Quick find
Product features:
12 combo 10/100/1000/ SFP ports L2 Managed Gigabit Ethernet Switch
EOL
General features:
Interfaces
• 12 Combo 1000Base-T/SFP Ports
• 1 RS-232 Console Port
• 1 RJ-45 OOB Management Port
Performance
• Switching Capacity: 24 Gbps
• Packet Performance Rate: 17.86 Mpps
• CPU: 266 MHz
• Packet Buffer: 1 MB
• Flash Memory: 32 MB
• DRAM: 128 MB
Power
Internal Power Supply
• AC Power: 90 to 264 V AC, 47/63 Hz
• DC Power: -36 to -72 V DC
Software Features
Stackability
• Virtual Stacking
• D-Link Single IP Management (SIM)
• Up to 32 units per Virtual Stack
L2 Features
• MAC Address Table: 16K entries
• Flow Control
- 802.3x Flow Control
- HOL Blocking Prevention
• Jumbo Frames up to 13 Kbytes
• 802.3ad Link Aggregation
- Max. 6 groups per device, 8 ports per group
• Spanning Tree Protocols
- 802.1D STP
- 802.1w RSTP
- 802.1s MSTP
- BPDU Filtering
- Root Restriction
• Loopback Detection
• L2 Protocol Tunneling
• Port Mirroring
- One-to-One
- Many-to-One
- Flow-based
- RSPAN Mirroring
• Ethernet Ring Protection Switching (ERPS)
L2 Multicasting
• IGMP Snooping
- IGMP v1/v2/v3 Snooping
- Supports 1024 IGMP groups
- Port/Host-based IGMP Snooping Fast Leave
• MLD Snooping
- MLD v1/v2 Snooping
- Support 1024 MLD Groups
- Host-based MLD Snooping Fast Leave
• IGMP/MLD Proxy Reporting
• IGMP Filtering
- Up to 60 IGMP filtering profiles, 128 ranges per profile
VLAN
• VLAN Group
- Max. 4K VLAN Groups
• GVRP
- Max. 255 Dynamic VLAN Groups
• 802.1Q Tagged VLAN
• Port-based VLAN
• 802.1v Protocol VLAN
• Double VLAN (Q-in-Q)
- Port-based Q-in-Q
- Selective Q-in-Q
• VLAN Translation for single/double tagged packets
• Voice VLAN
• MAC-based VLAN
• Subnet-based VLAN
• ISM VLAN
• Asymmetric VLAN
• Private VLAN
• VLAN Trunking
L3 Features
• Max. 32 IPv4/v6 Interfaces
L3 Routing
• 32 IPv4/v6 static route entries
QoS (Quality of Service)
• IEEE 802.1p
• DSCP
• 8 queues per port
• Queue Handling
- Strict Priority
- Weighted Round Robin (WRR)
- Strict + WRR
• Supports following actions for flows
- Remark 802.1p Priority Tag
- Remark TOS/DSCP Tag
- Bandwidth Control
- Flow Statistics
• CoS based on
- Switch Port
- VLAN ID
- 802.1p Priority Queues
- MAC Address
- IPv4/v6 Address
- DSCP
- Protocol Type
- IPv6 Traffic Class
- IPv6 Flow Label
- TCP/UDP Port
- User-Defined Packet Content
• Three Color Marker
- trTCM
- srTCM
• Bandwidth Control
- Port-based (Ingress/Egress, Min. Granularity 64 Kbps)
- Flow-based (Ingress/Egress, Min. Granularity 64 Kbps)
- Per egress queue bandwidth control (Min. Granularity 64Kbps)
• Time-based QoS
Operation, Administration & Management (OAM)
• D-link Unidirectional Link Detection (DULD)
• Broadcast/Multicast/Unicast Storm Control
• ITU-T Y.1731
Access Control List (ACL)
• ACL based on
• 802.1p Priority
• VLAN ID
• MAC Address
• Ether Type
• IPv4/v6 Address
• DSCP
• Protocol Type
• TCP/UDP Port Number
• IPv6 Flow Label
• IPv6 Traffic Class
• User-Defined Packet Content
• Supports up to 1.5K Ingress access rules
• ACL Statistics
• Time-based ACL
• CPU Interface Filtering
Security
• IP-MAC-Port Binding
- ARP Packet Inspection
- IP Packet Inspection
- DHCP Snooping
- IPv6 ND Snooping
- Support up to 500 address binding entries per device
• SSH v2
• SSL v3
• Port Security
• Traffic Segmentation
• D-Link Safeguard Engine
• NetBIOS/NetBEUI Filtering
• DHCP Server Screening
• ARP Spoofing Prevention
• BPDU Attack Protection
AAA
• 802.1X:
- Port-based Access Control
- Host-based Access Control
- Identity-driven Policy (VLAN, ACL or QoS) Assignment
- Authentication Database Failover
• RADIUS
• TACACS
• XTACACS
• TACACS+
• RADIUS Accounting
• MAC-based Access Control (MAC):
• Compound Authentication
• Guest VLAN
• Microsoft® NAP
- Support 802.1X NAP
• Web-based Access Control (WAC):
• 3 Level User Account
• Trusted Host
Green Features
• Support Power Saving function on Gigabit ports
• Power Saving by Link Status
• IEEE 802.3az Energy Efficient Ethernet (EEE)
Management
• Web-based GUI (Support IPv4/v6)
• Command Line Interface (CLI)
• Telnet Server (Support IPv4/v6)
• Telnet Client (Support IPv4/v6)
• TFTP Client (Support IPv4/v6)
• ZModem
• SNMP v1/v2c/v3 SNMP over IPv6
• SNMP Traps
• System Log
• RMON v1:
- Supports 1,2,3,9 groups
• RMON v2:
- Supports ProbeConfig group
• sFlow
• LLDP
• BootP/DHCP Client
• DHCP Auto-Configuration
• DHCP Relay (Support IPv4/v6)
• DHCP Relay Option 60, 61, 82
• DHCP Server
• Dual Image
• Dual Configuration
• CPU Monitoring
• DNS Relay
• SNTP
• Password Recovery
• Password Encryption
• Microsoft® NLB (Network Load Balancing) Support
• Ping (Support IPv4/v6)
• Traceroute (Support IPv4/v6)
MIB
• RFC1065, 1066, 1155, 1156, 2578 MIB Structure
• RFC1213 MIB II
• RFC4022 MIB for TCP
• RFC4113 MIB for UDP
• RFC4293 IPv6 SNMP Mgmt Interface MIB
• RFC1493 Bridge MIB
• Link Aggregation LAG-MIB
• RFC2571-2576 SNMPv3 MIB
• RFC271,1757, 2819 RMON MIB
• RFC2021 RMONv2 MIB
• RFC1398, 1643, 1650, 2358, 2665 Ether-like MIB
• RFC2668, 4836 802.3 MAU MIB
• RFC2674, 4363 Q-Bridge / P-Bridge MIB
• RFC4318 RSTP MIB
• RFC2233, 2863 Interface Group MIB
• IEEE8021 PAE MIB
• RFC2925 Ping & Traceroute MIB
• LLDP MIB
• LLDP-EXT-DOT1 MIB
• LLDP-EXT-DOT3 MIB
• LLDP-EXT-MED MIB
• DOT3 OAM MIB
• IEEE8021 CFM MIB
• D-Link Private MIBs
RFC Standard Compliance
• RFC768 UDP
• RFC791 IP
• RFC792 ICMPv4
• RFC2463, 4443 ICMPv6
• RFC4884 Extended ICMP to Support Multi-Part Messages
• RFC793 TCP
• RFC826 ARP
• RFC1981 Path MTU Discovery for IPv6
• RFC2461, 4861 Neighbor Discovery for IPv6
• RFC2462, 4862 IPv6 Stateless Address Auto-configuration
• RFC3513, 4291 IPv6 Addressing Architecture
• RFC2460 IPv6
• RFC2893, 4213 IPv4/IPv6 dual stack function
• RFC2474, 3168, 3260 IPv6 Differentiated Services field
• IPv6 Ready Logo phase 2 router mode
• MEF 9&14 EPL, EVPL, ELAN
Physical
Dimensions
• 441x210x44 mm (17.36x8.26x1.73 inches)
Weight
• 3.4 kg (7.49 lbs)
Operating Temperature
• 0 to 65 ˚C (32 to 149 °F)
Storage Temperature
• -40 to 70 ˚C (-40 to 158 °F)
Operating Humidity
• 10% to 90% RH
Storage Humidity
• 5% to 90% RH
Emission (EMI)
• FCC Class A, CE, C-Tick, VCCI
Safety
• CB, cUL
Maximum Power Consumption
• 28 Watts, 110 V AC
• 27 Watts, 48 V DC
Certification
• IPv6 Ready Logo Phase 2
Products | Support  | News  | About |
