DIR-822
AC1200 Wave 2 MU-MIMO Wi-Fi EasyMesh Router
Description
Wireless Interface
Using the DIR-822 device, you are able to quickly create a high-speed wireless network at home or in your office, which lets computers and mobile devices access the Internet virtually anywhere (within the operational range of your wireless network). Simultaneous activity of 2.4GHz band and 5GHz band allows performing a wide range of tasks. The router can operate as a base station for connecting wireless devices of the standards 802.11a, 802.11b, 802.11g, 802.11n, and 802.11ac (at the wireless connection rate up to 1167Mbps1).
Secure Wireless Connection
The router supports multiple functions for the wireless interface: several security standards (WEP, WPA/WPA2/WPA3), MAC address filtering, WPS, WMM.
In addition, the device is equipped with a button for switching the Wi-Fi network off/on. If needed, for example, when you leave home, you can easily switch the router’s WLAN by pressing the button, and devices connected to the LAN ports of the router will stay online.
The EasyMesh function is D-Link implementation of mesh networks designed to quickly connect several2 devices into one transport network, for example, when it's required to provide high-quality Wi-Fi coverage without dead zones in living units of complicated planning or it's needed to create a large temporary Wi-Fi network for an outdoor event.
Multi-user MIMO technology allows to distribute the router's resources to let multiple wireless clients use the Wi-Fi network efficiently, keeping high rates for HD media streaming, lag-free gaming, and fast transfer of large files.
Transmit Beamforming technology allows to flexibly change the antennas' radiation pattern and to redistribute the signal directly to wireless devices connected to the router.
Support of guest Wi-Fi network allows you to create a separate wireless network with individual security settings and maximum rate limitation. Devices connected to the guest network will be able to access the Internet, but will be isolated from the devices and resources of the router's LAN.
Security
The wireless router DIR-822 includes a built-in firewall. The advanced security functions minimize threats of hacker attacks, prevent unwanted intrusions to your network, and block access to unwanted websites for users of your LAN.
The SSH protocol support provides more secure remote configuration and management of the router due to encryption of all transmitted traffic, including passwords.
In addition, the router supports IPsec and allows to create secure VPN tunnels. Support of the IKEv2 protocol allows to provide simplified message exchange and use asymmetric authentication engine upon configuration of an IPsec tunnel.
The router also supports the SkyDNS web content filtering service, which provides more settings and opportunities for safer Internet experience for home users of all ages and for professional activities of corporate users.3
Now the schedules are also implemented; they can be applied to the rules and settings of the firewall and used to reboot the router at the specified time or every specified time period, to set rules for limitation of wireless client maximum bandwidth4, and to enable/disable the wireless network and the Wi-Fi filter.
The new ad blocking function effectively blocks advertisements which appear during web surfing.
Easy configuration and update
You can configure the settings of the wireless router DIR-822 via the user-friendly web-based interface (the interface is available in several5 languages).
The configuration wizard allows you to quickly switch DIR-822 to one of the following modes: router (for connection to a wired or wireless ISP), access point, repeater, or client, and then configure all needed setting for operation in the selected mode in several simple steps.
Also DIR-822 supports configuration and management via mobile application for Android smartphones.
You can simply update the firmware: the router itself finds approved firmware on D-Link update server and notifies when ready to install it.
1Up to 300Mbps for 2.4GHz and up to 867Mbps for 5GHz.
2Up to 6 devices. Cooperation is supported for the following models: DIR-X1530/A1, DIR-X1510/R1, DIR-842V2/A1, DIR-842/R7, DIR-842/R5, DIR-842/S2, DIR-842/S1, DIR-842/R4, DIR-830M/A1, DIR-825/R7, DIR-825/R5, DIR-825/I1, DIR-825/R4, DIR-822/E1, DIR-822/R4, DIR-815/R4. Provided that the FW version supporting the EasyMesh function is used.
3Only for DIR-822/R4.
4Only for DIR-822/E1.
5In Russian and English for DIR-822/R4.
General features
				 DIR-822/R4
				 DIR-822/E1
				 Hardware
				 Processor
				 RTL8197FH-VG (1GHz)
				 RAM
				 128MB, DDR2, built in processor
				 Flash
				 128MB, SPI NAND
				 Interfaces
				 10/100BASE-TX WAN port
				4 10/100BASE-TX LAN ports
				 LEDs
				 Power
				Internet
				4 LAN LEDs
				WLAN 2.4G
				WLAN 5G
				WPS
				 Power
				Internet
				WLAN 2.4G
				WLAN 5G
				 Buttons
				 POWER button to power on/power off
				WIFI button to enable/disable wireless network
				WPS button to connect mesh network devices and set up wireless connection
				RESET button to restore factory default settings
				 ON/OFF button to power on/power off
				WPS button to connect mesh network devices, set up wireless connection, and enable/disable wireless network
				 Antenna
				 Four external non-detachable antennas (5dBi gain)
				 MIMO
				 2 x 2, MU-MIMO
				 Power connector
				 Power input connector (DC)
				 Mounting
				 Desktop
				Wall
				 Software
				 WAN connection types
				 PPPoE
				 IPv6 PPPoE
				 PPPoE Dual Stack
				 Static IPv4 / Dynamic IPv4
				 Static IPv6 / Dynamic IPv6
				 PPPoE + Static IP / Dynamic IP (PPPoE Dual Access)
				 PPTP/L2TP + Static IP
				 PPTP/L2TP + Dynamic IP
				 Network functions
				 DHCP server/relay
				 Advanced configuration of built-in DHCP server
				 Stateful/Stateless mode for IPv6 address assignment, IPv6 prefix delegation
				 Automatic obtainment of LAN IP address (for access point/repeater/client modes)
				 DNS relay
				 Dynamic DNS
				 Static IPv4/IPv6 routing
				 IGMP/MLD Proxy
				 RIP
				 Support of UPnP
				 Support of VLAN
				 WAN ping respond
				 Support of SIP ALG
				 Support of RTSP
				 WAN failover
				 Autonegotiation of speed, duplex mode, and flow control / Manual speed and duplex mode setup for each Ethernet port
				 Built-in UDPXY application
				 Firewall functions
				 Network Address Translation (NAT)
				 Stateful Packet Inspection (SPI)
				 IPv4/IPv6 filter
				 MAC filter
				 Ad blocking function
				 URL filter
				 DMZ
				 Virtual servers
				 Built-in SkyDNS web content filtering service
				 VPN
				 IPsec/PPTP/L2TP/PPPoE pass-through
				 PPTP/L2TP tunnels
				 L2TP over IPsec
				 IPsec tunnels
				 Transport/Tunnel mode
				 IKEv1/IKEv2 support
				 DES encryption
				 NAT Traversal
				 Support of DPD (Keep-alive for VPN tunnels)
				 Management and monitoring
				 Local and remote access to settings through SSH/TELNET/WEB (HTTP/HTTPS)
				 Bilingual web-based interface for configuration and management (Russian/English)
				 Multilingual web-based interface for configuration and management
				 Support of D-Link Assistant application for Android smartphones
				 Notification on connection problems and auto redirect to settings
				 Firmware update via web-based interface
				 Automatic notification on new firmware version
				 Saving/restoring configuration to/from file
				 Support of logging to remote host
				 Automatic synchronization of system time with NTP server and manual time/date setup
				 Ping utility
				 Traceroute utility
				 TR-069 client
				 Schedules for rules and settings of firewall, automatic reboot, limitation of wireless client maximum bandwidth1, and enabling/disabling wireless network and Wi-Fi filter
				 Automatic upload of configuration file from ISP's server (Auto Provision)
				 Wireless Module Parameters
				 Standards
				 IEEE 802.11ac Wave 2
				IEEE 802.11a/b/g/n
				IEEE 802.11k/v
				IEEE 802.11w
				 Frequency range
				The frequency range depends upon the radio frequency regulations applied in your country
				 2400 ~ 2483.5MHz
				5150 ~ 5350MHz
				5650 ~ 5850MHz
				 Wireless connection security
				 WEP
				 WPA/WPA2 (Personal/Enterprise)
				 WPA3 (Personal)
				 МАС filter
				 WPS (PBC)
				 WPS (PIN)
				 Advanced functions
				 EasyMesh function
				 Support of client mode
				 WMM (Wi-Fi QoS)
				 Information on connected Wi-Fi clients
				 Advanced settings
				 Guest Wi-Fi / support of MBSSID
				 Rate limitation for wireless network/separate MAC addresses
				 Periodic scan of channels, automatic switch to least loaded channel
				 Support of 5GHz TX Beamforming
				 Autonegotiation of channel bandwidth in accordance with environment conditions (20/40 Coexistence)
				 Support of STBC
				 Wireless connection rate
				 IEEE 802.11a: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
				IEEE 802.11b: 1, 2, 5.5, and 11Mbps
				IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
				IEEE 802.11n (2.4/5GHz): from 6.5 to 300Mbps (MCS0–MCS15)
				IEEE 802.11ac (5GHz): from 6.5 to 867Mbps
				 Transmitter output power
				 Less than 20dBm (100mW)
				 Receiver sensitivity
				 802.11a
				 -92dBm at 6Mbps
					-91dBm at 9Mbps
					-90dBm at 12Mbps
					-88dBm at 18Mbps
					-85dBm at 24Mbps
					-81dBm at 36Mbps
					-77dBm at 48Mbps
					-75dBm at 54Mbps
				 -95dBm at 6Mbps
					-93dBm at 9Mbps
					-92dBm at 12Mbps
					-90dBm at 18Mbps
					-87dBm at 24Mbps
					-84dBm at 36Mbps
					-80dBm at 48Mbps
					-78dBm at 54Mbps
				 802.11b
				 -95dBm at 1Mbps
					-91dBm at 2Mbps
					-90dBm at 5.5Mbps
					-87dBm at 11Mbps
				 -90dBm at 1Mbps
					-92dBm at 2Mbps
					-93dBm at 5.5Mbps
					-96dBm at 11Mbps
				 802.11g
				 -92dBm at 6Mbps
					-91dBm at 9Mbps
					-90dBm at 12Mbps
					-88dBm at 18Mbps
					-85dBm at 24Mbps
					-81dBm at 36Mbps
					-77dBm at 48Mbps
					-76dBm at 54Mbps
				 -94dBm at 6Mbps
					-92dBm at 9Mbps
					-90dBm at 12Mbps
					-89dBm at 18Mbps
					-87dBm at 24Mbps
					-84dBm at 36Mbps
					-80dBm at 48Mbps
					-77dBm at 54Mbps
				 802.11n
				 2.4GHz, HT20
					-92dBm at MCS0/8
					-90dBm at MCS1/9
					-87dBm at MCS2/10
					-84dBm at MCS3/11
					-81dBm at MCS4/12
					-77dBm at MCS5/13
					-75dBm at MCS6/14
					-74dBm at MCS7/15
					2.4GHz, HT40
					-88dBm at MCS0/8
					-86dBm at MCS1/9
					-84dBm at MCS2/10
					-81dBm at MCS3/11
					-77dBm at MCS4/12
					-73dBm at MCS5/13
					-71dBm at MCS6/14
					-70dBm at MCS7/15
					5GHz, HT20
					-91dBm at MCS0/8
					-90dBm at MCS1/9
					-88dBm at MCS2/10
					-84dBm at MCS3/11
					-81dBm at MCS4/12
					-76dBm at MCS5/13
					-75dBm at MCS6/14
					-73dBm at MCS7/15
					5GHz, HT40
					-90dBm at MCS0/8
					-87dBm at MCS1/9
					-84dBm at MCS2/10
					-81dBm at MCS3/11
					-78dBm at MCS4/12
					-73dBm at MCS5/13
					-72dBm at MCS6/14
					-70dBm at MCS7/15
				 2.4GHz, HT20
					-95dBm at MCS0/8
					-91dBm at MCS1/9
					-88dBm at MCS2/10
					-86dBm at MCS3/11
					-82dBm at MCS4/12
					-79dBm at MCS5/13
					-77dBm at MCS6/14
					-75dBm at MCS7/15
					2.4GHz, HT40
					-92dBm at MCS0/8
					-89dBm at MCS1/9
					-86dBm at MCS2/10
					-83dBm at MCS3/11
					-80dBm at MCS4/12
					-77dBm at MCS5/13
					-74dBm at MCS6/14
					-72dBm at MCS7/15
					5GHz, HT20
					-95dBm at MCS0/8
					-93dBm at MCS1/9
					-90dBm at MCS2/10
					-87dBm at MCS3/11
					-83dBm at MCS4/12
					-79dBm at MCS5/13
					-77dBm at MCS6/14
					-75dBm at MCS7/15
					5GHz, HT40
					-92dBm at MCS0/8
					-89dBm at MCS1/9
					-86dBm at MCS2/10
					-83dBm at MCS3/11
					-80dBm at MCS4/12
					-76dBm at MCS5/13
					-74dBm at MCS6/14
					-72dBm at MCS7/15
				 802.11ac
				 VHT20
					-91dBm at MCS0
					-89dBm at MCS1
					-87dBm at MCS2
					-84dBm at MCS3
					-81dBm at MCS4
					-76dBm at MCS5
					-75dBm at MCS6
					-74dBm at MCS7
					-69dBm at MCS8
					VHT40
					-90dBm at MCS0
					-87dBm at MCS1
					-84dBm at MCS2
					-81dBm at MCS3
					-78dBm at MCS4
					-73dBm at MCS5
					-72dBm at MCS6
					-71dBm at MCS7
					-66dBm at MCS8
					-64dBm at MCS9
					VHT80
					-87dBm at MCS0
					-83dBm at MCS1
					-81dBm at MCS2
					-78dBm at MCS3
					-74dBm at MCS4
					-70dBm at MCS5
					-69dBm at MCS6
					-67dBm at MCS7
					-63dBm at MCS8
					-62dBm at MCS9
				 VHT20
					-95dBm at MCS0
					-92dBm at MCS1
					-90dBm at MCS2
					-86dBm at MCS3
					-83dBm at MCS4
					-79dBm at MCS5
					-77dBm at MCS6
					-75dBm at MCS7
					-71dBm at MCS8
					VHT40
					-92dBm at MCS0
					-89dBm at MCS1
					-87dBm at MCS2
					-84dBm at MCS3
					-80dBm at MCS4
					-76dBm at MCS5
					-74dBm at MCS6
					-72dBm at MCS7
					-68dBm at MCS8
					-66dBm at MCS9
					VHT80
					-89dBm at MCS0
					-86dBm at MCS1
					-83dBm at MCS2
					-80dBm at MCS3
					-77dBm at MCS4
					-73dBm at MCS5
					-71dBm at MCS6
					-69dBm at MCS7
					-66dBm at MCS8
					-64dBm at MCS9
				 Modulation schemes
				 802.11a
				 BPSK, QPSK, 16QAM, 64QAM with OFDM
				 802.11b
				 DQPSK, DBPSK, DSSS, CCK
				 802.11g
				 802.11n
				 802.11ac
				 BPSK, QPSK, 16QAM, 64QAM, up to 256QAM with OFDM
				 Physical Parameters
				 Dimensions (L x W x H)
				 205 x 136 x 33 mm (8.07 x 5.35 x 1.3 in)
				 181 x 132 x 48 mm (7.13 x 5.22 x 1.88 in)
				 Weight
				 285 g (0.63 lb)
				 305 g (0.67 lb)
				 Operating Environment
				 Power
				 Output: 12V DC, 1A
				 Temperature
				 Operating: from 0 to 40 °C
				Storage: from -20 to 65 °C
				 Humidity
				 Operating: from 10% to 90% (non-condensing)
				Storage: from 5% to 95% (non-condensing)
				 Delivery Package
				 Router DIR-822
				Power adapter DC 12V/1A
				Ethernet cable
				“Quick Installation Guide” (brochure)
1Only for DIR-822/E1.
Certificates
Order info
				 DIR-822/R4
				 DIR-822/E1
