT2 SFP transceiver for 1000BASE-SX, multi-mode fiber, max. distance 2km, 3.3V
DEM-314GT SFP transceiver for 1000BASE-LHX, single-mode fiber, max. distance 50km, 3.3V
DEM-315GT SFP transceiver for 1000BASE-LX, Single-mode fiber, max. distance 80km, 3.3V
