Quick find
Product features:
Unified Service Router
EOL EOS
General features:
Interface
• Ethernet:
• 10/100/1000 Mbps WAN Port
• 8 10/100/1000 Mbps LAN Ports
• USB 2.0 Ports: 1
• Console: 1 RJ-45
System Performance****
• Firewall Throughput***: 45 Mbps
• VPN Throughput*****: 35 Mbps
• Concurrent Sessions: 20.000
• New Sessions (per second): 200
• Firewall Policies: 200
Internet Connection Type
• Static/Dynamic IP
• PPPoE/L2TP/PPTP
• Multiple PPPoE
Firewall System
• Static Route
• Dynamic DNS
• Inter-VLAN Route
• NAT, PAT
• Web Content Filtering: Static URL, Keywords
• Intrusion Prevention System (IPS): Signature Package Included in Firmware
Networking
• DHCP Server/ Client
• DHCP Relay
• IEEE802.1q VLAN
• VLAN (Port-Based)
• IP Multicast: IGMP Proxy
• IPv6
• 3G Redundancy
Virtual Private Network (VPN)
• VPN Tunnels: 55
• IPSec Tunnels: 25
• SSL VPN Tunnels: 5
• PPTP/L2TP Clients: 25
• Encryption Methods: DES, 3DES, AES, Twofish, Blowfish, CAST-128, NULL
• SSL Encryption Methods: RC4-128, 3DES, AES
• IPSec/PPTP/L2TP Server
• IPSec NAT Traversal
• Dead Peer Detection
• IP Encapsulating Security Payload (ESP)
• IP Authentication Header (AH)
• VPN Tunnel Keep Alive
• Hub and Spoke
Bandwidth Management
• Max. Bandwidth Control
• Priority Bandwidth Control:
• Port-Based QoS
• 3 Classes
System Management
• Web-based User Interface: HTTP, HTTPS
• Command Line
• SNMP: v1, v2c, v3
• Power Supply: External Power Supply Unit, DC 12 V/1.5 A
• Max. Power Consumption: 11.8 W/ 12.6 W
• Dimensions (L x W x H): 140 x 203 x 35 mm
• Operation Temperature: 0 to 40°C
• Storage Temperature: -20 to 70°C
• Operation Humidity: 5% to 95% non-condensing
• EMI/EMC: FCC Class B, CE Class B, C-Tick, IC
• Safety: cUL, LVD (EN60950-1)
• MTBF: 250,000 hours
* The following 3G dongles are supported: DWM-152 A1/A2/A3, DWM-156 A1/A2/A3/A5*/A6*, DWM-157*, Huawei E1550, E173, and EC306.* The dongles marked with * will be supported through firmware upgrades.
** Available through firmware upgrade.
*** VPN throughput is measured using UDP traffic with a 1420 byte packet size, adhering to RFC2544.
**** The maximum firewall throughput is based on RFC2544 testing methodologies.
***** Actual performance may vary depending on network conditions and activated services.
Products | Support  | News  | About |
