DIS-S310LXProje
1000Base-LX Single-Mode SFP transceiver (up to 10 km)
Tanımlama
The DIS-S310LX Gigabit SFP fiber transceiver is external transceiver designed for insertion in SFP (Small Form-Factor Pluggable) slot of network device for transmission and reception of data signals on the fiber cables. The DIS-S310LX has a wide operating  temperature  range (-40° to 85°C). This allows the transceiver to be deployed in harsher environmental conditions. This transceiver provides the Gigabit operation and physical compactness to deliver the speed, reliable long-distance (up to 10 km) data transfer, and deployment flexibility that today’s fiber networks require.
The DIS-S310LX transceiver uses standard duplex LC connector for fiber cable connection. It conforms to industry standards and is interoperable with D-Link Gigabit switches. All D-Link transceivers are hot-pluggable. Hot-swap capability allows network administrators to plug or unplug it from the SFP slot without having to turn off the power of the connected device.
Genel Özellikler
| General features | |
| Standard | • IEEE 802.3z 1000Base-LX |
| Wavelength | • 1310 nm |
| Data Rate | • 1.25 Gbps |
| Connector | • Duplex LC |
| Fiber Type | • 9/125 um Single-mode Fiber |
| Maximum Fiber Cable Length | • 10 km |
| Transmit Power Range | • -3 to -9.5 dBm |
| Receive Power Range | • -3  to -21 dBm |
| Sensitivity | • -21 dBm |
| Supported Features | • Hot swap • MSA compliant • RoHS compliant |
| Physical Parameters | |
| Power Support | • 3.3 V |
| Supply Current | • 300 mA |
| Temperature | • Operating: -40° to 85°C • Storage: -40° to 85°C |
| Humidity | • Operating: 0% to 85% • Storage: 0% to 95% |
| Dimensions | • 56.7 mm x 13.4 mm x 8.5 mm |
| Certificates | • Class 1 laser: EN 60825-1 • FDA 21 CFR 1040.10 и 1040.11 |
Çözümler
Sipariş Bilgisi
| DIS-S310LX/A1A | 1000Base-LX Single-Mode SFP transceiver (up to 10 km) |
