Quick find
Product features:
16-Port Unmanaged Gigabit Switch
EOL EOS
General features:
Number of Ports
• Sixteen 10/100/1000 Gigabit ports
Standards
• IEEE 802.3 10BASE-T Ethernet
• IEEE 802.3u 100BASE-TX Fast Ethernet
• IEEE 802.3ab 1000BASE-T Gigabit Ethernet
• ANSI/IEEE 802.3 NWay auto-negotiation
• IEEE 802.3x Flow Control
Data Transfer Rates
• Ethernet:
• 10 Mbps (half duplex)
• 20 Mbps (full duplex)
• Fast Ethernet:
• 100 Mbps (half duplex)
• 200 Mbps (full duplex)
• Gigabit Ethernet:
• 2000 Mbps (full duplex)
Network Cables
• 10BASE-T:
• UTP CAT 3, 4, 5/5e (100 m max)
• EIA/TIA-586 100-ohm STP (100 m max)
• 100BASE-TX, 1000BASE-T:
• UTP CAT 5/5e (100 m max)
• EIA/TIA-568 100-ohm STP (100 m max)
Functionality
D-Link Green Features
• IEEE 802.3az Energy Efficient Ethernet (EEE)
• Link status detection power saving
• Cable length detection power saving
• RoHS Compliance
LAN Features
• Back pressure at half-duplex operation
• Auto MDI/MDIX
• Wire speed reception and transmission
• Store-and-Forward switching method
• 8K MAC addresses
• 4Mbits RAM for data buffering
• Jumbo Frames: 9216 Bytes
• Switching Capacity: 32Gbps
Port Packet Filtering
• 10M: 14,880 pps
• 100M: 148,800 pps
• 1000M: 1,488,000 pps
LEDs
• Power LED
• 16 Link/Activity/Speed LEDs (one per port)
Power Inputs
• 100 to 240V AC Input
Power Consumption
• Standby: 4.48 watts
• Maximum: 9.84 watts
Heat Dissipation
• Standby: 15.2768 Btu/h
• Maximum: 33.5544 Btu/h
MTBF
• 795,539 hours
Dimensions
• 280 x 125 x 44 mm (11.02 x 4.92 x 1.73 inches)
Weight
• 1.06 kg (2.34 lbs)
Operating Temperature
• 0 to 40 °C (32 to 104 °F)
Storage Temperature
• -10 to 70 °C (14 to 158 °F)
Humidity
• 5% to 90% non-condensing
Certifications
• FCC Class A
• ICES-003 Class A
• CE Class A
• C-Tick Class A
• CB
• cUL
Products | Support  | News  | About |
