Description
INTERNET OR TRADITIONAL PSTN PHONE FROM THE SAME CORDLESS HANDSET
The DPH-300S is a dual-mode IP phone that provides IP telephony and traditional phone connection in a single handset. It allows you to take advantage of your DSL/cable modem connection to make inexpensive Internet phone calls. This cordless phone operates in two modes: it is a normal DECT cordless phone when you connect it to an ordinary PSTN connection, and it is an IP phone when you connect it to the Internet through broadband. Because the DPH-300S has embedded VoIP functionality, you don’t need to use your computer and microphone to make IP calls - unlike PC-based softphones such as Skype.
RELIABLE CONNECTION & CLEAR VOICE
The DPH-300S delivers superior call quality with features that include voice activity detection (VAD), comfort noise generation (CNG), silence suppression, echo cancellation, adaptive jitter buffer, and lost packet recovery. It combines the industry’s latest Voice over the IP network technology with advanced communication features, and is compatible with industry-wise phone service.
SURF INTERNET WHILE MAKING INTERNET PHONE CALLS
The DPH-300S provides an Ethernet WAN port to connect to a DSL modem, cable modem, or to your broadband router. Once connected and logged on to the Internet, you are ready to make and receive calls. In addition, it provides an extra LAN port for connection to your PC’s Ethernet interface. This allows you to talk on the IP Telephone while browsing web sites, send e-mail, transfer files and do other network tasks.
QUALITY OF SERVICE AND SECURITY
The DPH-300S supports voice VLAN to isolate your voice communication so it cannot be tapped over the network. It provides priority queues to streamline traffic so web browsing and Internet download will not interfere with voice traffic and degrade Internet phone quality.
General features
GENERAL FUNCTIONS
+ WAN connection: through 10/100BASE-TX Ethernet port
+ Dialing via Ethernet port
+ LAN (PC) connection: through 10/100BASE-TX Ethernet port
+ PSTN connection: through RJ-11 phone port
+ Dialing via PSTN to standard telephone numbers
+ Voice Activity Detection (VAD) /Comfort Noise
Generation (CNG)
+ Configurable comfort noise insertion and handset echo cancellation
+ Audio Compression: G.711, G.726, G.729, iLBC
+ PPPoE, Static IP, DHCP Client support
+ Supports TCP/IP, UDP, RTP and RTCP
+ Lost packet recovery ability for improved voice quality
+ Adjustable speaker / ringer volume control
+ Dialing by last 10 calls
+ Call Log (Missed, Received, Dialed)
+ 3-way conference and attending/blind call transfer
HARDWARE DECT FUNCTIONS
+ Frequency: 1880 to 1900 MHZ
+ 10 RF channels
+ GAP (Generic Access Profile) Compatible
+ Can register up to 5 handsets
+ Outdoor range: 300 meters
+ Indoor range: 50 meters
+ Handset standby time: 150 hours
+ Handset talk time: 10 hours
+ Handset caller ID function: FSK, DTMF
+ Handset phonebook memory: 50 locations
+ Intercom
+ Call transfer of external calls (when using two or more handsets)
+ Ringer melody selection: 9 different melodies
+ Ringer volume adjustment: 9 levels
+ Handset earpiece volume setting: 9 levels
+ Delete single or all records in phonebook
+ Redialing and preparation dialing functions
+ Page on base unit to look for the handset easily
+ Clicking key tone ON or OFF
+ Speakerphone
+ Hand-free dialing
SOFTWARE FUNCTIONS
+ Voice Activity Detection (VAD) /Comfort Noise Generation (CNG)
+ Configurable comfort noise insertion and handset echo cancellation (G.168)
+ VoIP NAT traversal Support by SIP/STUN
+ Support TCP/IP, UDP, RTP and RTCP
+ Adjustable speaker/ringer volume control
+ Call Control Protocol in SIP
+ HTTP 1.0 (RFC 1945) Embedded web server
+ Auto-Provisioning mechanism via automated centralized configuration file
+ Configuration Restore/Backup
+ TELNET support
+ TFTP client for providing firmware upgrade and configuration file download
+ SIP Authentication with password encryption (eg.MD5) and HTTP Digest Authentication
