DCS-5220EOL EOS
Wireless Pan/Tilt Internet Camera
Where to buy
Description
POWERFUL SURVEILLANCE
IP surveillance systems are quickly gaining ground over conventional CCTV security cameras due to superior performance and reduced cost. The D-Link DCS-5220 wireless Internet camera is a powerful surveillance system that features 802.11g wireless connection and the ability to view live video streams from a 3G mobile phone or PDA. Designed as a standalone system complete with CPU and web server, light sensitive lens, motorized pan/tilt, digital zoom, and advanced video/sound surveillance remote monitoring utility, and this camera presents a powerful yet low-cost solution for demanding home/offce security needs.
SHARP IMAGE MONITORING FROM DIFFERENT ANGLES
Equipped with a light sensitive lens, this camera is capable of capturing video in rooms with minimal lighting. It features a motorized pan/tilt capability, allowing images to be monitored from different angles, and a digital zoom for greater remote viewing options. This camera allows users to monitor video and audio using an Internet browser from any where in the world. Simple installation procedures, along with the built-in web-based interface, offer easy integration to any network environments.
VIEW LIVE VIDEO FROM 3G MOBILE PHONE
The live camera feed of the camera can be pulled from the 3G cellular network by using a compatible cell phone or PDA with a 3G video player. From anywhere within the 3GPP service area, users are offered a fexible and convenient way to remotely monitor a home or offce in real time.
WIRED & WIRELESS ACCESS
For effective surveillance in and around a building, this camera comes with a built-in high-speed 802.11g wireless network interface, allowing images to be transmitted at up to 54Mbps wireless speed. In addition, a 10/100BASE-TX Ethernet port is also provided for convenient connection to an Ethernet network or to a broadband Internet via a gateway router. The camera can be accessed and viewed from any network place as a device on the network
INTELLIGENT & EASY TO USE
Instead of recording 24 hours a day, 7 days a week, images can be recorded to a computer hard drive only when motions are detected. This saves disk space and eliminates the time wasted to view unnecessary images. Images can be recorded manually or according to a pre-set schedule. Playback consumes little time with triggered event browsing and fast database searching. Software is included to let users view up to 16 cameras on a single computer screen at one central location. Users can set up automated e-mail alerts for sending through the Internet to be alarmed instantly of all unusual happenings. The camera adheres to the Universal Plug-n-Play specifcation, which allows computers running Windows XP/ME to automatically recognize the camera and add it to the network. By signing up with one of the many free Dynamic DNS services available on the web, users can assign an easy-to-remember name and domain to the camera (e.g. ww.mycamera.myddns.com). This allows them to remotely access the camera without having to remember the IP address, even if their Internet Service Provider has changed it.
General features
NETWORk PROTOCOL SUPPORT
+  TCP/IP, RTSP, RTP, RTCP, HTTP, SMTP, FTP, NTP, DNS, DHCP, UPnP, DDNS
BUILT-IN NETWORk INTERFACES
+  802.11g wireless LAN
+  10/100BASE-TX Ethernet port
VIDEO ALGORITHM SUPPORT
+  JPEG for still image
+  Enhanced video compression using MPEG4 Simple Profle
VIDEO RESOLUTION
+  Up to 30fps at 160 x 120
+  Up to 30fps at 176 x 144
+  Up to 30fps at 320 x 240
+  Up to 30fps at 640 x 480
VIDEO FEATURES
+  Adjustable image size and quality
+  Time stamp and text overlays
+  3 confgurable motion detection windows
+  Flip & mirror
VIDEO BIT RATE
+  20k to 4M
CAMERA SPECIFICATIONS
+  1/4-inch CMOS sensor
+  0.5 Lux @ f1.4
+  AGC/AWB/AES
+  Electronic shutter: 1/60 to 1/15000 sec.
+  Standard fxed mount type lens 4mm, f2.0
+  62 degrees feld of view
PAN/TILT/ZOOM
+  Pan range: +/- 135
+  Tilt Range: +90 to -45
+  Digital zoom: 4x
AUDIO
+  Sample rate: 16k to 128k (AAC), 4.75k to 12.2k (GSM-AMR)
MICROPHONE
+  Directivity: omni-directional
+  Frequency: 50 to 16000Hz
+  S/N ratio: more than 60dB
WIRELESS TRANSMIT OUTPUT POWER
+   16dBm (typical)
Wireless Receive Sensitivity
For 802.11b:
(Typically @PER < 8% packet size
1024 @ 25º C +/- 5º C)
+  11Mbps (CCk): -80 dBm
+  5.5Mbps (CCk): -83 dBm
+  2Mbps (QPSk): -84 dBm
+  1Mbps (BPSk): -87 dBm
For 802.11g:
+  54Mbps (OFDM): -65 dBm
+  48Mbps (OFDM): -66 dBm
+  36Mbps (OFDM): -70 dBm
+  24Mbps (OFDM): -72 dBm
+  18Mbps (OFDM): -77 dBm
+  12Mbps (OFDM): -79 dBm
+  9Mbps (OFDM): -81 dBm
+  6Mbps (OFDM): -82 dBm
WIRELESS LAN ANTENNA
Datachable 2dBi dipole antenna with reverse SMA connector
SECURITY
+  Administrator and user group protected
+  Password authentication
+  Wireless LAN security: 64/128-bit WEP and WPA-PSk data encryption
SURVEILLANCE SOFTWARE FUNCTIONS
+  Remote management/control of up to 16 cameras
+  Viewing of up to 16 cameras on one screen
+  Supports all management functions provided in web interface
+  Scheduled motion triggered, or manual recording options
REMOTE MANAGEMENT
+  Confguration accessible via web browser
+  Take snapshots/video clips and save to local hard drive via web browser
SURVEILLANCE
(Motion detection weekly schedule)
+  Upload snapshots/video clips via email
+  Upload snapshots/video clips via FTP
VIEWING SYSTEM REQUIREMENTS
+   Operating System: Microsoft Windows XP, 2000, ME
+   Browser: Internet Explorer v6.0 or above
SUPPORTED PDA, MOBILE PHONES & SOFTWARE
+  Handsets with 3GPP player
+  Packet Video Player 3.0
+  QuickTime 6.5
+  Real Player 10.5
+  Windows ME, 2000, XP
Certificates
Order info
DCS-5220   Wireless SecuriCam Pan&Tilt Internet Camera with 3G Mobile video
Pictures
DCS-5220
Front view
Back view
Downloads
Support Resources
