DWA-140EOL EOS
Description
ULTIMATE PERFORMANCE
The DWA-140 RangeBooster N USB adapter is a draft 802.11n client device that delivers unrivaled wireless performance for the PC. Users can easily upgrade to the next generation of wireless technology by adding this RangeBooster N adapter to access network high-speed Internet connection while sharing photos, fles, music, video, printers, and storage. Enhance Internet experience with a faster wireless connection and enjoy smooth digital phone calls, gaming, downloading, and video streaming.
GET CONNECTED, STAY CONNECTED
Powered by RangeBooster N technology, this adapter provides very high wireless performance. This high performance wireless adapter is designed for use in bigger homes and for users that demand higher networking performance. Maximize wireless performance by connecting this adapter to a RangeBooster N router and stay connected from virtually anywhere in your home. It can also be used with 802.11g and 802.11b wireless networks to enable signifcantly improved reception. This adapter supports WPA/WPA2 security and WEP data encryption to help prevent outside intrusion and protect your personal information from being exposed.
EASY TO SETUP, EASY TO USE
D-Link’s Quick Setup Wizard provides you with an easy way to setup your USB adapter. The Wireless Manager included with this product helps keep track of all your most frequently accessed networks. The addition of the Wi-Fi Protected Setup (WPS) function provides advanced security features that remain simple enough for the average user to confgure correctly. This function allows for devices to undergo an easy one-time click-button confguration for establishing connection with an access point or wireless router without the need of manually setting up complex encryption codes. With unmatched wireless performance, reception, and security, this adapter is the best choice for easily adding or upgrading wireless connectivity to your computer.
General features
SYSTEM REQUIREMENTS
+  Windows XP SP2, 2000 SP4, or Vista
+  CD-ROM drive
+  20MB hard disk space
+  Available USB port
STANDARDS
+  IEEE 802.11n (draft)
+  IEEE 802.11g IEEE 802.11g
+  IEEE 802.11b IEEE 802.11b
+  USB 2.0 USB 2.0
FREQUENCY RANGE
+  2412 to 2462MHz (North America) 2412 to 2462MHz (North America)
+  2412 to 2462MHz (General Europe) 2412 to 2462MHz (General Europe)
EMISSION SCHEMES
+  DSSS, OFDM
DATA MODULATION SCHEMES
DBPSK, DQPSK, CCK and OFDM
(BPSK/QPSK/16-QAM/64-QAM)
DATA RATES
+  802.11g: 6/9/12/18/24/36/48/54Mbps
+  802.11b: 1/2/5.5/11Mbps
+  802.11n: 30/60/90/120/180/240/260/300Mbps
TRANSMIT OUTPUT POWER (TYPICAL)
+  18dbm (802.11 b) 18dbm (802.11 b)
+  14dbm (802.11 g/n) 14dbm (802.11 g/n)
ANTENNAS
+  Two integrated antennas
SECURITY
+  64/128-bit WEP data encryption
+  Wi-Fi Protected Access (WPA, WPA2)
OPERATING VOLTAGE
5VDC +/- 10%
POWER CONSUMPTION (802.11N)
+   TX: 460mA
+   RX: 240mA
DIAGNOSTIC LEDS
+  Activity
DIMENSIONS
86 x 28 x 12 mm
OPERATING TEMPERATURE
0º to 40º C
STORAGE TEMPERATURE
-20º to 65º C
OPERATING HUMIDITY
10% to 90% non-condensing
STORAGE HUMIDITY
5% to 95% non-condensing
CERTIFICATIONS
+  FCC Class B
+  CE
+  C-Tick
+  IC
+  Wi-Fi
+  WPS Certifed
Certificates
Order info
DWA-140 RangeBooster N USB 2.0/1.1 adapter is a draft 802.11n
