Quick find
Product features:
Wireless Day & Night Internet Camera
EOL EOS
General features:
Camera Specifications
- Built-in 1/3-inch CCD sensor
- Minimum illumination: 0.5 Lux @ f2.0 (typical); 0 Lux (10 meter range with optional IR Lens)
- Resolution: 380 TV lines
- Seamless digital zoom with up to 4x magnification
- AGC / AWB / AES / BLC
- Electronic shutter: 1/60 ~ 1/100,000 secretary.
- CS mount lens: 6mm, f2.0
- Lens mount supports Auto Iris lens (DC/Video Drive) or IR
- Lens (10 meter range)
- 66  field of view
LED Indicator
Single two-color LED for status indication (POST, connection, heartbeat)
Reset Button
Reset to factory default settings
Extended I/O
- 1 relay alarm output (max. 24V DC 1A /  125V AC 0.5A)
- 1 Optic-isolated sensor input (max.12V DC 50mA)
Memory
- SDRAM: 16Mbytes
- Flash ROM: 4Mbytes
Video Resolution
NTSC support:
- Up to 30fps at 176 x 120 (NTSC)
- Up to 30fps at 352 x 240 (NTSC)
- Up to 15fps at 704 x 480 (NTSC)
PAL support:
- Up to 25fps at 176 x 144 (PAL)
- Up to 25fps at 352 x 288 (PAL)
- Up to 12fps at 704 x 576 (PAL)
Video Algorithm Support
- MPEG4 simple profile or MJPEG compression for streaming video
- JPEG compression for still image
Video Features
- Adjustable image size and quality
- Time stamp and text overlays
- Three configurable motion detection windows
- Flip & Mirror
Microphone
- Omni-directional
- Frequency 20 to 20000Hz
- S/N Ratio over 58dB
Audio
- Sampling rates: 8K / 24K / 32Kbps
- Full duplex audio communication
- Acoustic echo cancellation
Audio Output
- Proprietary, 8K~32K bps audio codec
- 2-way audio, mono, supporting simplex, half-duplex, full-duplex modes
- Can be muted at server side by administrator (camera microphone on/off)
- Can be muted at client side (PC speaker on/off)
- Adjustable audio volume (PC microphone on/off)
Network Connectivity
- 802.11g Wireless LAN
- 802.3 10/100Mbps Fast Ethernet supporting NWay auto negotiation
Network Protocol Support
UPnP, TCP/IP, HTTP, SMTP, FTP,  NTP, DNS, DDNS, DHCP, PPPoE
Configuration
- 3 motion-detection windows
- 2 adjustable parameters: sensitivity and percentage
Digital Input
- Status checking of high, low, rising, falling
- DI triggered or motion triggered alert and notified via FTP or e-mail
Digital Output
On/Off
Video Bit Rate
64 ~ 1200Kbps
Remote Management
- Configuration can be accessed via web browser
- Take snapshots and save to local hard drive via web browser
Security
- Administrator and user group protected
- Password authentication
- Wireless LAN security: 64/128-bit WEP and WPA-PSK data encryption
Surveillance Software Functions
- Remote management/control of up to 16 DCS-3420 cameras
- Viewing of up to 16 cameras on one screen
- Supports all management functions provided in web interface
- Scheduled motion triggered, or manual recording options
Viewing System Requirements
- Operating System: Microsoft Windows 98 SE, 2000, ME, XP
- Browser: Internet Explorer v.6.0 or later
Optional Accessories
- Auto Iris Lens (3x Optical Zoom)
- IR Lens
- Illuminator for Night Vision
- External Speakers
- External All-Weather Housing  (wired Ethernet connections only)
Optional Protocol
SMTP Authentication
Wireless LAN
Radio and Modulation Schemes
- 802.11b: DQPSK, DBPSK and  CCK
- 802.11g: BPSK, QPSK, 16QAM,  64QAM, OFDM
Operating Frequency
2400 to 24835MHz
Wireless Data Rates
- 802.11b: 11, 5.5, 2  and 1Mbps
- 802.11g: 54, 48, 36,  24, 18, 12, 9  and 6Mbps
Receiver Sensitivity
802.11b:
- 11 Mbps (CCK): -84dBm
- 5.5 Mbps (CCK): -86dBm
- 2 Mbps (DQPSK): -88dBm
- 1 Mbps (DBPSK): -90dBm
(typically @PER < 8% packet size 1024 and  @25  C + 5  C)
802.11g:
- 54 Mbps (OFDM): -66dbm
- 48 Mbps (OFDM): -  70dbm
- 36 Mbps (OFDM): -76dbm
- 24 Mbps (OFDM): -79dbm
- 18 Mbps (OFDM): -83dbm
- 12 Mbps (OFDM): -85dbm
- 9 Mbps (OFDM): -86dbm
- 6 Mbps (OFDM): -86dbm
(typically @PER <10% packet  size 1024 and @25  C + 5  C)
Transmitter Output  Power
- 802.11b: 16dBm (typical)
- 802.11g: 12dbm (typical)
Antennas
2dBi Gain dipole antenna  with reverse SMA plug
Power Input
12VDC, 1.5A
Power Supply
Through external AC switching power adapter
Power Consumption
7 watts maximum
Dimensions
170(L) x 80(W) x 60(H) mm (camera only, excluding antenna)
Weight
544 grams (camera only with antenna)
Operating Temperature
0  to 50 C (32  to 122  F)
Storage Temperature
-40  to 70 C (-40  to 158  F)
Humidity
20% to 80% non-condensing
Emission (EMI), Safety & Other Certifications
- FCC
- CE
- IC
- C-Tick
Radio
EN 300 328-2 (07-2000)
Safety
EN60950
Package Includes
- DCS-3420 Wireless Internet Camera
- 12V/1.5A external power adapter
- CAT 5 Ethernet cable
- Quick Installation Guide
- Master CD
- One dipole antenna
- Camera stand
Products | Support  | News  | About |
