Description
Flexible Deployment
The DP-311P is ideal for both the large of fice and the small workgroup. For homes and SOHO with just one printer to share, this print server offers a single port and saves you the cost. For the large office with many computer users and several printers scattered at different places, you can plug one print server to each of these printers to share them on the network.
802.11b Wireless LAN Access
With a built-in 802.11b wireless LAN interface, the DP-311P allows your users to conveniently send files to the printer for printing. Compatible with various wireless LAN standards, this print server provides you with excellent network interoperability.
Versatile Functions
The DP-311P print server can directly attach to the parallel port on the back of your printer, eliminating the need to connect a printer cable. A detachable external antenna provides an efficient operating range for wireless users. You can easily replace this antenna with a higher Gain antenna when a longer operation range becomes necessary. For wireless security, data encryption is provided using the user-selectable 64/128-bit industry-standard WEP (Wired Equivalent Privacy) encryption protocol.
Multiple Network OS Support
The DP-311P supports many network OS, including Windows 95, 98, ME, NT 4.0, XP, Mac with Appletalk, Solaris, SCO Unix and NetWare native NDS. Thi s gives you the flexibility to install the print server, regardless of your network environment.
Easy Setup
Setup the print server is easy with a Windows-based menu-driven program, which guides you through all the necessary steps to set up and configure your network printer. SNMP and latest MIB-II MIBs are also built into the print server, allowing you to manage this device on any SNMP standard-based network.
