Quick find
Product features:
4-Port 10/100Mbps and 2-Port 10/100/1000Mbps Web Smart Switch with 4 PoE Ports
EOL
General features:
Size
• 7-inch metal case
Interface
• 4 10/100BASE-TX
• 2 10/100/1000BASE-T
Port Standards
• IEEE 802.3ab 1000BASE-T Gigabit Ethernet (twisted-pair copper)
• IEEE 802.3af PoE
• IEEE 802.3at PoE
• Auto-negotiation
• IEEE 802.3x Flow Control
Performance
Switching Capacity
• 4.8 Gbps
Maximum Forwarding Rate
• 3.6 Mpps
MAC Address Table Size
• 4K Entries
Packet Buffer
• 2.75 Mbits
Flash Memory
• 2 Mbytes
Forwarding Method
• Store and forward
LEDs
• Power (Per Device)
• Link/Active/Speed (Per Port)
• PoE Budget LED
PoE Capable Ports
• Ports 1-4
Power Budget
• 80 W
Software Features
Layer 2 Features
• MAC Address Table
  • 4K entries
• Flow Control
  • 802.3x Flow Control
  • HOL Blocking Prevention
• Port Mirroring
  • One-to-One
  • Many-to-One
  • Supports Mirroring for Tx/Rx/Both
• Spanning Tree
  • Supports 802.1D STP 2004 edition
  • Supports 802.1w RSTP
  • Supports Root Restriction (defined in 802.1Q-2005)
• 802.3ad Link Aggregation
  • Supports 2 trunking groups:
    • 2-4 ports per trunk, port 1-4 and port 5-6
Layer 2 Multicasting
• IGMP Snooping
  • Supports IGMP v1/2
VLAN
• VLAN mode: tag-based or port-based*
Quality of Service (QoS)
• 802.1p
• Max. 4 queues per port
• Queue Handling
  • Strict
  • Weighted Round Robin (WRR)
• Bandwidth control
• CoS Based on:
  • 802.1p
  • DSCP
  • ToS
  • TCP/UDP port number
Security
• Storm Control
• MAC-Port Binding
Physical
MTBF
• 61320 hours
Acoustics
• 0 dB
Heat Dissipation
• 45.73 BTU/h
Power Input
• 54 V / 2.22 A external power adapter
Maximum Power Consumption
• 94.5 W
Weight
• 480 g
Dimensions
• 180 x 145 x 34 mm
Operating Temperature
• 0 to 50°C
Storage Temperature
• -20 to 70 °C
Operating Humidity
• 20% to 80% non-condensing
Storage Humidity
• 10% to 90% non-condensing
Certification
• CE
* Only one VLAN mode can be enabled at a time.
Products | Support  | News  | About |
