Quick find
Product features:
Pan & Tilt Wireless N Network Camera
EOL EOS
Description:
Full-featured wireless surveillance camera
D-Link DCS-5230L Pan & Tilt Wireless N Network Camera is a pan and tilt wireless network camera, ideal for small-to-medium business applications and remote monitoring over the Internet. It gives you detailed remote surveillance of a large area by using a 1.3 megapixel CMOS image sensor for high-quality video and a built-in IR illuminator for low-light surveillance. The DCS-5230L can also be connected to your network wirelessly, allowing you to place the camera anywhere, and eliminating the need to install network cabling.
A Complete Surveillance System
The DCS-5230L includes a built-in CPU, allowing it to be used as a complete, standalone surveillance system. Recordings can be made continuously, whenever movement is detected, or according to a schedule you define. E-mail notifications can be sent when specific events occur, keeping you informed of what’s going on. The built-in microSD slot allows the camera to run independently, or can be used to continuously record video even if the network connection is lost. The DCS-5230L can also be used as part of a multi-camera surveillance system through the included D-ViewCam software, which supports up to 32 cameras.
Sharp image monitoring from different angles
With sharp, responsive pan/tilt movement and digital zoom, the D-Link Pan & Tilt Wireless N Network Camera gives you full control, so you can quickly scan a wide area from a variety of angles, and 16x digital zoom lets you zoom in for more detail.1 The DCS-5320L can also be set to automatically move to specific preset positions, allowing the camera to patrol and secure a wide area.
MyDLink for easy setup and remote viewing on your phone
D-Link’s convenient mydlink™ zero-configuration setup gets you up and running in no time – just connect the DCS-5320L, then register the device on the mydlink™ website. The DCS-5320L will then automatically configure itself and connect to the mydlink™ service, which gives you convenient access to your video feeds through the mydlink website. You can even view your camera feeds on your smart phone or tablet with the mydlink iOS and Android apps so you can stay in touch on the go.
Products | Support  | News  | About |
