Quick find
Product features:
Dual-Band Omni Directional Antenna
EOL EOS
General features:
Power Handling
5 W (cw)
Impedance
50 ohms
Connector
N Jack (built-in)
Extension Cable
N/A
Mounting Type
Pole
Surge Arrestor
Optional
Survival Wind Speed
216 km/hr
Operating Temperature
-40°C to +80°C
Operating Humidity
95% @ 55°C
Color
White
Material
Glass Fiber, UV resistant
Weight
1.03 kg
Dimensions
1220 (L) x 75 (W) x 80 (H) mm
1 Transmission and reception distances can vary according to the transmission speeds. To get maximum signal coverage, make sure there is no obstruction in the signal path between the transmission and reception ends.
2 The transmission distance range depends on the two same spec antennas with default cable loss under free line of sight environment.
Power Handling
5 W (cw)
Impedance
50 ohms
Connector
N Jack (built-in)
Extension Cable
N/A
Mounting Type
Pole
Surge Arrestor
Optional
Survival Wind Speed
216 km/hr
-40°C to +80°C
Operating Humidity
95% @ 55°C
Color
White
Material
Weight
1.03 kg
Dimensions
Products | Support  | News  | About |
