DBT-120EOL EOS
Bluetooth 1.1 Adapter for PC
Where to buy
Description
Bluetooth 1.1 Standard Data Encryption Security
Adhering to Bluetooth 1.1 standard, the DBT-120 supports  Security is an issue when data is transmitted without the wireless data transfers of 723Kbps at ranges up to 10  wires. In the air, transmitted data can be easily intercepted meters or 33 feet. This capability allows you to establish an  if not well protected by a security scheme. The DBT-120 automatic wireless connection at a decent speed within a  provides the necessary security, using the enhanced 128-bit convenient range between your computer and your PDA,  data encryption on any Bluetooth communication. mobile phone and other devices.
Wireless Connection
As a new technology for wireless connectivity, the DBT - your computer simple and easy. With Bluetooth software 120 lets you connect to a wide variety of devices without  provided and easy-to-understand instructions, this adapter long cables trailing all over the place. Using a radio-based  lets you experience true wireless connectivity and link with integrated antenna, the DBT-120 connects  enhanced compatibility with Bluetooth enabled devices. different devices together, giving you more freedom to roam.
Security is an issue when data is transmitted without the wires. In the air, transmitted data can be easily intercepted if not well protected by a security scheme. The DBT-120 provides the necessary security, using the enhanced 128-bit data encryption on any Bluetooth communication.
Simple Installation
The DBT-120 plug-and-play feature makes installation on your computer simple and easy. With Bluetooth software provided and easy-to-understand instructions, this adapter lets you experience true wireless connectivity and enhanced compatibility with Bluetooth enabled devices.
General features
Certificates
Order info
Pictures
DBT-120
Front view
Downloads
Support Resources
